Question about Car Audio & Video
Hi, our car battery was replaced and when we enter the security code for the radio, it comes on but display is flashing. Radio does not stay on for more than 10 minutes and cuts out again, having to re-enter pin and same thing occurs. Can you help please?
  • tracykay Mar 12, 2011
    Ok, will do, thanks
    Ok, will do, thanks
  • 4,848 Answers
You must be using the wrong code perhaps?
pst the radio make+model plus all the letters+numbers on any labels,barcodes or stamped in the metal case and we`ll see if the correct code can be calculated.
Posted on Mar 12, 2011
My 2001 odyssey radio and gps were working fine...then my belt for ac,alternator shredded..now my radio/gps does not work..when lights are turned on the radio/gps lights around the perimeter,but no display...
Enter the security code in the radio. The code is a 5 digit number and should be written in the owner's manual or on a little label inside the glove box. If it still doesn't work after entering the code,check the fuses.
Feb 25, 2015 | 2001 Honda Odyssey
I have a 2006 Ford Taurus and the radio will not work recently replaced battery alternator and starter any suggestions on what it could be I'm check for radio fuse but cannot find radio fuse everything...
all fuse boxes, there is not just one;
and its marked RADIO.
radio will not work (what does that mean)
100% dead
asking for code
display dead or not
or display works but all stations dead.
what.
if 100%dead it can only be 3 things
1: fuse blow , i bet
2, wire cut to radio (called power B+)
3: the radio is dead, bench test it. ask
Jan 20, 2015 | Ford Cars & Trucks
How do I get my radio to work after I changed my battery. I have the radio code. It is a 2004 Suzuki forenza
Hello there
I found this in a suzuki forum
After connecting the audio security system to the battery, "CODE" will flash on the display.
Enter the proper security number into the unit, using the preset buttons No. 1 through 8.
For example, if the security number is "1234":
Press the preset button No. 1. "CODE" will disappear and "1 --- " will appear on the display.
Press the preset button No. 2, and "12 -- " will appear.
Press the preset button No. 3, and "123- " will appear.
Press the preset button No. 4, and "1234" will appear and flash three times.
The audio system will function and will transfer to the radio. If the incorrect security number is XXXXX into the unit, "Err" will appear followed by "CODE" and there will be several audible beeps. If this happens, repeat the security entering procedure beginning with Step 2.
Hope this helps.
If code doesnt work then it is dealer, sorry.
Sep 24, 2014 | Cars & Trucks
Car stereo flashing display/security code
Try to check the fuses both inside the car and under the hood.
X431 IV with wifi
Nov 12, 2013 | Saab 900 Cars & Trucks
Malibu 2001 radio locked
hi friend,
If you have the security code it's easy. The code is something that either you or a previous owner entered. If you don't have the security code a trip to the dealer will be in your future.
Unlocking the Theft-Deterrent Feature After a Power Loss
Enter the code as follows; pause no more than 15 seconds between steps.
  1. Turn ON the ignition. LOC will appear on the display.
  2. Press MN and 000 will appear on the display.
  3. Press MN again to make the last two digits agree with your code.
  4. Press HR to make the first one or two digits agree with your code.
  5. Press AM-FM after you have confirmed that the code matches the secret code you have written down. The display will show SEC, indicating the radio is now operable and secure.
Entering the incorrect code eight times will cause INOP to appear on the display. Wait an hour with the ignition in the ON position before you try again. When you try again, you will have three more chances (eight tries per chance) to enter the correct code before INOP appears.
Deactivating the Theft-Deterrent Feature Enter the code as follows; pause no more than 15 seconds between steps.
  1. Turn the ignition to ACC or ON.
  2. Turn OFF the radio.
  3. Press the 1 and 4 buttons together. Hold them down until SEC shows on the display.
  4. Press MN and 000 will appear on the display.
  5. Press MN again to make the last two digits agree with your code.
  6. Press HR to make the first one or two digits agree with your code.
  7. Press AM-FM after you have confirmed that the code matches the secret code you have written down. The display will show -- -- --, indicating that the radio is no longer secured.
Entering the incorrect code will cause SEC to appear on the display. The radio will remain secured until the correct code is entered. When battery power is removed and later applied to a secured radio, the radio will not turn on and LOC appears on the display. To unlock a secured radio, refer to "Unlocking the Theft-Deterrent Feature After a Power Loss".
hope this helps u
please rate me..............
thank u for using fixya
regards
sivvaranjini
Nov 26, 2009 | 2001 Chevrolet Malibu
Hi, We replaced our battery on our 2001 chevy
CK THE INTERNET THERE IS A WAY TO UNLOCK YOUR RADIO
Sep 28, 2009 | 2006 Pontiac G6
Hi, problem with 2007 VW Citi Golf radio security code.
The radio is in Lock-Out mode. You only get two attempts to enter the code, then it enters Lock-Out mode.
Put the key in ignition and turn on the radio for an hour (maybe a bit more). The radio should reset itself after about an hour and then you can re enter the code.
Jul 08, 2009 | 2007 Volkswagen Golf
How to retrieve current radio code for my 2004 chevy aveo?
Here's an easier way. Purchase a 9 volt battery powered radio / computer MEMORY RETAINER. Plug into your cigarette lighter/power socket SECURELY. AFTER replaceing the battery, remove 9 volt poer feed, and BINGO. Radio stations memory, clock will all RETAIN. their memory. Hope this helps
Apr 19, 2009 | 2006 Chevrolet Aveo
Radio code
If you don't have the radios security code, you can try entering 1111 as some replacement radios were coded with this security code. Your local Audi Dealer may be able to provide the correct security code for your vehicle, if you provide them with your vehicles Identification Number (VIN). This VIN is typically located on the drivers door pillar.
The radio should have a serial number on the unit which also can be given to the Audi dealer and checked in their data base of radio security codes. The serial number will start with AUZ, one radio serial number for example is AUZ1Z9A1965412.
To enter the code on the Wiesbaden Radio: Turn on the radio, SAFE should be displayed.
Push and hold the AM/FM button, then while holding the AM button down, push and hold down the SCAN button. Release the AM/FM and SCAN buttons, and the display should show 1000. Now enter the correct code using the radio pre-set station buttons (1-4). Button 1 changes the first digit in the code "1"000, Button 2 changes the second digit in the code 1"0"00, button 3 changes the third digit, button 4 changes the last digit in the code. In most cases the first digit is a 1 and won't need to be changed. You push each pre-set station button multiple times to step through the digits (1-9) to get the correct code displayed.
Code 1246 would entered by pushing button "2" two times, pushing button 3 four times, and pushing button 4, six times.
After entering the correct security code, push and hold down the AM/FM button, then while holding down the AM/FM button, push and hold down the SCAN button. The display will then show SAFE, release the two buttons, and now the radio should play correctly.
Sep 19, 2008 | 2001 Audi S4
Car radio pin code
Hi pat... bad news I'm afraid. You need to get the code from Eurovox. There is a way to change/defeat the code, but it involves having the thing apart on the bench and actually fitting a new memory chip to the radio that does not have a code. I used to do this if someone left a unit for repair and we were not left the code. I have cut and pasted the FAQ from Eurovox's site for you, Click the link to their code request form. There are also instructions on how to enter the code
And as always, the bastards charge for the info. Sorry I couldnt actually give you a code. I used to have charge $60 to recode a radio back in the day by rechipping it.
Why is my radio not working after the battery was disconnected/replaced?
The radio requires a security code to be entered. (also known as PIN number). A security code is either 4 or 6 numbers long for most of Eurovox Units.
How can I obtain my security code?
Download the Security Code Request form located in the Downloads section. Fill it out and send it in via fax or email with proof and payment. The serial number & model number of the piece of Eurovox equipment is essential. A new security code card will then be mailed to you and your details will be registered in our database.
Why does Eurovox charge for supplying a security code?
Security and administrative reasons. We enter your details in our database so if you lose it again you only have to identify yourself and give the serial number and we will give you the security code again, we also send you a new code card.
How do I enter my security code to my Eurovox radio/cassette/CD Unit?
Refer to the owner's manual of your equipment. Turn ignition key to 'Accessories' & a number '1' or code '1' or similar will appear. Press corresponding preset buttons as you read you security code. If you have a 6 digit security code, the display will count the preset buttons pressed. i.e. display will show '1' the '2' then '3' & so on up to '6' regardless of which number is pressed. If the security code is correct, the radio will turn on. If the security code is incorrect, the display will show '2' or 'code 2' or similar. After 3 incorrect attempts, the radio will go into 'lockout mode'.
Why has my radio got horizontal lines on the display & is not responding to any buttons?
The radio has had 3 incorrect security codes entered & is now in lockout mode. For recent model radio's leave 1 hour (some radio's require ignition key to be on accessories). For older model radio's, remove power to radio by either unplugging radio or disconnecting the negative lead on the battery for 1 hour.
My radio will not accept my security code?
(1) This radio may have been replaced and now requires a different security code
(2)The security code you have been supplied is wrong.
(3)This radio has an internal fault. To check if radio works there is a temporary test code '1111' or '111111' can be used for most of Eurovox Radio. This only lasts for approx 3 minutes.
How do I enter security code to my overhead DVD/Screen combo unit?
Using the <<or>> buttons on the overhead console, scroll up or down to select the first number. Once the correct number is shown, press the ENT button. Repeat this procedure to enter the 4 digit code. As each digit is entered, it will be shown on the display.
Why does "Code Input Error" appears on my overhead DVD/Screen Combo Unit?
If incorrect codes are entered for more than 3 times, your Eurovox overhead DVD/Screen unit will show "Code Input Error" on the display.
Leave car key in the car and turn it to Accessories for approximated 1 hour, the overhead DVD/Screen unit will reset itself and shows"Security Input 1***" on the display.
Good luck... a FixYa rating would be great for my attention to your problem. Cheers mate
regards
Graeme
Mar 08, 2008 | Car Audio & Video
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
