Question about Canon PowerShot A520 Digital Camera
I slip in memory card and turn on camera and get a printout card locked. what do I do
    Scholar:
  • 72 Answers
Most memory cards have a little switch on the side. Make sure it is not in the "Locked" position.
If the switch is not in the locked position, the card may be defective.
If you have had the same problem with other memory cards, then it may be necessary to clean the contacts in the camera with compressed air. You can buy a can at a photo store or major discount store like Walmart.
In the event that this does not solve the problem, the camera will require service.
Posted on Mar 12, 2011
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 102,366 Answers
Take a look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If that doesn't work, try another card.
How can I switch on memory card?
Make sure the memory card in not write protected. There is a small sliding switch on it.
On the camera, go to Settings and look for Save to Camera, Save to SD Card.
Jan 26, 2016 | Kodak EasyShare Cameras
I just got my Nikon D3100 and it wont turn on..why?? i didnt buy a memory card yet..doest it need memory card to turn on??
The battery ships in an uncharged state. Slip the battery into the charger until the it indicates it is fully charged. Install into the camera. The camera should power up without an SD/SDHC/SDXC type memory card installed - and should flash [-E-] in the viewfinder alerting you to the fact that no memory card is inserted.
Sep 06, 2011 | Nikon D3100 Digital Camera
I keep getting "card locked!"
There are several possible causes for "memory card locked", "memory card error", or "no memory card". Troubleshooting steps for this problem are listed here.
Aug 24, 2011 | Canon PowerShot SD960 IS Digital Camera
My hp 635 memory card is locked how do i get it unlocked
I am going to guess that perhaps your memory card is an SD type. These cards have a little switch on the card that can write protect or "lock" it. Take the card out of the camera and check this switch. To unlock it, it should be moved towards the edge of the card which has the electrical contacts.
Nov 18, 2010 | HP Photosmart 635 Digital Camera
My Canon A460 says the Card is locked. The lock switch on the card is set to unlock. I have another camera with a similar card. Both cards work in the other camera. neither card will work in the A460 both...
back up your data first,thenyou reformat the memory card in the camera.i guess you have formatted the memory card in another device.canon cameras generally do not accept cards that have been formatted in another device.then sitch off the camera and reinsert the memory card.
Jun 27, 2010 | Canon PowerShot A75 Digital Camera
This memory card is protected
Sometimes I get 'this memory card is protected warning'. It turned out that the lock on the left upper side of the SD memory card slipped down. The lock is tiny and gray on SanDisk.The lock suppose to be in upper position towards top.
You can download manual for FX-7 from Panasonic.
FX-7 and FX-8 are similar.
http://tinyurl.com/35m35xe
Jun 23, 2010 | Panasonic Lumix DMC-FX8 Digital Camera
I had a canon digital camera my memory card of that camera got locked can u help me to unlock it.
Remove the memory card from the camera if it isn't already, and look along the left edge of the card. Find a small tab and slide it forward (to the unlock position) and carefully slip the card back into the camera and try again. If it reports locked again, carefully remove the card to see if the tab has moved back to the locked position.
If the tab is moving to the locked position during the insertion process, you could place a small amount of tape along the card edge - over the tab - and carefully insert the card again. You might have to remove some tape to allow the card to fit into to slot. If you never locak the card - you could put a very small drop of super glue on the tab to hold it in place. Wait for the glue to set completely before inserting into the camera.
Sep 18, 2009 | Canon PowerShot SD1100 IS Digital Camera
Memory card
If the card is locked, you could the steps below:
- Turn off camera
- Remove memory card
- Take a look on the switch of the memory card itself
* If it's at the TOP = card is UNLOCKED
* If it's at the BOTTOM = card is LOCKED
- So, you just have to make sure that the switch is at the top
for the memory card to be UNLOCKED
After doing that, you just have to put back the memory card to your camera and turn on the camera. Try to check if this works.
Jan 01, 2008 | Samsung Digimax S630 Digital Camera
Unlock card
- Turn off camera
Nov 10, 2007 | Pentax Optio 550 Digital Camera
My PDC 640 digital camera's memory locks up (when I'm using a memory card). What should I do?
The camera memory may "lock" as it reaches its limit. With the camera disconnected from the PC, and on battery power, turn off the camera by closing the lens cover. Remove and reinsert the memory card. Now turn on the camera -- it should power on properly.
Sep 21, 2005 | Polaroid PhotoMax PDC 640 Digital Camera
Canon PowerShot A520 Digital Camera Logo
24 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
