Question about Sony Audio Players & Recorders
I have a Fisher Stereo Amp Model CA-9025 thats not producing any sound. I have the cabinet off the unit, the unit will turn on, but won't produce any sound. Any other fuses to check or other ideas?
  • Idalia Gonzalez Sep 28, 2012
    Do you by chance know how many watts this Fisher CA-9025 has because I have one and would like to know!!
  • 4,234 Answers
These units use STK amp pac ICs (large black part attached to the rear heatsink). In many cases, this IC is defective. It is possible that there is a problem with the voltage regulator circuit, but that is less likely. This IC needs to be replaced. Expect to pay in the $50 range (or more) for the part.
Dan
Posted on Mar 13, 2011
I would like to find out how to play audio from my panasonic viera tx-40cx400b tv/other devices e.g. xbox one etc through to my Teac A-H300 amplifier.
Having looked at the TV, you will have a lot of problems trying to connect to that amp. The TV has a digital optical out output only. The disc player you mentioned will also be out only. You need a optical "in" for them both. The TV has no analogue out sockets. The only chance you might get any sound out is via the scart socket. If that is fully wired, then the scart might produce L&R analogue out. A scart plug with RCA connections (make certain it has both audio in and out) might produce some sound for the amp.
Otherwise no chance!
The amp you have was not made to work with digital signals. The TV will produce high quality Dolby 5.1 sounds. Assuming you get the scart to produce the sound, then you will only get stereo sound, little better than the TV itself!
I therefore recommend you get a decent digital amp that you connect all your future devices too. One that has HDMI connectors as well as at least two optical inputs.
Onkyo make some excellent models. For example this model would do the job Onkyo TXSR444 Home Cinema Receiver.
Feb 25, 2016 | Teac A-H300 Amplifier
Can I use a 412 guitar cabinet in a vehicle as part of the stereo system at what type of amp what I use to push that
You would want an amp at least the wattage of the speakers, I would go double the wattage, say 800 watts and fuse speaker so as not to blow them. This way you have power to spare if you upgrade.
press the helpful button
INSANE Car Sound Systems
Custom Car Stereo Sound Systems
24 000 WATT Car Sound System PART 1 of 2
How To Design Car Audio System
Jan 23, 2016 | AMP Music
My amp stopped workin, when i turn the stereo on, the green light is on, then when the music starts to play it turns red and stops working,
The red light on amplifier relates to power supply while the green light is indication of sound functionality. An amplifier that allows sound to generate should display both red and green lights. Howeever, some amplifiers would display only green as long as the sound is functioning.
Solving the problem
First, a red light still on means the power connections to the amplifier is fucntional least requirng repairs.
Second, the green ligh should turn on once the stereo were tuned up to produce sound. If the stereo is still on only least produce sound on the amplifier, check on the connection wires between stereo to amplifier that may have disconnected due to woofing or dubbing sound generals with unfirm wiring.
Third,
Jan 28, 2011 | JVC KS-AR7501D Car Amp
When i got the fisher home stereo ca-9025 very little sound
Lets try the simple stuff first. Check to be sure that the tape monitor switch is not engaged. Since youare getting some sound, it appears that the signal path is being interrupted. It is possible that the output transistors have failed (open), but that is extremely rare. Check the tape monitor switch and update this with your results.
Thanks,
Dan
Dec 31, 2009 | Audio Players & Recorders
Fisher Stereo Intergrated Amplifier CA 9025 is stuck on standby
just bought a ca-275 that i cant seen to get any sound to come out of. but im also testing it with car speakers. is this my culprit
Oct 14, 2009 | Fisher Audio Players & Recorders
Fisher ca 9025 amplifier
The amp is in protect mode. Something in the final stage is defective. This is usually caused by shorted output transistors. This unit is worth getting repaired. Expect a parts cost in the $25-$50 range.
Dan
Dec 03, 2008 | Audio Players & Recorders
Kenwood kcd-v6017 no sound
My kenwood X792 has an option to turn the internal amp on or off, having it off (despite having an external amp) produced no audio, since it ONLY produced audio out of the line-outs with the internal amp off.
May 10, 2008 | Car Audio & Video
Earlier; Fisher stacker type unit. stuck in Standby. mode
Hi jamz.
I see this is a pretty ancient posting so you've probably fixed it or given up by now.
I also own a CA-350 Amp which I purchased many years ago here in Auckland NZ.
I've recently had it in bits to fix so if you're still looking for a solution I may be able to offer you some help.
If so, you can contact me at martymarvel@hotmail.com
Oct 25, 2007 | Audio Players & Recorders
For those who accidently put thier CA-9025 in standby mode by hitting the timer button and no longer have the remote, I figured out how to turn them back on.
Turn on the power button and press and hold the Tuner button for at least 10 seconds. it should come back on :) Hope that helps.
May 08, 2007 | Fisher RS920
131 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
