Question about Western Digital WD Caviar Blue WD800AAJS hard drive 80 GB SATA300 SATA II
What Jumper Setting Do I Need To Use A WD800AAJS As A Slave Drive?
  • 604 Answers
Look closely at the back of the hard drive, in small print it should say where to put the jumpers to make it a slave
Posted on Mar 12, 2011
How do I slave a cd-rom drive in a dimension 1100
Most CD or DVD drives installed in modern computers have a group of short jumper pins on the rear of the drive that determine the master or slave setting for the device. The master or slave setting helps to identify the drive when it shares a connector cable inside the computer with another device, such as a hard drive or even another optical drive. Without the master or slave jumper setting, the computer would not be able to tell one device from another or from which drive to retrieve or write data. Configuring a CD drive as master or slave is a relatively simple task that takes only a couple of minutes.
Turn the CD drive so that you view the rear of the unit, then check the position of the jumper covers on the set of pins next to the power adapter plug. If the CD drive will be the only device on the IDE data ribbon cable, set the jumper cover on the two pins farthest away from the power connector. This position is the master drive setting, and, by default, most CD drives ship with this configuration. In most cases, if the CD drive is the only device connected to the cable, you do not need to change the jumper setting. Determine if you need to change the CD drive jumper setting if the device will share a connector cable with a hard drive or another optical drive. If the CD drive will be the primary (master) device on the cable, do not change the jumper setting. If the CD drive will be the secondary (slave) device on the cable, continue to the next step to change the setting. Use a pair of needle-nosed pliers or your fingers to remove the jumper cover from the CD drive if the unit will be the secondary device on the IDE ribbon cable. Set the cover over the pair of pins next the pair from which you removed it, then press it until it completely covers the pins. The jumper is now in the slave setting position.
Mar 02, 2013 | E-Machines T2892 PC Desktop
NEED JUMPER SETTINGS FOR MASTER HARD DRIVE
Set The Jumper Setting On Your Hard Disk Drive
The hard disk drive will be detected as 32 GB if the jumper is set to the 32 GB clip pin setting. The common jumper settings for Samsung hard disk drives are listed below. Please check the label on your hard disk drive for the correct jumper setting.
Important: Use the alternate jumper setting listed below under General Pin Setting. After changing the jumper, partition and format your hard disk drive.
Configuring your Hard Disk Drive (Master, Slave, or Cable Select) - Setting the Jumper
If this is the only HDD in your computer, set the pin setting to Master.
If this is the second HDD in your computer, set the pin setting to Slave.
If this is the second HDD in your computer, and the first drive is set to Cable Select, set the pin setting to Cable Select.
If you are replacing the HDD in your computer, set the jumper setting to match that of the drive you are replacing.
Cable Select:
This setting is the default setting for PATA/IDE hard disk drives. With the Cable Select jumper setting, the BIOS determines whether a hard disk drive is Set as Master or Set as Slave by it's position on the UDMA cable.
If the hard disk drive jumper is set to Cable Select and is connected to the black connector on the end of the UDMA cable, it is recognized as Set as Master for that PATA controller.
If the hard disk drive jumper is set to Cable Select and is connected to the grey connector on the middle of the UDMA cable, it is recognized as Set as Slave for that PATA controller.
Note: When using Cable Select, your system must meet the following conditions:
Your systems host controller must support Cable Select.
Your hard drives must support Cable Select.
Your cable must support Cable Select.
Set as Master:
Use this setting if you are installing an additional hard disk drive to a single UDMA cable with a hard disk drive Set as Slave, jumper one hard disk drive to Set as Master, and the other to Set as Slave.
Use this setting if you are installing an additional hard disk drive to a single UDMA cable and the Cable Select setting is not recognized.
Set as Slave:
Use this setting if you are installing an additional hard disk drive to a single UDMA cable with a hard disk drive Set as Master, jumper one hard disk drive to Set as Master, and the other to Set as Slave.
32 GB Clip Pin Setting:
Use this on computers manufactured before November 1998 when either you start up your computer and see the message, "Hard disk drive controller failure", or your system stops responding during the boot process after installing a new drive. This occurs when the hard disk drive is too large for the BIOS to support.
If after performing the troubleshooting procedure listed above, the full capacity of your hard disk drive is not recognized, click here for information about obtaining a system BIOS update. If you are unable to update your BIOS, another option would be to create a second partition with the remaining unallocated disk space.
Aug 18, 2012 | Computers & Internet
How connect slave drive dell computer?
I assume you are trying to add a slave drive to a Dell DESKTOP? If so, is it an IDE drive (standard hard drive). To that you will find a jumper plug, usually beside where the cable plugs in but sometimes on the opposite side. The jumper options are usually listed on the drive but what you will need to do is place the jumper plug in the slave slot. You will also need to move the jumper plug on the original hard drive to the master slot. That always seems to work the best for me. However, you can try adding plugging the slave drive into the next open slot on the IDE cable, which is already plugged into the original hard drive. If you get lucky it may automatically recognize the new drive as the slave. You may need to setup/configure the BIOS to set the master and slave drives. To check BIOS setting, hold F2 or F10 when you turn on/boot the PC.
Apr 20, 2012 | Dell Computers & Internet
Is there a jumper setting to run my hitachi 250 gb sata laptop hdd as a slave ?
There should be, look on the rear of the drive, close to the SATA and power connectors, you should see the jumper connections as well.
It varies from drive to drive, but the jumper setting could be engraved near the connector, look of SL for a slave setting.
If no, look on the label on the top of the drive, there should be the jumper settings listed there.
Some may be ambiguous, my last one offered the option of Master on / off. (Jumper in position 1 for on, no jumper for off) The off in this case was of course slave.
The result being, no jumpers - Slave.
Mar 26, 2011 | Hitachi 250GB Hitachi 2.5" SATA Hard Disk...
Can we use Excelstor Gstor as a Slave Drive? If yes, how? What is the jumper setting required?
To configure the hard drive as a slave drive, you need to set a jumper on the hard drive to SL (slave)
The other jumper settings are MA (master) and CS (cable select).
Mar 20, 2011 | Excelstor Technology J880 Hard Drive
What is the jumper pin placement to make a slave of a DiamondMax Plus 9, 80GB hard drive?
The manual is linked below and section 3.3.1 covers jumper settings.
The slave setting shows the park position so you have a jumper on the drive so you can reconfigure it later.
A quick answer is that the slave setting is no jumper at all on the jumper pins.
DiamondMax Plus 9 Manual - DiamondMaxPlus 9.book
Feb 12, 2011 | Maxtor Hard Drive
How do i configure this hard drive for a 'slave' ?
Hello
Ok, you ill be able to see the jumper configuration on the hard drive itself. Here is an example on what the jumper diagram will look like on a hard drive.
Now, all you need to do is to have a look on your hard dive and see where you need to place the jumper for the slave configuration. Here is what a jumper looks like.
After you have done this, you only need to plug the hard drive into your pc.
Hope this can be of help.
Kind regards
Aug 13, 2010 | Quantum Fireball 15 GB ATA-66 Hard Drive
Need IDE jumber settings.
There is a little jumper block on the rear of a DVD. by IDE connector. on the case above there will be a Table marked . Master: Slave: CS. Now, you must set the jumper as to your drive's position. IE: Master or Slave, Master is on the plug at the END of the ribbon, the Slave is on the "Other" one. Accordingly the Master has the Master Jumper ON, the Slave the Slave Jumper ON. CS is Cable Select. It isn't all that used.
Feb 11, 2010 | Plextor 52x32x52 PX-230A Internal CD-RW...
Need jumper setting for slave drive ide
If the drive is the Seagate Baracuda series, then simply remove all the jumpers from 8-pin jumper block and it will be a Slave drive.
If you want any other settings, the jumper settings are described here:
Jan 09, 2010 | Seagate (ST380011A) 80 GB IDE Hard Drive
Western Digital WD Caviar Blue WD800AAJS hard drive 80 GB SATA300 SATA II Logo
846 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
