Question about Konica Minolta bizhub C250 All-In-One Laser Printer
Hi, we have Bizhub C280 and is very slow on A3 duplex printing. It took almost 4 hours to print out 750 duplex pages of A3 format! As I see it first prints out one side, then throws out the paper almost in full, then waits few seconds, pulls slowly paper back for first third, then speeds up pulling it back entirely. Then prints out the other side, and after again few seconds it spits out paper, again first third slowly, then speeds up. I understand it reverses paper inside, but it is very, very slow procedure when printing large series. Is there any option to get special DUPLEX TRAY, which would be an empty casette for paper, serving just as temporary port for duplexing? Printer would then print all pages on one side, temporary holding one-side-printed paper in this duplex tray, then it would reverse mechanism, and pull paper from temporary duplex tray and print the other sides. I know I saw such a printer, but I am not sure which vendor. Does Knica Minolta provide such a functionalty for office MFP printers? I mean, under 8000 euro. thanx!
  • 214 Answers
SOURCE: Minolta 2530 DL duplex paper handling
also check that you installed the duplex correctly, that the gears fit into right place. gears are making this sound
Posted on Feb 29, 2008
  • 214 Answers
SOURCE: Duplex Printing
do you have duplex installed ? if you trying to copy duplex originals, you need duplex feeder.. in main displey the left tab is dupleks printing, if you have there options 1 -1; 2-1; 1-2; 2-2 then you have a duplex installed and you can copy/print duplex. also in driver menu there is a option duplex, wath you have to choose if you printing.
Posted on May 11, 2008
  • 11 Answers
SOURCE: Reset Duplex Unit Correctly on Ricoh 2232C
Hi There,
The vertical box on the left side of the machine is not closed all the way. Open it, and close it again. It is directly on the left side of the main machine.
Scott K.
Posted on Jan 31, 2009
SOURCE: Cannot print in duplex
Go to Option, in driver and be sure that the Duplex Option is installed.
Reset your Toners and Imaging units for Minolta Bizhub and CF series.
http://www.chipreset.eu
Posted on Sep 03, 2009
  • 903 Answers
SOURCE: MY Ricoh Aficio 2550 Printer I
The print driver probably does not show that the copier has duplex functionality. If you go into the driver's advanced settings, you can either (depending on the specific driver you have installed) check the option for duplexing to show that it's installed, or click the Update Now button (if there is one) and the PC will automatically detect which options and accessories the copier has.
Posted on Jan 03, 2011
KONICA MINOLTA BIZHUB C250 Printed only magenta
Does the demo page do the same? Mite have image control board failure. And electrical storms on a good surge protector not a Ace hardware 19.99 special, of course nothing against Ace Hardware :). Could also be a High Voltage board failure. Meter count page OK print out.
Apr 19, 2015 | Konica Minolta bizhub C250 All-In-One...
How may i print for Both Side Printing?
Both side printing depends on the printer. It's a feature which require a hardware in the printer known as Duplexer. Which automatically turns the paper and prints on the other side. Some printer may not come with duplexer but if they support duplex printing, you can but the duplexer for the specific printer and attach it at the back of the printer.
If your printer supports duplex printing, when you click on print, click print preferences as shown in the fig 1 below.
Fig1
Click on finishing tab >> put a check on Print on both sides under document optoins section
Click Ok to close the preferences window
Click Ok to send the print job to the printer
Below is the series of images showing how to connect a duplexer.
FIG1
FIG2 - Press the buttons to take out the back cover
FIG3 - Connect the duplexer in the same place
Regards,
Shrey
Jun 04, 2011 | Computers & Internet
Restriction problem under domain environment(bizhub c280)
call your tech services rep, he will tell you in detail what you are asking..........
have a good time,,,,,
May 23, 2010 | Konica Minolta bizhub C250 All-In-One...
When printing duplex A3
If you have the duplexer installed and can use it in the copy mode fine then you probably don't have it installed under you printer setup screen. Just go to printers&faxes in Windows. Double click on the C350. Then click on properties, then upper left should be a configure or advanced tab which lists all the installed options. Make sure that duplex unit is installed and not disabled.
Apr 07, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
We can duplex copy but not duplex print on the KM Bizhub 250. When printing from the computer, in the Konica Document Properties Window on the Layout tab, when the Print Type pull down screen is activated...
Hello
See if you have selected weight paper from the tray in the duplex mode.
Weight paper is selected in duplex mode only from the bypass.
So you check that the paper in the tray 1 or tray 2 must be plain paper and in duplex mode it can print normally.
Jan 29, 2010 | Konica Minolta bizhub 250 All-In-One Laser...
How do I print a two page, single sided, document onto a one page, double sided, document?
go printer driver properties device setting and enable duplexer.
secondly,when u sent print to printer befor sending printing go on properties page and select "duplex"
Oct 30, 2009 | Konica Minolta bizhub C250 All-In-One...
HP lasejet 1320 prints duplicate on front and back when in duplex
Hi I had the same problem on a couple of machines I tried uninstalling and reinstalling but no luck.
Then I changed the Print Processor (printer Properties- Advanced Tab - Print Processor) it was set to HPZPP041 I changed it to Winprint and it worked
Apr 24, 2009 | HP LaserJet 1320 Printer
Duplex printing problem
do you have to replese driver of printer for IR6000
Feb 10, 2009 | Canon imageRUNNER 5000 Copier
Duplex Printing
Apr 25, 2008 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
168 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
