Question about Dryers
Where is teh thermal breaker located - Dryers
  • 552 Answers
Depending on the make and model number it is on the heater canister.
You can watch a video that explains how to take apart the dryer and test the fuse at the link below.
http://www.appliancerepairlesson.com/
Posted on Mar 12, 2011
Where is the breaker for the motor?
There is a thermal overload in the motor that is internal and also resets automatically when the motor cools down. If you are asking about the circuit breaker for the dryer, it is located in your circuit breaker box where you power comes into your house. In the breaker box you will find a 2 pole double breaker that is marked 30 on the breaker lever, and hopefully the electrician has marked the location in the box panel door.
Oct 01, 2015 | Dryers
Where is the thermal shut off fuse located and what does it look like. DV331AEW/Xaa
The thermal fuse is located on the blower housing. You should check out this link to www.repairclinic.com
for a lot more info on this and other possible items that could cause no heat. The link is; http://www.repairclinic.com/Shop-For-Parts/a8b160c44d1067187/Model-DV331AEW-Samsung-Dryer-Fuse-Thermal-Fuse-Breaker-Parts
Good Luck!
Rich Lilja
Dec 03, 2014 | Samsung DV331AEW Dryer
Where is the thermal fuse located on a 110.67032600 kenmore elite oasis dryer
If you are talking about Thermal Switches that turn on and off to regulate the Heating Element, They are in the back of teh machine one is close to teh heating Element and teh other is close to the Exhaust
as the Heating
Aug 29, 2014 | Dryers
Ultimate care ii dryer thermal fuse
Thermal limiters should reset automatically. More likely is a breaker has tripped. turn off the power FULLY and somewhat forcefully, then back on and test again...
Nov 19, 2011 | Dryers
Location of Thermal Circuit Breaker, actually two
located inside the back cover then remove rear access panel to oven cavity and they are there
Sep 28, 2009 | Frigidaire 30" Self-Cleaning Slide-In...
Dometic RM2862 Can you reset the thermo fuse? Current going to it but nothing going out and wouldn't this cause the unit not to work at all?
It probablby has a timer in it. You can reset the timer by turning it clockwise, and the compressor would come on again. It is usualy located under the concoles where the setting button is located. Look for a small hole under that console. If a thermal breaker is making the compressor cut off, it is usually located on the compressor where all the wiring are going in, along with the starting capacitor. Usually if the compressor is overheating and making the thermal breaker go off, there is a problem with the compressor, or it is low on refrigerant. A low refrigerant will make a compressor overheat. Furthermore if the compressor has been being overload by low refrigerant, it will be damaged sooner or later, by overheating the elecmotor inside and causing a short. If resetting the timer don't work and it is indeed the thermal breaker, unplug the machine and get it service, which I hope the compressor is still okay.
Jun 27, 2009 | Dometic RM2852 Refrigerator
Headlight fuse location
Headlights do not have fuses. They have circuit breakers (thermal cutoffs) ususally in the headlight switch. Headlight circuits aren't fused because once the fuse blows, you're out of luck. At least with a self-resetting breaker, when the circuit cools off, you again have light.
May 04, 2009 | Buick Regal Cars & Trucks
Whirlpool dryer model LEB6000PQ0 its not heating up anymore''it starts it turns but the clothes dont dry its only 2 yrs old.
check your breaker first.A dryer will run on 110 but wont heat.if not breaker it could be your thermal fuse or element.the thermal fuse is located on element cage,unplug machine and test for continuity to your thermal cut off fuse which will be the top one on cage and check continuity to element.
Mar 08, 2009 | Whirlpool Dryers
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
