Question about LG Heating & Cooling
Model su/sz/s3 inverter
Has not been used for a while and have cleaned the filters . switched on and dsiplay seems ok except no air (warm) and dsiplay on panel switches to CS only.
any ideads?
2 Suggested Answers
Sea Breeze
  • 4655 Answers
SOURCE: fan not working on LG air conditioner su/sz/s3 model
Bad fan motor and or start capacitor are reasons that I suspect......Sea Breeze
Posted on Jan 31, 2009
Why LG air conditioner su/sz/s3 model C3 error code
C3 isn't a common LG fault code but from what I remember, its a communication error. Possible wiring or outdoor board failure.
Mar 19, 2016 | LG Heating & Cooling
Why does my carina 212 stutters in the morning when cold and runs fine when hot I change the coolant temperature sensor lead wires, distributer, injectors,fuel filter, spark plugs I even check the wires...
Dang... Clean the throttle body/carburetor. Inside of it. Also the idle air control motor. Replace the air filter if dirty. You checked the wire for the coolant senor. Was it less then 5 Ohm's resistance? It is not the ECM or the sensor. Since it works OK after it gets warm. Do you use E85 fuel? Don't when it is below 40 degrees fareinhieght.
Dec 10, 2014 | 1996 Toyota Carina
LG ac remote is not working, batteries have been replaced
Probably the fuse to the indoor unit must replace it. It's on the pcboard and it's from glass. Turn of the power and replace it.
Dec 31, 2013 | Heating & Cooling
My Blomberg 1330A stopped heating. Heating element seems fine, so now looking for the thermal switch...
Test the heating element with a meter for continuity with a meter.
After that follow the wires, one thermal fuse should be neer the heater element the other near the exhuast.
Jan 12, 2013 | Dryers
2004 mercury sable gs just had new plugs and wires since then 1 week the car start to chug after it warms .it chugs for 5-10 seconds then seems to be ok it did it twice today car has 132,000 miles.any...
Should have had the air and fuel filter replaced with the tune up. Also, Noone does this that I know of, Except me, Remove the air induction plenum and clean the Mass Air Flow sensor And clean the throttle bottle and the throttle plates on the back side. Doing these things only will give the car a tune up and better gas mileage. If you clean these yourself, use brake cleaner and do not use a brush on the Mass Air Flow sensor.
Apr 21, 2011 | Mercury Sable Cars & Trucks
Echo CS440 wont idle when warmed up
Check for air leaking at cylinder to block.gasket.
Mar 18, 2009 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Fan not working on LG air conditioner su/sz/s3 model
Jan 31, 2009 | LG Electronic Window Air Conditioner
Panasonic Inverter aircon E24DKR icing up inside unit
Yes, if the filters are clean, the coils are clean, and it is still freezing up in cooling mode, then it is low on refridgerant.
Jan 14, 2009 | Carrier 52PQ307 Wall/Window Air...
Refrigerator not getting any air, (it is warm), freezer seems ok
so you mean the vents in the refer/frezer sections? yes ok there is a fan in the frezer section that moves the air thru out the box.its called the evaporator fan.you should hear a vissssss sound when you open the doors.some boxes you have to push the door switch closed with finger because fan goes off win door open.test fan with volt meter,should get 110 volts[may have to push that door switch in when testing]if voltage and not turning get new fan.hope that helps God bless ,tom
Jan 05, 2009 | Kenmore 50522 / 50524 Side by Side...
Heating & Cooling Logo
254 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
