Question about LG 42LC2D 42 in. LCD HDTV
I have an LG 42PQ30 that is locked and I don't have the code. How do I get this thing back on?
  • 11,361 Answers
Try default code: 7777
Posted on Mar 12, 2011
Testimonial: "That was it! Thanks"
  • 31 Answers
It's seems like your main pcb is acting up I recommend taking it into a service center for a look
Posted on Apr 01, 2011
I have a LG 42 tv that when I press the on switch, it turns green for a few seconds, and then goes red again, any ideas?
Posted on Mar 22, 2011
Power light flashing
Go to www.shopjimmy.com and locate the power supply board for your tv. It's not hard to do if you're not afraid to open the back of your tv.
Jan 08, 2014 | LG 42PQ30 42 in. Plasma TV
LG 42PQ30 plasma tv wont turn on anymore, when you plug the tv in it makes a click noise and when you hit the power button the blue light comes on then changes to red after couple seconds. Note the...
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have to buyand try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.5_15_2012_1_19_09_pm.jpg
May 15, 2012 | LG 42PQ30 42 in. Plasma TV
I have an lg 42pq30 plasma tv the main input board went bad causing no audio.. i replaced the board with same part number .. it now has sound but the picture at the right is off the screen good 20% of...
You must use a usb memory stick to copy data values from the old board to the new board. First you have to put the old board back in, insert the stick then follow prompts to copy register values to the memory stick. Then put the new one back in and load the values back onto the new. I would definitely have a certified tech do this process. You don't want to make a mistake with the old board values.
Feb 18, 2011 | LG 42PQ30 42 in. Plasma TV
I have an lg 42pq30 the main input board lost sound so i replaced it with same part number.. got sound back but the video runs off the right side of screen...any help thanks in advance
you need the set up remote, part number 105-301-m . in start mode press tools button, rt click until your model shows up. the main board is for several size screens. HIT enter when you see your model number.
Please post feedback
I have a problem with my lg 42pq30 plasma, it has vertical lines distortion across the screen. does anyone know how to fix this problem
yes is the 2 top & botton board connect to Y board control is bad need new one
Most problem on plasma TV is heat & burner some component, about 80% is 2 top & bottom board connect to Y board is come in bad
Feb 04, 2011 | LG 42PQ30 42 in. Plasma TV
Lg plasm flat panel tv 42pq30 one month old has vertical pink and green lines that roll from bottom to top any answers.
Your set should be under warranty. This could be a clocking circuit that is out of sync, or some other processing device that is out of frame sync. To service this at board level, if it is not a standard factory known fault to correct, or if it involves extensive SMD work, the board with the fault will be replaced.
Jerry G.
Jan 23, 2010 | LG 42PQ30 42 in. Plasma TV
I need the code to program my sky plus remote to my new lg tv it is an lg 42pq300
press intreactive on sky remote move down to sky costomer service press select then move down to program remote ( 5 ) you will need make ( lg ) and model number of tv then follow on screen instructions
hope this helps
Nov 28, 2009 | LG 42PQ30 42 in. Plasma TV
Need owner's manual for LG 42
You can get the manual on link below. Go to support then look under documents on right side to download manual.
http://www.lge.com/us/tv-audio-video/televisions/LG-plasma-tv-42PQ30.jsp
Nov 25, 2009 | LG 42PQ30 42 in. Plasma TV
LG 42LC2D 42 in. LCD HDTV Logo
279 people viewed this question
Computer Repairing
Computer Repairing
