The heater fan is noisy - Heating & Cooling
    Guru:
  • 683 Answers
What kind of heater, little more information please.
Posted on Mar 12, 2011
Why doesn't fan start?
Fan operation should be less noisy after it has been replaced.
Feb 16, 2016 | Reddy Heater-170,000 BTU Kerosene Deluxe
How can I fix My 2006 Honda pilots noisy Ac fan .
You have one of two problems causing a noisy heater fan. The bearing in the fan motor is getting bad or something has fallen down into the heater box ( napkin/paper) and compromising the spinning of the fan cage. You will have to remove the fan assembly and inspect for foreign debris and/or bad fan motor bearing
Sep 06, 2015 | 2006 Honda Pilot
Saturn 2002 heater fan is noisy How can I lube the heate rfan
it will be a case of stripping it down to access it
Mar 02, 2015 | Saturn Vue Cars & Trucks
The heater operation is very noisy compared to new. Perhaps it's the fan? The heater is six years old and I'm concerned that it may cause a fire.
Its most likely the bearings in the fan motor failing causing vibration. One simple way would be too check and make sure all nuts and screws and bolts are tight around th e fan. If so is the fan blade dirty it doesnt take much dirt on a fan blade to get it out of balance and cause bearing failure.
Dec 13, 2010 | Dayton (3UG73) Electric Utility Heater
2005 Sienna AC Heater fan is very noisy
the fan may be loose on its drive shaft and catching the housing
Jul 07, 2010 | 2006 Toyota Sienna
How to fix noisy blower fan squeek for heater/air
Well you can lube the shaft on the squirrel cage fan side,but this requires removal of the fan.If you can get acess to the rear you can drill a small hole.About the size of a WD40 straw .Hole can be drilled anywhere at the far end as long as it is within the little nipple on the end.These are only temp. fixes. If it is not that hard to get to you may want to think about replacement.They are not that expensive around $25-30.Maybe more now it has been years since i have purched one.
Dec 30, 2009 | 2002 Buick LeSabre
Noisy, smelly fan in nutone heater
You should probably replace the heater motor. All the parts should still be available for you fan and it should only take a few minutes to change out.
Dec 07, 2008 | Broan-NuTone Wall Heater
Marvin 5460
Returned to home depot. Fan was broken.
Feb 08, 2008 | Marvin Quartz Radiant Heater
Noisy B&D Ceramic Heater
unit uses a sealed "muffin" fan.  you could check out grainger supply for a replacement fan.
Feb 22, 2007 | Black & Decker BDCH100 Ceramic Compact...
Heating & Cooling Logo
14 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
