Question about Car Audio & Video
Eclips 8 band graphic eq need to know the weiring schematics i have a new plug for it and the color r not the same
  • 35 Answers
If you have the old plug just match up the pin locations.
Posted on Mar 12, 2011
How to hook up a 7 band pioneer equalizer great 470 to a Kenwood kr-v6030 receiver
Connecting an Equalizer to a Receiver Before beginning, purchase RCA cables. In order to run the signal from a stereo receiver to the graphic equalizer and then on to the amplifier, two sets of RCA cables are needed. These are basic cables used to connect auxiliary components like record players and CD players. The length of the RCA cables should be about the same length as the distance between the receiver and equalizer.
1. Connect Graphic the Equalizer to the Receiver
The first step in this setup is to connect the graphic equalizer (EQ) to the receiver. Most receivers will have preamp-in and preamp-out connections. Some have tape monitor connections. It's preferable to connect the EQ to the preamp-in or preamp-out because the tape monitor won't allow for connection to the amplifier as well.
2. Connect the RCA Cables
The first set of RCA cables should connect the receiver and equalizer. Connect one pair to the preamp output channels and the other end to the left and right input channels on the EQ. These are on the back side of the equalizer. Usually, the colors will correspond to the RCA plugs. That means connect the red plug to the red jack and the white plug to the white jack. Then connect the second pair of RCA cables between the receiver and the amp. Match the colors in the same way.
3. Connect the Amp to the Receiver
Now the amp can be connected to the receiver via RCA cables in the amp inputs on the receiver. This will create a loop from the receiver through the EQ and amp and back to the receiver so that all three units are connected.
4. Test Graphic Equalizer
Turn on the receiver, amp and equalizer. Once they are powered up, try controlling the sound with the equalizer knobs. They should fine tune the music according to your preferences. It's easy to change the frequency response or tone of the music with the equalizer knobs.
May 09, 2016 | Pioneer Audio Players & Recorders
Need Schematics for Mackie C300 Speaker
Do you have the existing resistor, Larry? Is it crisped up, or can you still read the colored bands? Those colored bands are a color code indicating its resistance - if you can read them off here, we can tell you what its resistance is.
As to wattage... that's something we could at least estimate from size & shape, weighted a little by speaker wattage rating (that resistor should never see as much wattage as the rating).
Last... if we knew for sure what every other component is (from its printed labeling), we could reconstruct the schematic and calculate that resistor's value. Reverse-engineering a crossover designs is far from being rocket surgery. 8)
I offer these as alternative approaches; it may be near-impossible or impossible to get that schematic.
Aug 04, 2014 | Mackie C300Z passive PA speaker (with )
I need data sheet or user manual for my pioneer graphic equaliser
If is a parametric equalizer is zero watts. ,pionner should have a front, rear and subwoofer connections. If i remenber correctly, a single rca going to your stereo and the rest from eq to amp or amps. Hope this helps ,hope you get WIRED.
May 15, 2013 | Pioneer EQ-6500 9-Band Car Equalizer
The Madison Local High School marching band sold gift wrap to earn money for a band trip to Orlando,Florida .The gift wrap in solid colors sold for $4.00 per roll ,and the print gift wrap sold for $6.00...
Ah, word problems! The trick is to convert the given information into two equations in two unknowns. Let's let S be the number of solid color rolls sold, and P be the number of print rolls.
The first equation is easy:
(eq. 1): S + P = 480
We're given that information: the total number of rolls sold. For the second equation, use the given price information ($4/roll for the plain, $6/roll for the print).
(eq. 2): 4S + 6P = 2340
Again, we're given the total sales, and we know how much each kind costs.
Now it's just some basic algebra. Let's rearrange equation 1 to get S by itself:
S = 480 - P
Then use that value in equation 2, and solve for P:
4S + 6P =2340
4(480 - P) + 6P = 2340
1920 - 4P + 6P = 2340
2P = 420
P = 210
Now we know that the MLHS band sold 210 rolls of print paper, which means they sold 270 rolls of solid. You can your answers in the original equations. If they are the right values, both equations will work out.
270 + 210 = 480, eq. 1 is right.
(4 x 270) + (6 X 210) = 1080 + 1260 = 2340, eq. 2 checks.
Dec 13, 2010 | Computers & Internet
I am keyboard player and i want hook up an equalizer to the system where do i hook it up to
If you're only using the keyboard, connect the keyboard output to the EQ input, and EQ output to your amp.
If you have multiple instruments and a mixer, run mixer output to EQ input, EQ output to amp.
More info, let me know.
Charlie
Aug 29, 2009 | DBX 231 Dual Channel 31-Band Graphic Eq
Wiring ID- Pyramid SE808ECHO 200watt amplifier/grapic equalizer
THE UNIT YOU ARE USE HAVE SPEAKER IN AND OUT WIRES LOOK AT THE INSTRUCTION AT THE BACK OF THE EQ AND DECIDE HOW YOU WANNA USE THE EQ
Aug 01, 2009 | Car Audio & Video
Hi I would like to know how to wire up a kam keq 15 dual band graphic equalizer to my home hifi thanks
Either run the main ouptut for your amp to the input of the eq and output of the eq to the main input of your amp OR use one of your tape monitors on your amp. Record on your amp goes to eq input and play on your amp goes to eq output. Hope this helps you.
Jul 29, 2009 | Audio Players & Recorders
Power supply connection for pioneer eq-6500
top left - orange.....goes to aux or memory wire
top right - blue.......goes to the remote wire used with amps
bottom left - black.......goes to the ground wire
bottom right - red........this goes to your hot wire
May 31, 2009 | Pioneer EQ-6500 9-Band Car Equalizer
Install
the eq should have all those connection at the back follow instruction
Mar 29, 2009 | Clarion EQS744 7-Band Car Equalizer
Mackee PPM808M 1200 How to set the equalizer
Each channel strip has its own 3 band EQ with knobs that effect the hi, mid, and low.
The mid is centered at 2.5kHz and gives you 12dB of boost or cut in either direction, the high gives you 15dB of boost or cut from 12kHz and up, while the low gives you 15dB of boost or cut at 80kHz and below. At their mid positions these knobs are flat (no cut or boost).
The PPM808M also has two 9 band graphic EQs in the Master Output Section on the front panel, Monitor EQ and Main EQ. These two EQs are the last thing in the chain before the signal leaves the mixer on either of these line outs (monitor line out, or mixer line out).
The 'Monitor EQ' effects output to the monitor speakers on stage (and power amplifier if the 'Power Amp Routing' switch is pushed in).
The 'Main EQ' effects the signal to the main speakers (or the mixer line out).
Each of these 'Master Output' EQs has a Rumble Reduction button which when pressed in engages a low-cut filter which rolls off frequencies below 75Hz and is designed to prevent 'stage rumble' from things like footsteps on the stage being picked up by stage mics. These filters are separate from the graphic EQs and the Main Rumble Reduction switch effects only mono channels 1-6 (not stereo channels 7&8). It also has no effect on the EFX to MAIN or the TAPE IN. The Monitor Rumble Reduction switch however does effect the EFX to MON signal.
Dec 31, 2007 | Audio Players & Recorders
Car Audio & Video Logo
24 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
