Question about Ecoquest Flair Air Purifier
Flair living air purificaion system
I CAN'T SEEM TO BUY THE PARTS I NEED..MY FLAIR NEEDS A NEW FAN MOTOR.
MY HUSBAND CAN REPLACE IT BUT WHERE CAN I BUY IT?
THANKS
BOBBI AUSTIN
  • 3 more comments
  • BOBBIGO Aug 01, 2008
    HELLO
    IT JUST SAYS FLAIR LIVING AIR ELECTRONIC AIR PURIFICAION SYSTEM
    NO MODEL NUMBER THAT I CAN FIND.
    MY HUSBAND TOOK OUT THE MOTOR AND ALL IT HAS ON IT IS:
    BOMAX
    TYPEB-JD
    CLB
    120V 60HZ .35A
    1900 RPM
    301-7336
    DOES THAT HELP OR DO YOU NEED MORE INFO
    THANKS
    BOBBIGO
    HELLO AGAIN
    I GUESS I SHOULD HAVE SAID ECOQUEST THAT IS CORRECT
    BOBBIGO
    HELLO AGAIN
    NO THE PLUGS ARE IN THE WRONG DIRECTION..THE ALPINE IS DIFFERANT THAN THE FLAIR.
    SORRY
    BOBBIGO
    I DIDN'T FIND THE PART ON EBAY.
    THAT WAS FOR ANOTHER KIND OF LIVING AIR PURIFICATION SYSTEM.
    MINE IS OLDER, IT IS JUST THE FLAIR THE MOTOR I NEED IS BOMAX
    TYPEB-JD
    CLB
    120V 60HZ .35
    1900 RPM
    301-7336
    AND THE PLUGS ARE ON THE TOP POINTING BACKWARDS WITH THE FAN IN THE FRONT BOTTOM.
    DEAR EXPERTS
    NO LUCK ON THOSE SITES FOR MY PART.
    I STILL NEED THE FAN MOTOR FOR THE ECOQUEST FLAIR..NOT THE NEWER MODELS.
    I WILL WRITE WHAT WAS ON THE MOTOR ITSELF AGAIN.
    BOMAX
    TYPEB-JD
    CLB
    120V 60HZ .35
    1900 RPM
    301-7336
    HOPE YOU CAN FIND ONE FOR ME..
    BOBBIGO
    Genius:
  • 1,689 Answers
Here are parts for your air purifier, including the motor and other parts you may need in the future.
AirPurifierRepair.
- just click the link
hope that helps, good luck
Posted on Aug 01, 2008
  • marlon john madrid
    marlon john madrid Aug 01, 2008
    here is the link i sent earlier:
    http://airpurifierrepair.com/index.aspx?...
    just copy and paste that to your address bar.
    you may even call their toll free number for more information.
    (800)705-7071
    (800)705-7071
Hey its a simple fix
contact any appliance parts service center
they are in most major cities in the phone book
get a SUPEO SM673 Utility Motor Kit
cost is from 25.00 List to $15.00 wholesale
now the trick
toss out the 2 fan blades that it comes with the motor kit
turn the fan upside down and remount it on the metal frame
(motor box up) it will work just fine
tighten the mounting nuts and place the fan assembly back onto the unit frame
push on the old fan (black) blade,
make sure it is deep in the fan house so the grill does not stop the rotation
replace the fan grill
take the two pink wires and clip off the wire connectors
take one and wire nut it to the white wire (common)
take the other and wire nut it to the black (high speed)
do not use the red wire (slow speed), just tape it off, so it does not ground
test the circuit, turn on the unit with the filter switch depressed
KEWL
reinseert the assemble flair frame into the box
enjoy the fresh air
15 minutes or less
3 hours to find the right replacement fan
charges from Eco == $250.
the right way- this way === priceless (under $40.00
your welcome
Lee Novak
leemnovak@hotmail.com
Posted on May 10, 2009
    Genius:
  • 2,035 Answers
Please use this link to buy a new motor :
http://www.pureairfacts.com/reviews/air-purifier/ecoquest/
Good luck..
  • 876 Answers
You could look for your item at a thrift store such as goodwill. You can often find a machine for parts.
  • 13,433 Answers
I will look for the replacement part but I need the following information
-Brand - Ecoquest?
-Model - ?
-Make - Flair air purifier?
Does the old fan have a part number or serial?
Posted on Jul 31, 2008
How do you clean motor on Flair? Fan will not turn
The motor shouldn't need cleaning that would prevent it from turning on. When was the last time you cleaned the machine?
Jul 26, 2011 | Ecoquest Flair Air Purifier
I cleaned my Flair air purifier, The motor turns on but not the fan even after lubricating the fan shaft and giving the fan blades a little push. Any suggestions on how to get this going?
The Flair is no longer manufactured nor serviced by EcoQuest, and the company is now Vollara. If what you're hearing is the fan motor (there is no other motor associated with this machine), it might mean that either it's totally seized up, or that the oil just has not penetrated deeply enough.
1) Turn the machine over and remove the large screw in the bottom. The chassis will then slide out (I assume you've already done this in order to reach the fan shaft.)
2) Firmly pull on the fan blades near the center in order to pull them free of the shaft.
3) Turn the chassis on its back, so the fan shaft points up. Drip a small amount of lightweight oil (sewing machine, hair clipper, 3-in-1) on the shaft and turn it manually to work the oil down the shaft. Continue doing this if you feel the shaft loosening up.
4) Set the chassis upright, tilt it forward, and drip a small amount of oil on the rear opening to the fan shaft. Continue manually turning the shaft and tilting the machine to work the oil in.
5) Replace the fan blades and turn on the machine, depressing the safety switch manually, to see if the fan will begin to turn.
If it won't turn, it might mean that the fan motor is entirely seized up. You may be able to find a local small appliance repair person who could replace that motor.
Your other option is to call Vollara customer service at 800-989-2299 and ask them to explain your options. Use #16618 if you need a dealer referral number.
Feb 11, 2011 | Ecoquest Flair Air Purifier
Can feel motor run, but fan doesn't turn and very little ozone smell-have new plate
same deal with mine. Im gonna open er up n give a look c. Im thinkin the fan motor is running but not enough 2 turn the blades. Im fixin 2 google fan motors now as a matter of fact.
Jun 09, 2010 | Ecoquest Flair Air Purifier
HELLO AND GOOD MORNING I HAVE A FLAIR AIR
Open the back and change the Ozone plate. then slide out the ION plate and clean it with denatured alcohol. If no light inside, you may have to replace the bulb and / or starter. Hope that helps.
Mar 18, 2010 | Ecoquest Flair Air Purifier
How do we clean the fan on our Flair?
take the grill of and get a soft cloth and lubricate the center of the motor
Mar 17, 2010 | Ecoquest Flair Air Purifier
Ecoquest flair fan replacement. Cannot read the model # on fan.
I can help you get a replacement fan for your flair if you still have not found one. You can reach me at stevelam@ecobusiness.com.
Oct 12, 2009 | Ecoquest Breeze AT Living Air Purifier
Unit hums slightly but fan doesn't turn. I cleaned dust out of unit but still no results.
Shut the power off to the unit, spin the fan blade to see if it spins freely. If it doesn't spin freely, (there appears to be a little drag when you spin it),the bearings are bad, if it does spin freely, then try moving the motor shaft from side to side if there’s any play in the shaft side to side then the bearings are worn and motor needs replaced. Then, check the capacitor, if it’s bulging even slightly, the capacitor is bad and needs replaced. Most of the time people replace the capacitor if motor seems ok. If capacitor is ok, turn power on to see if the motor is getting the proper voltage, if it is and not trying to run, then the windings are probably open, the motor's bad and needs replaced.
Aug 06, 2009 | Ecoquest Flair Air Purifier
Only one plate inside, it's glass edges are broken or deteriorate
I haven't seen an older Flair that I know of. There will be as many slots for plates as are required. The filter is definitely washable. Use an enzyme cleaner and rinse with hot water. The fan motor should be oiled every month or two. It should cost less than $100 to get it running in top shape.
Feb 08, 2009 | Ecoquest Flair Air Purifier
Fan trouble with Flair
remove the retaining screw from the bottom of the unit and slide the insides out the back. use WD40 with the plastic extension tube, spray into the motor armature/stator and turn with your hand until it is free spinning then reassemble and turn on.
this is an ongoing problem with my unit because the air and all contaminents are pulled directly to the fan.
Apr 04, 2008 | Ecoquest Flair Air Purifier
My Fan on My Flair purifier is not turning when I turn on the unit. Nervous about poking around in there don't want to break it, any ideas how to fix this? Thanks
To fix it..........there is one screw on the unit on the outside.........really long!.......remove that and the entire unit just slides out of the housing..........
The replacement fan motor can be purchased on ebay....ranging from $21.95 to $32.95...depending on the model Flair that you have...the most common one is the $29.95 replacement...
Really quite simple to remove and replace!!! and well worth it!
Hope this helps.
Feb 02, 2008 | Ecoquest Flair Air Purifier
Ecoquest Flair Air Purifier Logo
2,198 people viewed this question
Top Ecoquest Air Purifiers Experts
fordexpert
Michael Youngman
Michael Youngman
Are you an Ecoquest Air Purifier Expert? Answer questions, earn points and help others
