Can't hook up to a flat screen tv - Audio Players & Recorders
  • 604 Answers
I can only guess as to the nature of your problem, but I'll try. If you're trying to hook up your amplfier and its a 5.1, or 6.1 amp you need to hook up the audio by using the orange output on the flat screen, it may be labeled "coax" or "hd audio out" or surround out, this is the one wire you need to reproduce the surrond sound with left, right, center and rear speakers, and also the sub woofer. The other outputs on your tv will be red and white or red and black, these are the analog audio out and you plug them into your amplifer too, but they won't be 5.1 sound, although your sub woofer will still work. I hope I have helped some.
Posted on Mar 12, 2011
Cable hook up
try to find an new one from here
Nov 05, 2013 | Apex Digital LD1919 19 in. LCD TV
Can i hook pioneer speakers from a system to my lg flat screen
Absolutely! To provide a better solution to your problem, however, you will need to provide model numbers of your TV and surround sound system. Depending on the available hookups and your hardware, you may need a received to make everything compatible.
Feb 13, 2013 | Proscan 32LA30Q Television
I purchased a 46" Sony Bravia flat screen TV. I
Try going into menu input set up on tv and switch to av input. Just a thought I have the same model and had exact problem. All I had to do was change input style to av cable.
Jan 25, 2011 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Have xbox 360....got used,no instruct. book,was hooked to flat screen tv, no longer have flat screen tv, have regular tv hook up game comsole to tv, wont work.....why
If it was hooked to a flat screen it was most likely on high def. There is a switch on the connection to the tv to make it work on a regular defination tv. Just slide the switch over to regular and it should work. Hope this helps.
Sep 12, 2009 | Microsoft Xbox 360 Console
Don't know where to hook cable wire into my W4207-Flat Screen
Nice tv - but its a monitor, so there will NOT be a RG6 cable connection on the set. you have to provide a tuner to get signals OR use a cable box, sat box, etc.
May 04, 2009 | Westinghouse W4207 42 in. HD-Ready LCD TV
How to hook up flat screen monitor??
The new flat screens hook up the same as the old CRT monitors.
May 03, 2009 | Televison & Video
Trying to hook compaq presario laptop to philips lcd digital tv
hey fox,
sounds to me like a connection problem. If the compaqs output is vga, you need to convert the input (tv side ) to hdmi, component, s-vidio... what ever you can find. Typically when you hook up your computer to a flat screen or such, its best to try to use the hdmi ports or the rpg. But if thats not available you need to take the outout from your laptop ( whatever type that might be and input it into your flat screen tv. If you input laptop into tv under ( eg..HDMI) then when you VIEW it you need to select the correct source on your flat screen. Such as hdmi or pcmi or rpg.I know that the do sell alot of cables that adapt from one type of connection to another. Typically only one cable is required from the laptop to the flat screen. If you think about it you are only using the flat screen as a monitor.
Feb 14, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
HOOK UP sATELLITE BOX TO vcr AND pHILLIPS FLAT SCREEN tv
hello. the first thing is to find the in to ant.!! on your vcr.!!! that's where you hook up the out to tv.!!! from the satellitebox.!!! then you hook up the out to to tv .!!! from your vcr.!!! to your flat screen tv .!!! to the in from ant.!! on your flat screen.!!! that should do it for u .!!! let me know if this help's u. GOOD LUCK.!!!
Jun 23, 2008 | Televison & Video
Hooking up game system to flat screen tv
you should have several kinds of inputs options on TV .If you have a surround audio receiver .Simply go direct to receiver on any available input .If using diect to TV , use any available input on TV .More likely VIDEO 1 or 2 (game or camera input)on front or side of flat panel
Nov 29, 2007 | Televison & Video
64 people viewed this question
 Grubhead
Grubhead
