Question about Toshiba L670-EZ1711 I3-370M 2.40G 4GB500GB DVDRW 17.3 - PSK3BU-011019 PC Notebook
My toshiba L670 Satelite is very very slow, i want to reformat, but if I do how do i get windows 7 back. I dont have a disk because it came installed when i purchased the toshiba. thankyou
  • 26 Answers
Run System In Safe Mode: To identify the root cause of theproblem, first of all restart your system, press and hold F8 key. Do thefollowing once you are on the desktop. 1. Right click on Computer.
2. Select Manage.
3. Click on Event Viewer in computer management.
4. Double click on Application.
5. Check for the errors.
6. Similarly double click on System and check for the errors.
7. Search for the solution to this problem. Now you are able to easily diagnosewhy Windows laptop starts up very slow. b> Limit your Startup list: A long list of programs in startupcan adversely affect the performance of your PC. There are some programsrunning in the background without knowledge of user that causes Windows laptopto start slower. To solve the problem, follow the steps given below. 1. Click on Start button.
2. Type "msconfig" in search option.
3. Double click on the file.
4. Click on Startup.
5. Uncheck all unwanted programs.
6. Close system configuration utility.
7. You are done. b> Uninstall unwanted program: Sometimes Windows laptop starts upvery slow due to unwanted programs hogging your memory. To fix this problem,below are some steps. 1. Click on Start button on thetaskbar.
2. Go to Control Panel.
3. Double click on Add or Remove Programs.
4. In the list of programs, select the program that you no longer needed.
5. Click on Remove button.
6. Repeat step 4 for all unwanted programs.
7. You are done. b> Scan System for Viruses: Windows laptop may start slower due to any virus onyour computer. To solve this problem you should scan your system with somepowerful antivirus program. b> Run Disk Clean Up: Running disk clean up utility isalso helpful to resolve slow Windows start up. To run disk clean up utility,here are the steps given: 1. Click on Start button.
2. Go to All Programs.
3. Click on Accessories.
4. Now click on System tools.
5. Click on Disk clean up. b> Defrag hard disk: 1. Click on Start button.
2. Go to Command Prompt.
3. Type "chkdsk" and press Enter. b> Defrag Registry:You may use some safeprogram such as McAfee secured RegInOut to fix registry related issues
Posted on Jun 16, 2011
    Scholar:
  • 158 Answers
Your toshiba should have a restore partition from factory from there in windows there should be a program to create physical disks for restore so if your harddrive ever totally crashes you should have these disks after replacing the harddrive. Anyhow, reformatting is usually done as a last resort. Have you emptied your temorary internet files? Go ot Internet options in the control panel > Browsing history > delete files. Also, open my computer > right click on the C:/ drive left click properties > tools clean up harddrive here. Also, does your computer have enough ram. Most computers come with just enough to run the OS and a few programs. Go to 18004memory.com scan your sysyetm and they will give you upgrade options . Is your Anti-virus up to date? scan for viruses they will slow down a computer beyond belief! Is your harddrive full? If so, remove some programs you dont use or need, just go to add/remove progrmas in control panel.
Posted on Mar 12, 2011
  • Toshiba Master
  • 3,606 Answers
Try to clean up your system with this program:
http://www.piriform.com/ccleaner
Also the registry.
There is no need to install a new version.
You have to buy a new windows if you want to do that.
I think you have virus or malware.
Try a free antivirus program from here: http://free.avg.com/us-en/download-avg-anti-virus-free
Uninstall the old one before you install the new one.
If it has malware you can remove it for free with this program:
http://www.malwarebytes.org/
Try also microsoft update for the new service pack.
Hope this was helpfull.
    Genius:
  • 1,542 Answers
Hi
It may be worth doing a system restore back to when it was working ok
that way you wont have to spend ages setting it all up again just as you like it
i think you do it this way but please save any pictures or files to a spare drive ist
because you could easlily loose them
start
all programs
maintenance
backup and restore
go down to recover system settings
then click on system restore
then click on choose a different restore point
next
show more restore points
this will hopefully show you several past dates to choose from
click on one of those older one
if you think that your laptop was ok then
and windows will restart and hopefully take it back to the date you choose
its worth having a look in your programs to see if the recovery is built into the hard drive
also look in programs for toshiba recovery disk creator so that you can create a recovery disk
Please remember to save any important pictures or files on a spare hard dive or burn them to a disk
before you do the format as you will loose everything that you have put on your laptop
good luck
  • 604 Answers
Usually toshiba has a recover partition on your hard drive, it might be called "d" drive or something. look in the toshiba file in your programs. If you can't find that, you might try contacting toshiba and asking them for a recovery disk, also one more thing, you can make back up disks of everything on your computer, but that will include all the **** that's making go slow. Your could go to a local computer shop also and get the ovm windows 7 disk. you have the serial number somewhere in your comptuer for th win 7 since it came with the comp. make sure you write it down before you start the install process, you will need it during the install, good luck
  • 35 Answers
Look for a recovery media creator in windows, it's usually under a toshiba folder in the start menu sometimes you have to poke around for it.
You can also do it without the discs because you have a recovery partition on your computer but it is nice to have the discs just in case. When you boot the computer keep hitting the f7 key and this will take you into the recovery manager where you can reinstall windows.
Transfer files from Toshiba Satelite L670-187 laptop to SDcard reader!
Make sure the drive for SD reader is installed.
go to my computer and see if you can see the card if you cannot see the card - right click on my computer and and choose properties next chse hardware then device see if you can see the driver for the SD card (if there is a "!" on that device driver download the driver from the internet (sd card manufacturer)
Apr 17, 2012 | Toshiba Computers & Internet
Toshiba Satelite A150-S4184,Hasent been used much,It was verry fast, now have internet again and loads very slow and takes long time to load pages,I think auto downloads instales windows 7,What can I
How much memory do you have in your Toshiba Satelite laptop?
Windows XP with Service Pack 3 needs a minimum of 1GB but ideally would run better with 2GB.
Windows 7 would need the same but there is no auto-update process to go from XP to 7 as this is not allowed - you would have to do a Custom install of Windows 7 which requires a clean install (i.e. format the hard drive and start from scratch).
If you are running XP with less than 1GB memory, then you need to check what the maximum memory that the laptop can be upgraded to?
The easiest method is to use the Crucial Memory web site System Scanner utility which will detect how much memory is installed and advise how much you can upgrade to according to the options available for the specific make & model of laptop.
If the laptop hasn't been turned on or on-line for a long time then you may be using a lot of resources downloading Microsoft critical updates plus updates for other installed programs like iTunes, QuickTime, Java etc.
Try downloading and installing a copy of the free Advanced System Care 5 utility then running the Deep Care tools which include System Optimisation and clean-up utilities to improve system performance.
Jan 02, 2012 | Toshiba Satellite A105 Notebook
Want to bring it back to factory new
The best way to reset your Laptop to Factory Default is to reformat it. Depending on which version of Windows you have this will create a directory in your Hard Drive called Windows.old, or depending on whether or not you deleted the partition, it will erase everything. You'll want to back up your hard drive if you have anything worth saving.
Beyond that, pop in your recovery disk, or if you don't have it, put in your Windows disk, then restart your computer. When your computer is booting up, head into the BIOS and set your computer to boot from your DVD Drive. If you aren't sure how to do this then reformatting is probably not a good idea. Once you've booted from the disk, just follow the instructions to reformat.
Dec 26, 2010 | Toshiba Satelite 2405-S201 Notebook
Ive lost my password and i cannot log on how do i reformat my toshiba laptop with windows 7 preinstalled
Hey, Here are three methods for you to reset Windows 7 password.
Method one: Logging in Windows 7 with an available adminaccount to recover Win 7 password
Methods two: Creating a password reset disk to recover the Win 7 password, bythis methods, you need create a Windows password reset disk before you havelost or forgotten your Windows admin password.
Method three: Using Windows Password Recovery Basic software to recover Windows 7password.
Nov 14, 2010 | Toshiba Satellite L500 Series Notebook
How do I replace the keyboard?
next to the F1 key and the windows key (2nd upper key and second to last key) are two screws, usually under some covering. unscrew and lift top edge of the keyboard towards the trackpad to lay face down. Undo the wire ribbon by lifting the grey or brown tabs and remove ribbon and keyboard. Then install the new keyboard by inserting the ribbon on the place. Lock down with the tabs and put the plastic prongs (close to the space bar) into the laptop body first, and then close keyboard onto the final position. screw back in and thats all. nboulikas@gmail.com for any additional questions.
Nov 06, 2009 | Toshiba Satellite A105-S4004 Notebook
Toshiba Satelite M100 PC notebook wont start up windows XP
This sounds like a memory problem. Download and run memtest 86, it is a small iso file that you create a bootable cd from. Run this for at least one pass.
If the memory passes boot from your xp disk and choose R to get into the repair console. Once there type the following commands
fixboot
fixmbr
then try the install again. Hope this helps
Apr 29, 2009 | Toshiba Satellite M100 Notebook
Keyboard inoperative
press and hold fn and press f11.it sounds like you activated the sticky keys
Nov 22, 2007 | Toshiba Satellite A135 Notebook
Toshiba L670-EZ1711 I3-370M 2.40G 4GB500GB DVDRW 17.3 - PSK3BU-011019 PC Notebook Logo
468 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
