Question about Refrigerators
Kenmore model 106 - Refrigerator too cold , eggs,veggies freezing
Ththere is a tiny hose in the freezer sounds like it maybe blocked .. with a frozen pea or something .. clean out this hose and should help.
Posted on Mar 12, 2011
Kenmore coldspot model #106.74203402 is constantly freezing liquid, meats and eggs in the refrigerator. Any ideas as to why this is occurring?
Most likely cold control thermostat but also check damper that controls air flow between fridge and freezer.
Aug 30, 2017 | Kenmore Refrigerators
Kenmore Model 10654613300 Freezer over freezing
In the freezer side there is a panel in the back. behind the panel are the evaporators. over the evaporators are heaters you will find one of then broken from water dropping on it the bottom one was broken on mine. put a fan to the freezer and thaw it out. get the model and serial numbers and look on ebay.com. or there is a place called http://www.repairclinic.com/
These are not hard to change but above all UNPLUG THE FRIG OR THEY MAY PUT YOU IN ONE.
Hope this helps.
Sep 21, 2014 | Kenmore Elite Side By Side Refrigerator -...
Where do I put cold cuts and meats I don't want to freeze?
Best place for cold cut meats is the bottom drawer in the refrigerator. It's also good for cheeses. That drawer is the coolest but not freeze place. The upper two drawer are good for veggies and fruits. We put the lever controls in the middle selection for them.
Aug 02, 2014 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Calibrate
Kenmore model numbers look like this example=> 321.1234567 can you provide a model number so I know what your model features? Sea Breeze
Jul 25, 2013 | Kenmore Refrigerators
My refrigerator Kenmore model 795 77563600 freezes up the vegies on the left side drawerand werever I store on top of that drawer. What can it's wrong with it?
Your refrigerator as cooling tubes that allows the cold air or the freezer to go to the refrierator side. If one becomes blocked with frost all the cold air is then forced to route through the other cooling tube. And that what it sounds like is happening to you.
Jan 04, 2012 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I have a Kenmore Trio 76504 that the refrigerator keeps freezing products on the back of any shelf or crisper bin
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
Good luck in solving the problem....
May 15, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
The frezzer is freezing up and the icebox is not cold. the fan in the freezer is turning. model 106 74262400 serial ER 2922094 type 22TFA
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 10, 2011 | Kenmore Refrigerators
Everything in my refrigerator is freezing and my ice machine wont work
the cold control and the air deflector
As you know, the deflector directs the freezer air toward the front of the frig and the rear of the cold control.
Hope this helpout.....
Aug 11, 2010 | Kenmore 57029 Side by Side Refrigerator
Refrigerator not cool, freezer ok
Either the freezer continues to freeze up (most likely due to low refrigerant, due to a leak), or there is an obstruction between the freezer and the refrigerator (refrigerators get their cooling from the freezer).
Given that it works after you defrost it, I'm going with low gas. Call a professional to see if the leak can be fixed. If the unit is more than 10 years old, just get a new one.
Aug 22, 2009 | Kenmore Refrigerators
Kenmore Elite 106-74202402 Freezes food ice solid in the fridge
Hi
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
Jun 03, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
128 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
