Question about Bissell Vacuum - Momentum Cyclonic 1 ea Bagless Upright Vacuum
What makes a bissell vac 3130 throw out dirt instead of sucking it up? i just changed the belt that was broken.
  • 1,564 Answers
Does your vac require you to twist the belt and fit it onto a shank on the impeller? If so twisting the wrong way will make your beater bar roll the wrong way and that will make it throw dirt out the front.
Posted on Mar 12, 2011
Bissel easy vac roller won't work
remove brush roll and clean any string, hair, or whatever from it. especially around the ends. you can also unscrew the ends and check for debris there also. when you put ends back on use a little wd40 to lube up the bearings. if that doesn't work replace brush and won't hurt to change belt
Feb 13, 2013 | Bissell Roller Brush 2037029 for Easy Vac...
My Bissell vacuum was making a loud vibrating sound when it was turned on, so I opened the bottom up, replaced the belt, but it is still making the loud vibration, which it wasn't doing before. Any...
Check to see that nothing is clogging the machine. If you don't find anything, then the fan on the motor may be broken or chipped.
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
Apr 27, 2011 | Bissell 3910 Bagless Upright Cyclonic...
My Bissell 3130 Easy Vac Bagless vacuum makes a "rev sound when pulling back on the vacuum, never did this before i have taken apart and cleaned vacuum thoroughly, not sure what else i can do
The drive belt may be wornout/stretched and the act of pulling the vacuum backwards could be causing the belt to slip and the motor to rev up as a result.
Do you have a replacement belt you can try?
Jan 05, 2011 | Bissell 3130 Bagless Upright Vacuum
Have a bissell easy vac 3130-B and the brush on the bottom stopped turning i never looked before so i don really know if it turned in the first place
Behind the brush will be a metal thing that spins when the vacuum runs. That's what the belt loops over with the other end around the brush. You can sometimes find the belts a places like wal mart.
Aug 31, 2010 | Vacuums
Not sucking the dirt.
Check the hose...they plug up and then everything stops...
Here is a tip that I wrote after having the same issues with my Bissell...
Bissell Bagless Upright Vacuum not working
http://www.fixya.com/support/r4387950-bissell_bagless_upright_vacuum_not
heatman101
May 20, 2010 | Panasonic MC-V9620 Canister Vacuum
Bissell proheat blowing out air instead of sucking in air
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
vm,v
Feb 16, 2009 | Bissell 1699 ProHeat Clear View Upright...
Bissell bagless
I had the same problem, called Bissell over 10 times! They send me 3 plastic inserts for the dirt chamber, not the problem. I solved it by throwing the Bissell away and buying a Eureka bagged vacuum, no more problems.
Oct 21, 2008 | Bissell 6594 PowerForce Bagless Upright...
Bissell Vacuum - Momentum Cyclonic 1 ea Bagless Upright Vacuum Logo
156 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
