Question about Tappan TGF657 Gas Kitchen Range
Oven shuts off
Is there a recall on this Tappan range? I am exasperated; we have replaced the electronic control three times in the last six years and the clock still blinks off and on occasionally and the oven shuts itself off. Totally frustrated and would never buy this oven again.
Thanks
  • Gee Dee
    Gee Dee Oct 18, 2013
    My Tappan 36" gas range, model TGF657BFW2, does the same thing. Three brain replacements, and no luck. It still shuts down randomly. At first I had a problem with the electronic igniter, which was replaced under warranty. That unit was partially melted. Located on the back of the stove under a shield. I keep wondering if this is shorting something out. The oven will restart for me, and I reset the clock. I would not recommend this brand either!! First time it happened... 20 people were waiting for Thanksgiving turkey :(
  • 750 Answers
AstrosandiWelcome to fixya.
I'm Huuum and happy to assist you,
you asked , Is there a recall on this Tappan range? You are exasperated; you have replaced the electronic control three times in the last six years and the clock still blinks off and on occasionally and the oven shuts itself off. Totally frustrated and would never buy this oven again.
What is the model number?
How old is the range?
Don't put good money into bad!
You need to shop quality and not price!
Here is an interesting report I just read!
Repair or replace?
When to pull the plug on your old range
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your range,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your range is under warranty or less than four years old ,
paying for a repair makes sense.
Note that ranges under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your ranger is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new range.
Data also shows that it doesn't pay to fix a less-expensive range
eight or more years old.
Thanks to better recycling programs, less than 10 percent
of ranges you replace are likely to end up in a landfill.
Thanks for giving me the opportunity to help!
Please do not for get to give a rating before you sign off!
Repair or replace?
Please remember to give a rating before you sign off!
Posted on Sep 24, 2008
Hi i own a tappan tgf328 gas range and I'm trying to heat up the oven and its beeping and giving me an F31 code. Can you help me?
Tamppan Range/Stove/Oven Fault Codes
Failure
Code
Condition Check/Repair F0 & F1 EOC (Electronic Oven Control) failure Replace Electronic Oven Control F2 Oven too hot Check Bake function, if OK, replace oven temperature sensor F3 Oven temperature sensor open Check oven temperature sensor, should be ~1100 ohms at room temperature. If too high or low, replace oven temperature sensor F4 Oven temperature sensor shorted Replace oven temperature sensor F5, 6, 7 EOC (Electronic Oven Control) failure Replace Electronic Oven Control F8 Lock switches Check switches and replace if necessary
Apr 07, 2011 | Tappan TGF320 Gas Kitchen Range
I'm showing the code F2 and the alarm is sounding.. What's wrong?
Hi mrbright84,
F2 error code description is an electronic oven control failure. Please replace Replace electronic oven control (also called EOC or clock).
Hope it helps.
Thank you for using FixYa.
Aug 12, 2010 | Tappan TGF320 Gas Kitchen Range
I am showing the code of F5 on my self cleaning oven and the alarm is sounding
Hello there:
On these tappan ovens the f-5 or even the f-6 & even the f-7 can show up meaning you have a bad electronic controle board that needs to be replaced normally this will cost about 40 dollars for the part
Jul 14, 2010 | Tappan TGF320 Gas Kitchen Range
My Tappan electric range oven wouldnt shut off tonight after baking dinner. Instead, it flashed ''F1'' in the digital screen, and would not allow cancel to work. What could be wrong? It is a Tappan Dual...
The EOC electronic oven control/clock has failed. This is easy to replace. Go to www.appliancehelponline.com and enter your model # for diagrams and illustrations. All parts come with installation instructions.
Apr 09, 2010 | Kitchen Ranges
When using the self cleaning I get an F6 response. What should I do to correct this??
Hi rippster129,
Err0r F6 is an electronic oven control failure. You need to replace the electronic oven control (also called EOC or clock).
Hope it helps.
Oct 28, 2009 | Tappan TGF320 Gas Kitchen Range
Our electric tappan dual radiant baking and roasting oven is beeping and giving an f1 message
Hi gracie7773,
The F1 error code description is an electronic oven control failure. To fix this error, you need to replace electronic oven control (also called EOC or clock).
Hope it helps.
Aug 02, 2009 | Tappan TGF320 Gas Kitchen Range
Tappan Millennia Electric Oven #316065306---"F1 comes up on digital clock and oven is beeping".
Hi rich750,
The F1 error code description is an electronic oven control failure. The easiest way to fix this error is to replace electronic oven control (also called EOC or clock).
Hope it helps.
Jul 30, 2009 | Tappan TGF320 Gas Kitchen Range
Tappen gas 4 burner about 10 years old with about 10 hrs total use time(basement stove)
Hi Carlsr,
Hope it helps.
Apr 13, 2008 | Tappan TGF320 Gas Kitchen Range
F1 and F2
Here are the codes for Tappan ranges:
TAPPAN
Range/Stove/Oven Fault Codes Failure
Code
Nov 06, 2007 | Tappan TGF363 Gas Kitchen Range
Tappan TGF657 Gas Kitchen Range Logo
213 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Sal De
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
