My Sony KP53S35 rear projection TV has a very dim picture and I was told that I need to clean the mirrors. Can you tell me how to take apart the TV to get to the mirrors and how to clean them?
  • 604 Answers
Chance are your problem is the projector lamp and not the mirrors. if the tv is 4 years old or more buy a new lamp, they are easy to change. as far as the mirrors go, you have take the back off to get at the mirror but its a lot of work try the lamp first.
Posted on Mar 12, 2011
Do I need to clean the screen on a DLP television? I have only changed the bulb. I feel like the picture is getting less sharp.
Not the screen so much as the projection mirror which is located on the rear wall of the Set. If the mirror gets dull it can make the picture dim and dull looking. Cleaning the mirror will help. Some models have a small mirror which projects the image back onto the rear mirror. Dont use windex, just a damp cloth then dry good.
Jul 21, 2011 | LG Televison & Video
The tv looks too dim. you have to stand right in front of it to see the picture but it still looks dim.
Other than a circuit problem it may be dirt or dust on the lens. The model indicated has 3 picture tubes.
If you unplug set and remove back cover you should be able to see and reach the large black lens dead center and above the circuit boards. If the lens are very dirty the picture will be dark and dull looking.
There is also at inside top back of set a mirror--if it is dusty or has grime on it, same thing--not as easy to get at but with back off you can use a small mirror to examine it.
Clean the lens with a lens cloth or a paper towel with glass cleaner sprayed on the towel.
With back off, 2 minute job and if picture now much brighter, you are in business. Lens, depending on how much dust etc in your area should be cleaned one time a year or more-----do it yourself job and easy.
If this told you something you did not know, rate this solution as very helpful as I do this here for free.
SD TECH
Aug 19, 2010 | Sony KP-43HT20 43" Rear Projection...
How do I clean the mirrors on my sony tv?
You should not attempt to clean the mirrors on the Sony TV because that can damage the picture quality.
Feb 04, 2010 | Sony KP-53S35 53" Rear Projection...
REAR PROJECTION TV SCREEN GETTING HARD TO SEE
Your TV requires service and cleaning of screen, mirror and 3 lenses (of CRTs) as looks dusty.
Below is an exploded view how to take off front beznet assembly of this TV to clean inside with moist cotton cloth.
Unplug TV before taking off front of TV.
Jan 26, 2009 | Sony KP-43HT20 43" Rear Projection...
How can I clean the mirrors on this tv?
to clean the mirrors you must remove the screen first there are several screws in the back to remove the screen. then there is a mirror shaped like a polligon clean this with a dry cloth do not use a paper towel. soft colth must be used on any optical surface. then clean the optical engine lens in the same manner. them the large mirror in the back. remeber if you leave a defect on any of these surfaces it will be amplified by the screen. this system relies on a lamp to provide bright picture so replace that as well. this should be a part of your anual cleaning agreement of the after market warranty you purchased assuming you bought one. dim picture = lamp, fuzzy, dim, dull picture = dust
Feb 10, 2008 | Mitsubishi WD-52725 52". Rear Projection...
UNABLE TO BRIGHTEN PICTURE
Your CRT coolant needs to be changed. Thats whats giving you the dim picture. You can also clean the projection mirror on the inside this often helps. But the coolant will need to be changed to get back the bright crisp picture. Hope this helps.
Jan 20, 2008 | Philips Magnavox 9P6034C 60" Rear...
Sony KP-61HS10 61 in. Rear Projection Television, dirty innerscreen
The important thing here is cleaning the refelective mirror inside you tv .We have noticed in dirty areas the dirt on mirror makes blurry picture.THerefore you have to open back cover and than tp cover to clean mirror and also dont forget to claen c.r.t lenses ,sisnce they are mounted facing upward ,lot of dust sit on c.r.t lens there fore clean 3 of them r.g.b..And you will notice on picture diffrence.
Dec 18, 2007 | Sony KP-61HS10 61" Rear Projection...
try cleaning mirror and lens inside
Dec 16, 2007 | Sony Grand WEGA KDF-50WE655 50" Rear...
Sony KP-53S35 Rear Projection TV
You will need to replace the "HA" board wich is the control panel and remote reciever (wich has failed). Here is a link to the part number and where to purchase from. http://www.partstore.com/Part/Sony/Sony/KP53S35/Sony/Sony/A1372288A/New.aspx
Apr 09, 2007 | Sony KP-53S35 53" Rear Projection...
Picture not clear
When you say the picture is not clear please describe what you mean a little more clearly/ Thanks.
Mar 22, 2007 | Sony KP-51HW40 51" Rear Projection...
Televison & Video Logo
109 people viewed this question
Top Televison & Video Experts
