Question about Maytag MBF 2256 Bottom Freezer Refrigerator
We have a Maytag refrig that is making an unusual sound. It is like a low pitched woodpecker sound that is repetitious every 2 seconds. It happens while the compressor is running or not running. Model MBF2256HEQ S/N 10492751EJ
  • 604 Answers
Its most likely ice build up, if this is a bottom freezer type. It could still be ice on the fan even if its a top freezer or side freezer. that's where I would look first.
Posted on Mar 12, 2011
Testimonial: "We don't have the water hooked up to make ice automatically. The arm to control ice making had dropped down. Great job. "
I noticed an unusual high pitch sound which I traced back to the refrigerator. I then noticed that the front panel lights were flickering on and off and so was the external ice maker lid. I turned the...
Hi and welcome to FixYa, I am Kelly. First off the high pitched sound you heard was most likely ice build up on the evaporator so th evaporator fan blades were striking the ice. Now as for your shutting of the unit and staring right back up..... You need to wait 15 - 20 minutes of OFF time when ever there is a power interruption. What is happening now is that the compressor can not restart because the coolant pressures are to high. That 15 - 20 mins of off time will afford that pressure stabilization time.
What you really need to do is remove the freezer contents and place a fan blowing into the freezer compartment to manually defrost the freezer evaporator. (about 2 hours of floor fan time) This should get rid of the high pitched noise. Then.... restart the unit. It should restart.
I suspect that you have an automatic defrost problem is why you had the noise. The manual defrost will only get you 2 - 3 days of normal operation again before it once again starts the icing routine. I want to get this off now to get you started on the manual defrost. I will respond with a 2nd post about the defrost problem.
Your to do list...
1. unplug the unit.
2. Manual defrost with floor fan (2 hours of fan and water mess)
3. Restart the unit
4. Watch for next post about defrost.
Thanks for choosing FixYa.
Kelly
Dec 09, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
My built in side by side is making a noise about every 30 minutes or so that sounds like a woodpecker pecking on it...about 10 times. It is driving me crazy! Have any idea what this might be?
I have the exact problem with my built0in side-by-side Monogram. 1 yr 3 months old, and it sounds m=like a woodpecker for 3 seconds approximately 1ce/hr. Does not appear related to ice maker. You can create the sound by changing the temp setting on the drawer at the bottom. As you command a lower temp, the sound happens a couple seconds. Actually sounds like a solenoid opening and closing at 60Hz frequency, as though a control board were feeding AC to a DC coil. Any ideas? Fortunately, this fridge has a 2 year warranty, but this should not happen to a $6K dual condenser fridge in just over a year!!
Jan 09, 2010 | GE Monogram® ZISS420DMSS Side by Side...
Dryer squealing?
you need to replace the felt around the door if it is not this it is in the motor and I would just use it tell it dies then replace. thank you for using fixya
Jun 19, 2009 | Maytag MDE308DAYW Electric Dryer
Maytag Performa Bottom Freezer refrigerator making weird noises
This can be due to low supply voltage, causing the compressor thermal overload to trip out. Therefore when this happens the compressor gets hot and it keeps trying to start but fails. It can also be a faulty starter relay, which is located in the conncetion box of the compressor and is very simple to replace.
Mar 20, 2009 | Refrigerators
Works - but the sound has changed
Possibly, the "fault" was the buzzing in the first place! Buzzing is usually a cabinet vibration caused by magnetic fields from the "gubbins". If the buzzing should occur again, try pushing/ pulling/ poking the cabinet while the oven is running, you may find a position that causes the buzz to stop.
Another possibility is you previously had something else placed in close proximity to the oven.
If a rattling cabinet is the problem, either try to reposition something, or just ignore it!
Apr 29, 2008 | Maytag MMV4205 Microwave Oven
GE ZBD6880KOOSS
This is an unusual failure. The humming could be a motor (or valve) that has power but isn't moving. But that doesn't explain the (absence of) lights on the control panel. I suggest you call a professional.
Mar 31, 2008 | GE Monogram® ZBD6880NSS Stainless Steel...
Maytag MBF 2256 Bottom Freezer Refrigerator Logo
300 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
