Question about Acer eMachines Black EL1850G-42w Desktop PC with Intel Celeron E3400 Processor and Windows 7 Home Premium... (884483099900)
My modem blinks off and on , when my pc is idle. Is that normal? and where could I buy a book on info on e-machines? When my monitor goes dark, then my modem starts blinking off and on. My computer is still turned on. When this happens. I just bought my computer 2 days ago. Thank you, Connie
  • 604 Answers
Your modem is always talking to your service even when not connected to your pc it is just showing that it is working. Emachine manuals are a little hard to find, your best bet is to contact the store where you bought it, I know Best Buy used to sell the, they may have a manual, and you could try contacting emachines directly.
Posted on Mar 12, 2011
Testimonial: "THANK YOU FOR YOUR INFO. I AM A SENIOR AND DID NOT GROW UP WITH COMPUTERS. SO I AM TRYING TO LEARN. I JUST WANTED TO KNOW THAT , IT WAS NORMAL."
Hi, my problem is that i can run my pc only in safe mode and if i try to use it in the normal way the monitor tunrs black and the blue light starts blinking, i can't configure it with the resolution...
This usually happens when your computer is set to a resolution that the monitor does not support. I have seen it when I set the resolution too high. That's why windows asks you to confirm the new mode after is switches to a new mode.
I think that in safe mode, you can set your 'normal' resolution. Try setting it to 1024x768 or something. If this helps you can try to find a resolution that works for your monitor. If -after a resolution change- your monitor goes dark: Don't touch the keyboard. Windows should switch back after about 10 seconds.
Jan 02, 2010 | Samsung 2333SW 23" Widescreen DVI LCD...
Monitor went dark
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out, this is the most likely case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site :-
www.lcdparts.net
Sep 25, 2009 | Toshiba Satellite A135-S2386 Notebook
The monitor screen goes dark about 10 minutes
Please verify the power option setting present in 'control pannel' option once. If you have selected to turn off the power supply after 10mins, (once the system is in idle state) then the SMPS will stop supplying power.
thanks.
Jul 20, 2009 | BenQ FP71G 17" LCD Monitor
Toshiba satellite a135 monitor goes black
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
Check out www.lcdparts.net for parts, repair service and DIY info.
May 03, 2009 | Toshiba Satellite A135-S2386 Notebook
The LCD does goes dark after power on
you mean few second the monitor goes in black. then its come. if it happen, it is ok
Jan 21, 2009 | Sony VAIO® VGC-LS37E PC Desktop
Safe Mode is also Black..
I found your other posts regarding this problem. I believe it may be that your monitor is failing. Do you have another monitor to try? Another clincher is to start the computer, do the login, and when the monitor goes dark, turn off it's power button, and turn it back on after waiting for 30 seconds or so. If the monitor lights and looks normal then goes back off, it's the monitor at fault.
Dec 12, 2008 | E-Machines eMachines Desktop PC
Monitor gets a square marked loicked in the middle of the screen. modem blinks on/off. help!
To change your screen saver, right click on the clear area of your desktop and and click on properties. Then, at the top info bar, click on the screen saver button and select a screen saver from the list that you want.
For the blinking light on your modem, it is supposed to blink, and if you want to, you could move it a certain way where you won't see it blinking.
Oct 17, 2008 | E-Machines eMachines Desktop PC
Sony SDM-HS75 tft lcd monitor
I HAVE ONE SONY MONITOR MODEL SDM HS75.
IT IS SHOWING LED BLINKING FAST NO DISPLAY IF CAN ANY BODY HELP ME TO SOLVED MY PROBLUME.
ASHOK MY CELL NO.09322133048
email.ashoksharma4@gmail.com
Mar 02, 2008 | Sony SDM-HS75 17" LCD Monitor
I HAVE A E MACHINE PROVIEW T2240 COMPUTER
This item is part of the Monitor control systeHas the monitor got manual controls usually on the edge or a software box on the computer Switch the Monitor off then on. See what happens
Jun 05, 2007 | E-Machines T2240 PC Desktop
Acer eMachines Black EL1850G-42w Desktop PC with Intel Celeron E3400 Processor and Windows 7 Home Premium... (884483099900) Logo
108 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
