We have a Maytag Performa PAV2200 Washing machine...lately, during the spin cycle it makes a loud whinning or scraping type of noise during the spin cycle and sometimes during the wash cycle.... we took off the agitator and there was nothing wedged underneath it like we thought might be happening... it seems to wash and spin ok, but we are worried about the sound.... also, when it stops running at the end of the cycle, it seems to stop more abrutley and louder... We thought about taking off the back cover of it and see if there is anything obvious wrong..but haven't yet... Your thoughts? Thanks!
  • Washing Mach... Master
  • 8,220 Answers
Might be the tub bearing going out. Is she leaking any?
Here is a visual inspect and repair of the tub seal:We have a Maytag Performa - themobilian_1841.jpgthemobilian_1842.jpgthemobilian_1843.jpg
I used a pipe wrench to unscrew thWe have a Maytag Performa - themobilian_1845.jpge seal (lefty loosey)themobilian_1845.jpgthemobilian_1846.jpgWe have a Maytag Performa - themobilian_1848.jpgg src=themobilian_1848.jpgthemobilian_1849We have a Maytag Performa - themobilian_1852.jpg><img src=themobilian_1851.jpgthemobilian_1852.jpg
Those 6 springs are pretty tough to get back on there without the special tool
other than that it all goes back pretty easy.
Service manual and more HERE
Posted on Mar 12, 2011
I have a maytag performa washer . When washing and drying clothes it make a loud screating noise
Posted on Jun 02, 2011
Loud squeaking noise during agitation and spin cycles and water leaking from underneath
it is too loose the drum make it check by a pro tech please rate my answer : )
Aug 19, 2010 | Maytag Performa PAV2200
IUs very loud during spin cycle and you would
It appears Maytag no longer produces the type of quality product we have purchased since 1970... we've owned three Maytag Washers - our last "performa" is a piece of ****!
Dec 23, 2009 | Maytag Performa PAV2200
Maytag Performa PAV2200 makes a rumbling sound while agetating. Suspect a worn bearing or belt? Could you shed any light on this?
Yes it could be the spin bearing at the base on top of the brake assembly. I would suspect that the brake assembly is the cause of the noise as this engaged when you the washer agitates. If it was the bearing it would make a loud noise in the spin cycle, too.
Nov 05, 2009 | Maytag Performa PAV2200
Screaching on all spin cycles
lean it back take off the belt turn the pump in both directions by hand. then motor and transmission pulley.unplug it first! my moneys on the pump :)
Jun 13, 2009 | Maytag Performa PAV2200
Spin cycle not working, was making loud noises,water won't drain
i dont have a model number ..just tip unit prop it up try and spin unit with belt on with your hand ,,than take belt off and spin pump pully..by itself...onthejob
Jan 24, 2009 | Maytag Performa PAV2200
Loud noise in spin cycle
it is your bearings and your transmission the noise is coming from your bearings but because you have to push the basket to get it started your transmission is bad also
Dec 30, 2008 | Maytag Performa PAV2200
LOUD NOISE IN SPIN CYCLE
you have a bad tub seal asm. remove agitator, spin basket and tub asm. remove seal and install new one. good luck
Dec 15, 2008 | Maytag Performa PAV2200
Maytag Performa - Loud Noises during Spin Cycle
This washer is JUNK!!!!!! We have the same washer (2 1/2 years old) and same problem. Tried to replace the bearing myself, no luck. So I called a repair man to come out and look at it. As soon as i told him the model number, they would'nt even come out. Very common problem for this washer. We are on our way to Sears to purchase a Kenmore.....GOOD LUCK
Sep 07, 2008 | Maytag Performa PAV2200
Washer makes loud scraping sound
Could very well be the pump as well. These pumps have been notoriously bad for the pully shaft housing slipping down and hitting the pump pully. More that likely your problem.
Jul 31, 2008 | Maytag Performa PAV2200
Noisy Washer
may be blocked outlet pipe or depending on the model a noisy drive belt, check for blockage if belt do not worry. Regards engineer
Jul 25, 2007 | Maytag Performa PAV2200
Washing Machines Logo
579 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
