Question about Dishwashers
Bosch dishwasher not working if power reset does not work what is the manual reset
  • rkraft44 Mar 12, 2011
    The model is SHI 6806. I HAVE NOT BEEN TO SEE THE MACHINE YET SO I DONT KNOW IF THERE IS A FAULT CODE
    President:
  • 1,140 Answers
Hello there,
The manual reset method depends on which model you have. On some models you need to press and hold the START/STOP (RESET) button for at least 3 seconds. On other models, you will need to press and hold both CANCEL/DRAIN buttons for three seconds.
The CANCEL/DRAIN buttons are not always explicity marked - particularly on models with the wash cycle buttons hidden on the top edge of the door. On these washers, the position of the CANCEL/DRAIN buttons depends on how many wash cycle buttons you have. If you have 3 or 4 wash cycle buttons, the CANCEL/DRAIN buttons will be numbers 1 and 3 reading from left to right. On models with 5 wash cycle buttons, the CANCEL/DRAIN buttons will be numbers 2 and 4 reading from left to right.
However, if the dishwasher isn't working, cancelling or resetting the program is unlikely to solve the problem. I would be able to assist you better, if you could let me know the following details
1. The model number of the dishwasher
2. A description of the fault . . .
- Is the power LED on or flashing or are there any other LEDs illuminated or flashing?
- What happens when you start a wash cycle - does the washer fill with water?
- If the washer fills with water, does anything else happen afterwards?
The more details you can provide, the easier it will be to diagnose the problem and suggest a solution. Please reply to me by clicking on "Add a Comment" below your question.
Thanks,
BElectric
Posted on Mar 12, 2011
  • DILLIGAF
    DILLIGAF Mar 12, 2011
    Thanks. There are 2 CANCEL/DRAIN buttons on this model. They should be clearly marked on the front panel and connected with a line under the wash cycle buttons. Press and hold these 2 buttons to drain the washer and reset the wash cycle.
    When you've had chance to inspect the washer, please let me know the details of the fault and I will provide further assistance.
    Regards,
    BElectric
  • shai her Jul 06, 2013
    Hello I have Bosh dishwasher model SGS43E72EU. It stopped working suddenly during operation there are some water stuck inside but the led is not working, nothing happens and i tried reseting it- nothing can you help me? note that yesterday i ran cleaning mode with cleaning material (blue buttle for cleaning). im not sure it is related.. Thnaks Shai hshai@hotmail.com
I have a Bosch dishwasher SHX68T52UC/02 that has stopped working.
Hello!
Here you can find manuals to a huge range of Bosch dishwashers.
Hope you find a solution.
https://manualsbrain.com/en/brands/bosch/dishwashers
Aug 31, 2017 | Bosch Dishwashers
My bosch shu43c02uc wont work at all and i think i need to reset it, how would you reset it and can you think of anything else that will help with the problem?
Hello
Welcome to Fixya.
Based on your post,"my bosch shu43c02uc wont work at all..."
This is the most common reason for these Bosch dishwashers not having power.
I would start by first shutting off the breaker. Then removing the kick plate ( access panel at the bottom ) and checking the wiring at the junction box for the dishwasher 120vac supply line.
Remove the murret's and visually inspect the wire for "resistance burn" and strip the wires back and install new fastener's if necessary to repair.
i.e.
This is actually quite common to find a wire connector come loose due to improper fastening and once the unit is in use for a while the connections heat
Sep 25, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Bosch Dishwasher will not power on
I saw my repair man do the following, which you might try...
Open the door and simultaneously press & hold down the power button with the 2 buttons used on your model to "Cancel & Drain." If the unit comes on it now is in self-diagnosis mode. Release the buttons and close the door. The unit should start to fill with water. Press the power button to exit the mode.
Jun 28, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
My bosch dishwasher does not fill with water (although it drains)
most bosch have the inlet valve at the end of the fill pipe and it has an anti-flood device.
try turning off the water, take off the fill pipe then reconnect it and see if this works.
taking off the fill pipe resets the anti-flood device
Nov 26, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
My bosch dishwasher will not reset after holding cancel and drain. It seems to want to run a cycle but will not...help please!!!
Hello michloyal68,
You said,
my bosch dishwasher will not reset after holding cancel and drain. It seems to want to run a cycle but will not...help please!!!
Try turning off the power from the breaker for 3 minutes and then restarting it!
This should reboot the system!
I hope that this is all you need to get moving again.
Let me know how it works!!
Bless You,
Huuum
Please give me a rating before you sign off.
Sep 18, 2008 | Dishwashers
Bosch SHU3306UC dishwasher stopped
Make sure you visit the Bosch dishwasher recall website as this model is under the recall with a faulty controller which may cause a fire! Check your model under http://microsites.boschappliances.com/safetyrecall/dishwasher/
then call 800.856.9226 to setup a recall repair appointment. We just found out about this recall and was never notified by Bosch even though we registered our unit after we purchased it...talk about poor customer service! Hope this helps!
Sep 04, 2007 | Bosch SHU3306UC Built-in Dishwasher
Bosch 5315 dishwasher
A fuse may have blown or a circuit breaker tripped. Replace fuse or reset circuit breaker at your fuse box/breaker box windman
Jan 30, 2006 | Bosch 24 in. SHU53 Built-in Dishwasher
Dishwashers Logo
3,201 people viewed this question
Top Dishwashers Experts
