Question about RTO 47cc / 49cc Pocket Dirt Bike Atv Ignition Coil 2-stroke
My pocket bike wont stay running - RTO 47cc / 49cc Pocket Dirt Bike Atv Ignition Coil 2-stroke
Adjust the air screw and idle screw situated on carby.
Posted on May 06, 2011
2 Suggested Answers
SOURCE: my 49cc pocket bike starts but wont stay on when i
That problem has happened to me to and i just ajusted the needle on the side becuase it was too rich or the breather on the gas tank sometimes that gets fratured and the gas fumes cant get out right
Posted on May 15, 2010
Pocket Bike 50 will not start
Hi, Orlando and the usual suspects are:
1. Fuel tank empty.
2. The fuel tank has old dead gas.
3. Fuel tank bottom contaminated with ethanol sludge, dirt, water, rust, etc.
4. Fuel supply valve/petcock turned off.
5. Fouled spark plugs.
6. Engine flooded as a result of overuse of the choke.
7. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
8. Fuel valve/petcock or filter clogged.
9. Fuel line to carburetor or throttle body pinched, kinked or blocked.
10. Carburetor float stuck.
11. Fuel injectors clogged.
12. Fuel injectors stuck open.
13. Quick disconnect check ball stuck.
14. Compression below 75 PSI.
15. A stuck-bent-burnt valve.
16. Severely discharged or a damaged battery should have 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a cursory reading of 12.5 volts or more but little or zero amperage the battery is faulty and must be replaced, AGM batteries fail in this scenario more so than lead-acid batteries.
17. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
18. Loose or corroded wire connection at the coil or plug between ignition sensor and ECM module.
19. Spark plug cables in bad condition and shorting check for spark leakage in the dark, cable connections are loose or connected to the wrong cylinders.
20. Ignition timing incorrect due to a faulty ignition coil, ignition module or MAP, CMP, CKP, O2, TPS, ETP, IAC sensors.
21. Faulty neutral, clutch, kickstand safety switch.
22. Faulty fuel pump or fuse or relay.
23. Faulty or corroded run/stop switch.
24. Tilt sensor needs a reset.
25. Security system not disarming alarm needs a reset.
26. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Common Reasons Why My Pocket Bike Wont Start
Pocket Bike Won Start Help Quick Fix
GB Evolution F1 Pocket Bike Service Manual For Use And Maintenance
Coolster POCKET BIKE QG 40 User Manual
ACU Pocket Bikes Manuals
Dec 28, 2017 | RTO 47cc / 49cc Pocket Dirt Bike Atv...
I have a pocket bike that wont start unless u put gas where the spark plug is and then it will run&idle but once u give it throttle it dies there is no high or low screw there 1 screw &the idle screw
Hi, Anonymous more than likely it's clogged carburetor jets, obstruction in the fuel system or a faulty battery for more information about your question and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
What To Do If Your Pocket Bike Won Start or any 2 stroke engine
Pocket Bike Not Starting
Jun 01, 2016 | Motorcycles
My pocket bike will run as long as I hold down the start botton down when I let it go it dies
Hi, Roy you may have a faulty ignition circuit connector for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. If necessary, transport your bike to the dealer or shop and have a professional technician take it for a test drive, if it is in running condition, and give you a written estimate of repairs and answer any specific questions you may have about your issue. For more information about your issue please visit the website below. Good luck and have a nice day.
Pocket Bike Wont Accelerate Bogs Down Stops dies
Bike will not run after start button released Honda Motorcycles FireBlades...
mini bike wiring diagrams Google Search
http://photobucket.com/images/49cc%20pocket%20bike%20wiring%20diagra
TBolt USA Tech Database TBolt USA LLC
Dec 27, 2015 | Motorcycles
Cagillari pocket bike starts but won't stay on
usually a carburetor problem, bad gas, fuel filter clogged or CHOKE needs to be turned lower soon after starting - move the choke toward "run" slowly until it is warmed up.
Aug 28, 2014 | Motorcycles
Why wont my pocket bike start
chances are the carburetor is set too lean, turn the screw all the way in and then back it out 1 1/4 turns, then adjust in 1/4 turn increments to get it running at peak performance.
May 21, 2014 | Quad 47 cc / 49 cc Pocket Mini Bike...
Wheres the choke on a 49cc pocket rocket
The choke is on the carb. Check if the carb set screw is set right, turn it all the way in and then back out 1 1/4 turns. then fine tune by 1/4 turn increments.
Feb 02, 2012 | Quad 47 cc / 49 cc Pocket Mini Bike...
My pocket bike stops running, and revs by itself
It could be a clog somewhere or he fuel pump. Hope this helps!?
Please rate solution - Thanks.
Apr 20, 2010 | Quad 47 cc / 49 cc Pocket Mini Bike...
My 49cc pocket bike starts but wont stay on when i give it gas?
Feb 20, 2010 | Quad 47 cc / 49 cc Pocket Mini Bike...
110cc pocket bike carberator
That tube would be the overflow tube. Your carb float is sticking open and allowing fuel to flow in constantly. You need to take carb apart, clean needle valve, and inspect or replace carb float.
Apr 21, 2009 | Pit SSR 110CC Pro Beginner Bike
RTO 47cc / 49cc Pocket Dirt Bike Atv Ignition Coil 2-stroke Logo
1,087 people viewed this question
Top RTO Cycling Experts
Michial Gueffroy
Lloyd Carter
Gregg Mahin
Gregg Mahin
Are you a RTO Cycling Expert? Answer questions, earn points and help others
