Question about Ruud UAMB042 Air Conditioner
High pressure contol
I have come home a couple of time and my A/C unit is on and running but blowing hot air. I went outside to check the compressor and the fan on that unit was not spinning. I saw a switch on the bottom of the unit that said High pressure control push to reset, I did that and the unit started running again and cooling but it has happen twice in the last week is there some major going wrong with this unit? it is only 5yr old.
kstfas
  • 75 Answers
SOURCE: High Pressure Shut Down
Hi, If the outside fan is running when this takes place and the condenser is clean, I believe its the High Pressure Control that is bad. There is a possibility that if the unit was opened and air was allowed to get into the refrigerant part on the system that it could cause this problem but unless the system was worked on just prior to this starting, I don't think this would be the case. The part about draining the freon to check the orifice doesn't sound right, This could be done with a pump down by closing the suction line valve at the condensing unit which leaves the freon in the condensing unit. If they charged you to replace the freon, I would question them about this procedure. Hope I have helped. kstfas
Posted on Sep 10, 2007
SOURCE: cooling problems
Inside coil could be undersized. Have a tech check inside coil rating. Sometimes people only change out what they perceive to be bad. Its best to change inside coil nad condenser at the same time
Posted on Jun 23, 2008
SOURCE: Daily reset of outside unit
I have the same unit and was having the same problem. My brother works on A/C's and told me that the coils most likely needed cleaning from the inside out because when they are clogged with a lot of debris the system will overheat and cause that switch to trip and so far it has worked. What you need to do is turn the main breaker off to the outside unit first then take the four screws out of the top of the unit, use a flat head screwdriver and lift the fan it's self up out of the carefully taking caution of the wires going to the fan, then take the garden hose with a spray nozzle and wash the coils from the inside spraying through the coil to the outside and then wash the louvers off of all the debris and this should help.
Posted on Aug 03, 2008
SOURCE: My outside air conditioner fan is not turning, but
if the button your pushing is in the unit outside it is a manual reset for high head pressure this cuts off the unit to protect the compressor,you need to clean the coil .turn the unit off and gently push water through the coil in an up and down motion till water comes out clean see if that helps
Posted on Jun 26, 2009
pilungu
  • 30 Answers
SOURCE: my heat unit will not blow hot air unless we go
If it does not have a furnace or heating elements for heating, then it is a heat pump, which is rare for a central AC system, but makes sense of the fact that it blows warm air when you reset the pressure switch, which may indicates freon pressure charge problem if your AC system has a reverse valve and uses freon to for heating (heat Pump).
Do you get heating when outside unit runs? if you do, check freon pressure levels and top up to required pressures. The button you depress is a pressure reset switch ... that is if your AC system is a heat pump ... which, as pointed above, it is not common for central ACs.
Posted on Nov 07, 2009
Testimonial: "Thank you. My home warranty tech is coming out monday and i want to make sure he checks everything. this will be the 2nd time he has been out."
House a/c compressor runs for a while then shuts off
It could be going out on a high head pressure safety
Jul 04, 2014 | Ruud /rheem R22 /2 Ton/13 Seer Ac...
Location of ac high pressure cutout switch on a 97 Plymouth voyager. Could it be a different problem? Had to replaced the PCM and a couple sensors because of a short in the wiring cluster. Now the ac...
HIGH PRESSURE CUTOFF SWITCH LOCATED ON AC COMPRESSOR DISCHARGE LINE LEADING TO THE CONDENSOR.THE HIGH PRESSURE CUTOFF SWITCH WILL CUT OFF THE AC COMPRESSOR IF SYSTEM PRESSURE RISES TO HIGH CAUSED BY RESTRICTION IN THE REFRIGERANT CIRCUIT OR OVERHEATED CONDENSOR.MAKE SURE COOLING FAN IS RUNNING WHEN THE AC SWITCH IS ON.THE COOLING FAN KEEP CONDENSOR COOL, IF COOLING FAN DONT RUN.YOUR AC WILL STOP BLOWING COLD AIR.HAVE THE REFRIGERANT SYSTEM CHECK OUT.MAKE SURE YOUR LOW SIDE PRESSURE IS 10 - 37 PSI. THE HIGH SIDE PRESSURE SHOULD BE 112 - 210 PSI. CHECK THE AC COMPRESSOR CLUTCH FUSE AND RELAY.
Jul 29, 2011 | Plymouth Voyager Cars & Trucks
My home air conditioning unit comes on with the thermostat and blows cold air when the outside temp is 80 or below/ When the outside temp is hot, above 90 degrees, the unit will not turn on. Any...
Make sure the coils on the outside unit are clean as can be, if any dirt or anything else is blocking the air flow on the coils, take a water hose with a medium stream and work your way from top to bottom, being carefully not to damage the aluminum fins. You can also be over charged on refrigerant which will have the same effect as dirty coils and cause the pressures to get so high, the compressor over works, over heats, and shuts off on thermal overload. It is still possible that it will blow cool air when the temp outside isn't that high, simply because the pressures are further down on the system. I would start there at least, it's easier when your there in person sometimes. Hope this helps anyways, if not, write another question but be sure to explain which components are working, inside and outside, and if the filters have been changed, and if the coils have been cleaned. It just helps to narrow it down. Again, hope this helps and good luck!
Jun 21, 2011 | Heating & Cooling
Suddenly showing "HI" in room temp window. Cold then warm air blows out.
"Hi" means your compressor has gone off on a high temperature limit. Basically, your outdoor coil is dirty and needs to be cleaned or your outdoor fan has stopped working. An air conditioner works off a simple principle of removing heat using a low temperature and low pressure refrigerant. Your compressor does what it is called. It changes that low temperature, low pressure refrigerant into a high temperature and high pressure refrigerant. Your outdoor fan blows over that high pressure gas and it blows out hot air. First thing to check is to turn your unit on, and go outside and feel if you have any air blowing out the back. If you don't, you have a bad fan. If you do, you need to clean your coil. Spray some simple green on your outdoor coil and let it sit for about 15 minutes. Then grab a hose and under low water pressure, wash out your coil from top to bottom pointing the hose in a downward direction. You do not want to point the hose straight into the unit. Make sure you disconnect the power and allow it a couple hours to dry before you plug it back in. If it's just a dirty coil, you should be good to go after that!!
Sep 28, 2010 | Maytag Portable Air Conditioner M6P09S2B
Hot air blowing and fan on unit outside not turning
Is the compressor running? Check the circuit breaker or disconnect that is close to the outside unit if it isn't. It may be tripped on high pressure since the fan isn't running. If the unit has power, use a screw driver or something that will reach the fan blades and spin the fan to make sure it turns freely. If it doesn't the fan is probably bad. Next, check the capacitor for the fan motor. If it looks swollen then it is bad, otherwise check it with a multimeter. Most heating and air suppliers will test it for you. If the capacitor is good, the problem may be you fan motor.
You can check the fan windings with an ohmmeter.
Sep 09, 2010 | Ruud Heating & Cooling
Outside unit will not run. Its happened before and I pushed the high pressure switch and it came on. Now that doesnt work
Usually when the high pressure switch trips its because the outdoor coil is dirty or the outdoor fan isn't running or not at full speed.
A lot of times when it cycles on high pressure the compressor gets hot and trips the thermal overload in the compressor and depending on the outside temperature can take several hours to come back on.
Jan 09, 2010 | Ruud UBHC Air Conditioner
A/C unit compressor shuts off
You will need a technician to check the system pressures with a gauge. Souns like the compressor is fighting high pressure in the coil that is outside.. Try this.Right after the compressor chugs to a stop, un plug unit and run cool garden hose water over the outsife coil for a few minutes, then see if the compressor will start again any sooner yhan before. If so. High pressure is the problem. But you still need a tech to adjust the refrigerant level. Make sure air is blowing out from the coils. You may want to clean the coils before our little test Hose it out with pressure yo remove any buildup on the coil and fins. Spray with 409 if you wish, it would help remove the dirt. Let it drip dry for half an hour and see if the compressor still shuts down. Make sure any water coming from the a/c itself is draining so the fan doesn't throw it around. Good luck Ned
Oct 05, 2009 | Fedders X Chassis A3X05F2B Air Conditioner
PROBLEM WITH MY AIR CONDITIONER
Is the outside unit running? if so can you feel warmer than outside air blowing from outside fan? If not your system may have a leak and pressures low. You can also check the piping to and from the unit larger one should be cold small one should be warm
Jul 03, 2009 | Whirlwind FH-778 Air Conditioner
Blowing hot air, compressor not kicking on, just fan ? ?
are you speaking of the outside fan or inside? compressor should be a little warm but not boiling hot. the unit could be low on freon. if low it will run a while but the compressor will overheat and shut off leaving the fan running by itself ouside. if nothing outside is running check power. if you have power check the contacted outside to make sure it's pulled in. contacters are bad about going out on goodman untis. Also ants can get under contacts.
Jun 11, 2009 | Goodman CKL60AR60 Air Conditioner
Goodman compressor cuts off when temp too high
I believe you have 1 of 2 problems going on here your system may be overcharged causing the compressor to cut out on a overload relay circuit internally, or it also could be tripping out a high pressure switch which could be from an overcharged system or a dirty condenser. I would have the tech come out on a 90 degree day and put the gauges on and check the pressures while it is operating under a full load.
Hope this helps you.
Please rate me
Jul 19, 2008 | Goodman CLQ36AR49 Air Conditioner
Ruud UAMB042 Air Conditioner Logo
63 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
