Question about Casio Parts Cash Register PC Desktop
The 1 key is coming up as 5 on the display. how do i fix this?
  • Casio Master
  • 1,572 Answers
If subsequent arithmetic operations treat is as a 5, then look for something like a staple causing a short in the keypad.
Posted on Mar 12, 2011
04trailblazzer won't start driver2 comes up on display
Each key is learned. You must be using an extra key. No code is needed unless your backup key was not learned. Find driver 1 key and start the vehicle and then shut off the truck and within 5 seconds, insert the backup key and start the truck. Your backup key should now be learned.
Oct 12, 2014 | 2004 Chevrolet TrailBlazer
TREADCLIMBER tc5000 error code e5_5
see the steps and fix it. God bless you
Error 5
Description
The power up test sequence has detected a key in the operated condition. The power up test
sequence is performed every time the unit is turned on (powered up). This test is performed
because a permanently stuck key will inhibit the correct operation of the unit.
Possible Causes
1. A key on the display housing is permanently stuck in the operated condition.
2. One of the upper PCA's keypad interface chips has failed.
3. Liquid (perhaps perspiration) is present on the surface of a touch sensitive display.
Possible Remedies
1. Remove the keypad connector cable from the upper PCA. Restart the power up sequence, if
the ERROR 5 is no longer present, the keypad is the cause. The keypad is typically part of
the display housing. Replace the display housing to correct the problem.
2. Remove the keypad connector cable from the upper PCA. Restart the power up sequence, if
the ERROR 5 is still present, the upper PCA is the cause. Replace the upper PCA to correct
Nov 18, 2012 | Exercise & Fitness
Treadmill not working at all
follow the steps and fix it. God bless you
Possible Causes
Possible Remedies
this problem. Most upper PCA's are provided without software. Therefore, the software (chip)
must be removed from the upper PCA being replaced and re-installed on the replacement
upper PCA.
3. Wipe the surface of the touch sensitive display clean of all liquid. Restart the power up
sequence, if the ERROR 5 is no longer present, the liquid was the cause.
Nov 15, 2012 | Exercise & Fitness
How do you write something in scientific notation?
To enter an exponent, use the EE key located just above the 7 key. For example, to enter
1.2 times ten to the 17th power, press 1 . 2 EE 1 7
To set the display to scientific notation, press 2nd [SCI]. To set floating point display, press 2nd [FLO]. To set fixed decimal display, press 2nd [FIX] and the desired number of digits. FLO, SCI, and ENG are on the 4, 5, and 6 keys.
Jan 19, 2011 | Texas Instruments TI-30XA Calculator
I need to fix the calculator to float 5 decimals,apparently it's not floating.
If you want your calculator to display the results with 5 decimal digits:
  1. Open the [MODE] configuration screen.
  2. On first line highlight [NORMAL], if it is not already highlighted and press [ENTER] to validate.
  3. Use Down arrow key once to reach the line Float 0 1 2 3 4 5 6 7 8 9
  4. Use right or left arrow key to highlight the number 5 in the foregoing list (Float 0 1 2 3 4 5 6 7 8 9).
  5. Press ENTER to validate your choice
  6. Press [2nd][Quit] to exit the [MODE] configuration screen.
Mar 14, 2010 | Texas Instruments TI-84 Plus Calculator
JVC HD-52Z575 red screen
The solution is an easy fix. Ignore anyone telling you to take it to a service center or to replace the convergence driver. You need to access the service menu on your television by using your remote control:
DRIVE CONVERGENCE Adjustment (Using remote control)
•Use the inner RGB box pattern.
(1)Set the [SLEEP TIMER] key to 0 min.
(2)Press the [DISPLAY] key and the [VIDEO STATUS]key simultaneously.
(3)Press the [9] key to display the RGB box pattern.
(4)Select the R mode by pressing the [DISPLAY] key.
(5)Adjust the R mode to setting as same as G mode bypressing the [CH ]+ / [CH -] key.
(6)Select the B mode pressing by the [DISPLAY] key.
(7)Adjust the B mode to setting as same as G mode bypressing the [VOL] - / [VOL +] key.
(8)Check to see that the cross pattern is white. If thecross pattern is not white, readjust (5) to (6).
That's it, your color is now corrected. Yes, I know...your welcome.
Feb 20, 2010 | JVC HD-52Z575 52" Rear Projection...
I am setting up a new Dell with Windows Premium. When I use WORD 2000, there are 5 keys on the keyboard that do not produce the character on the key. When I call Dell, they say they will charge me $129 to...
If those 5 keys produce "other" graphics, then look on your keyboard for the 'ALT GR' key, just to the right of the space-bar.
Hold-down the ALT-GR key.
Press one of those 5 keys.
Release the ALT-GR key.
What graphic is displayed?
Jan 20, 2010 | Dell 0Y3740 Keyboard
ON SWITCHING ON THE COPIER KONICA 2020 ERROR CODE F35 DISPLAYS PROMPTLY
How to clear fuser abnormality codes (F34, F35, F36), 2020.
Solution:
To reset fuser codes, perform the following steps:
1. Access the 25 mode (power the machine OFF. Hold down the 2 and 5 keys, and power the machine ON).
2. Press P-4-7-P on the key pad. (1, 4, 5, or 6 will be displayed on the copy quantity indicator).
3. Press the 0 key to change the indication to a zero.
4. Press the start/print key to enter the new data.
5. Power the machine OFF then ON to exit the 25 mode.
If the code comes back then your fusing unit will need parts/service.
Dec 14, 2009 | Office Equipment & Supplies
How to make the screen darker if fn keys don't work?
Hai,
1. Attach the connector lead of the monitor to your laptop
2. So you don't see the display? :D
3. The laptop has an Function key (Fn key next to the windows start key) on the keyboard. Press and hold the key, and hit the F5 or F8 key or that F key which has the monitor icon on it (it is F5 on toshiba and F8 on dell).
4. This should fix it.
5. Sometimes a high resolution to an extended screen can also be a cause of non-display. Just reduce the resolution of your new (additional) monitor to 800X600 and that must fix it.
6. If these two still don't fix, then your next bet is re-installing your display device drivers.
Hope this Helped!
Good luck!!
Aug 26, 2009 | Microsoft Windows Vista Ultimate Edition
Minolta Di183 display shows 88
1 Call the Utility Mode to the Display.
❍ Calling the Utility Mode to the Display (p.7-1)
2 Making sure that “U--” appears on
the Display, enter “5” from the 10-
Key Pad.
3 Press the [Start] key.
Enter the 6-digit administrator
number from the 10-Key Pad.
? Do you know how to enter the
administrator number?
➜ Enter the six digits successively.
? Do you want to correct a wrong
number just entered?
➜ Press the [Clear] key and then
enter the correct number.
5 Press the [Start] key.
6 Check that “Ad-” appears on the
Display.
7
Enter the code assigned to the
desired subfunction from the 10-
Key Pad.
? Do you know the code for Copy
Track?
➜ To select Copy Track, enter “1.”
? Do you know the code for Disable Auto Shut OFF?
➜ To select Disable Auto Shut OFF, enter “2.”
8 Press the [Start] key.
GO to Konicaminolta US website down load a operators manual free
Jan 26, 2009 | Minolta DiALTA Di183 Copier
Casio Parts Cash Register PC Desktop Logo
32 people viewed this question
Top Casio Retail Supplies Experts
Electroboy
Electroboy
tomferryman
Level 1 Expert
Are you a Casio Retail Supply Expert? Answer questions, earn points and help others
