Question about Adcom GFA-5503 3-Channel Amplifier
Can anyone tell me if the Adcom 5503 three channel amp is common ground? I want to use it to power some old school polk SDA 1C as my mains and a CSi5 polk center. Thanks
  • 604 Answers
No reason why not, 3 channel amps used to be the "state of the art" back in the early stereo days. the third channel was produced from the sum of the right and left channels, (the plus side of the right and the plus side of the left were sent to the center channel. produced what was considered at the time a true reproduction of the sound as it was intended to be. your lucky to have this old amp.
Posted on Mar 12, 2011
How do I eliminate buzz?
Things to check:
1. With your multi meter, measure from left ground to right ground. What do you get? Measure from each input ground to chassis. What do you get there.
2. Get or make a pair of shorting plugs. Plug those into the inputs. Power on. Hum there or gone?
3. Turn the pre-amp on. Connect. Level of hum change with preamp on?
4 additional information. How efficient are your speakers? This is a big amp, high-efficiency speakers may show some noise, while low-efficiency speakers won't.
A trip back to the shop may be indicated, too.
Nov 23, 2015 | Adcom GFA-5500 2-Channel Amplifier
Hum sound in one channel
Check cable to that channel for open groumd
Dec 06, 2013 | Adcom GFA-5503 3-Channel Amplifier
Adcom amp 5802 running hot
It should run hot to touch at idle, about 120F, because it is MOSFET type amplifier.
Mar 23, 2013 | Adcom GFA-5802 2-Channel Amplifier
Need service manual for adcom gfa-5503
Adcom still carries service manuals for virtually all their gear. Contact them at 480-607-2277 (Arizona).
Nov 27, 2009 | Adcom GFA-5503 3-Channel Amplifier
Adcom gfa 555 blows the 10 amp fuse and the 6 amp fuse on the far right
Any fuse blowing is caused by a shorted component in either the power supply section or main audio amp part. Follow the fuse circuit and see where it leads you. Look around for burnt of damaged parts. Suspect anything sitting on a heat sink. The most common culprit is the audio amp main transistors, especially if someone shorted the speaker leads together. In the power part it could be the transformer, the large Electrolytic capacitors, rectifier, or voltage regulator. Some amps use an IC for amplification and this can blow the fuse.
Oct 19, 2009 | Adcom GFA-5500 2-Channel Amplifier
Adcom 7500, Adcom 5400(bi-amp), Marantz AV-9000, Dakiom HA103
Try just the power amp on ..nothing connected
no Dakiom thingy either. It's a matter of elimination. Start at the output device and work back. Keep the Dakiom out of the loop.
If there's hum with just the Adcom..then it's the ADCOM
Mar 25, 2009 | Adcom GFA-7500 5-Channel Amplifier
Power button on adcom gfa5503 is stuck in the on position
Hi...
Contact ADCOM through their website. They seems pretty helpful.
The part is probably an off-the-shelf type that snaps into the front panel.
Jan 27, 2009 | Adcom GFA-5503 3-Channel Amplifier
Lots of hum from both speakers
Well folks I solved my problem and the amp has never sounded better. It had always hummed and now it close to stone quiet. The secret was it really never a problem with the amp. The problem was the result of either the pre-amp, interconnect cables, or the combinations of them. The solution came when I added a "drain wire" or ground to the cable I was using. There must have been a ground loop or some in-balance that required a wire to be connected to the earth (-) side at the source on the interconnect and then left unconnected at the other or receiving end of the interconnect. Anyway, no more hum, and the solution took some spare wire and solder.
Nov 17, 2008 | Adcom GFA-5503 3-Channel Amplifier
NEED WIRING DIAGRAM
Hi - You can download the manual from the link underlined in blue below:
GFA-5503
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Aug 28, 2008 | Adcom GFA-5503 3-Channel Amplifier
Adcom GFA-5503 3-Channel Amplifier Logo
170 people viewed this question
Top Adcom Audio Players & Recorders Experts
 Grubhead
Grubhead
Computer Links
Greg Cann
Greg Cann
Are you an Adcom Audio Player and Recorder Expert? Answer questions, earn points and help others
