Question about Dryers
Trying to put a belt on the roper dryer with model number REX5634KQO
    President:
  • 3,074 Answers
Http://www.ehow.com/how_6105563_change-belt-roper-dryer.html
Posted on Mar 12, 2011
  • Dryers Master
  • 8,220 Answers
What type of dryer belt does Roper REX4634KQ take?
The part number is 341241 it could be purchased from your local appliance parts store on online at;
searspartsdirect.com
repairclinic.com
apdepot.com
partselect.com
apwagner.com
Sep 08, 2011 | Roper REX4634KQ Electric Dryer
Cant figure out how dryer belt goes around pully and moter
Go to repairclinic.com and click on the "Get Repair Help" link. Select the "Dryer" category, followed by "Click here for a dryer belt installation diagram". There are numerous illustrations that you can use to assist you with the proper routing of your dryer belt. If the model number is correct, refer to diagram H. I hope this helps you.
Feb 16, 2011 | Roper REK2950W Electric Dryer
I'm trying to figure out where part #3346 goes on a roper REX5634. Pretty simple right? But I can't find it anywhere and no where looks obvious. help! Pleeez
if your part number is correct it would be the idler pulley tensioner for the drum belt and installs right next to the dryer motor inside the units lower area to keep belt tension on the drum belt
Feb 02, 2010 | Roper REX5635E Dryer
Roper drier model rex5634kqo turns but will not heat
Unplug the dryer and remove the rear panel. The element and safety's are on the right hand side. Check each component for continuity. any component that is ope will be the problem. Now here is your basic repair manual for this machine: HERE
I have compiled some repair photos: HERE
Jan 07, 2010 | Dryers
Dryer will heat up but drum will not turn. Unable
Good day,
Sounds like a broken belt, Excellent tutorial on changing the belt on the link below.
Caution: Some models used a very poorly designed belt tensioner. If the tensioner is that style, replace it while purchasing the belt.
Appliance parts house counter men are well aware of the problem. The Roper line is made by whirlpool.
http://www.wikihow.com/Replace-a-Dryer-Belt-on-Whirlpool-Models
Dec 04, 2009 | Roper REX4634KQ Electric Dryer
What is the routing of a dryer belt? It's a Roper dryer model GL6050VLO
To install a new belt and re-install the pulley, follow these steps:
1. Loop the drive belt around the dryer drum with the groove side facing the drum. (Try to line the belt up with the wear marks already on the drum from the previous belt).
2. With the tensioner in your left hand, insert the clip end of the idler pulley into the grooves on the dryer bottom casing with the idler wheel pointing to your left. (The grooves are directly in front of the drive motor.)
3. While holding the tensioner in place, insert the belt UNDER the wheel with your right hand and pull it up and over the drive motor pulley.
If this does not explain it well enough, you can also verify by going to repairclinic.com. Click on the Repair Help link and look for the "Dryer Belt Diagrams" link under the Special Features section on the next page. Look for Whirlpool and refer to diagram H.
You can also refer to pcappliancerepair.com for some excellent exploded view diagrams of your dryer. Just type in your model number as "GL6050VL0" (the last digit is a zero, not the letter O), and go to the "Bulkhead" section.
NOTE: Roper is manufactured by Whirlpool, so these instructions will apply.
If you have questions, or require additional assistance please let me know. I hope you find this information helpful.
Oct 17, 2009 | Dryers
Trying to put a new belt on a roper dryer model number rel4632b
Look at these illustrations. One of them is yours, it will give you the idea...
Sep 03, 2009 | Roper Dryers
Broken belt... won't spin
Real Manufactures part number for the drive belt is 341241. Roper is Manufactured by Whirlpool. If you need further assistance, feel free to stop back and visit us.
Feb 13, 2009 | Roper REX4634KQ Electric Dryer
Roper dryer not working
If the drum will not rotate, look for a broken belt or even possibly a faulty motor. If it is a belt, it should be relatively cheap to repair and possibly easy for you to aquire the specs on the breakdown of the dryer to access the belt for installation. If the belt isn't broken, then the motor is possibly shot and I am unsure of how much ROPER parts are. Be model number and serial number SPECIFIC when ordering parts, and don't go with the "SUGGESTED MATCH" just to save money if you can avoid it, they aren't always compatible.
Mar 14, 2008 | Roper RES7646KQ Electric Dryer
Roper Dryer
i have the same dryer it runs but doesnt heat and the timer wont move. its only 3 yrs old
Nov 28, 2007 | Roper REX3614KW Electric Dryer
Dryers Logo
69 people viewed this question
Top Dryers Experts
