Question about Avanti WC5100BG Wine Cooler
My Avanti WC5100BG is making a horrible noise, think it's the compressor. Do bad compressors make growling noise? What to do, what to do?
4 Suggested Answers
MNfisherman
  • 11896 Answers
SOURCE: Bad capacitor/relay or compressor?
that is most likely a relay. Does the unit get cold while running?
Posted on Oct 23, 2009
Testimonial: "Thank you for your quick reply. Keeping fingers crossed it's only the relay."
  • 744 Answers
SOURCE: Making loud noise when compressor kicks on.
Does the unit cool? See the comments below:
These domestic refrigerators do not have charging valves. They are charged at the factory and then a "process tube" is pinched off and soldered. If you do have a leak somewhere around the compressor area, you may see an oil and dirt buildup on a line somewhere. Another cause of refrigerant loss can be if someone tried to scrape ice off the freezer evaporator using a metallic scraper and possibly punctured the evaporator.
The noise you are hearing may be the internal compressor mounts inside the hermetic compressor case. There is no way to repair this other than to replace the compressor, at which time you could add service valves if you wish.
Also check to see if the external mounts for the compressor are loose, out of place or if any of the retaining clips have broken or otherwise come loose.
If the unit is older, it may not be worth the cost of the repairs.
Posted on Jan 02, 2010
Sea Breeze
  • 4654 Answers
SOURCE: Where can a I find
You don't really need the exact parts. Supco sells a RO81_1-12th HP to 1-5thHP that just slips on the compressor S,R and Common pins.
sea_breeze_218.jpgDistributor Locator
I would choose their parts over any OEM hard to find parts because they are simple and dependable, Thanks Sea Breeze
If helpful please Rate this solution.
Posted on Jul 15, 2011
Avanti 308ywt compressor keeps running but frig will not get cold
Nataly if there is not any cold air anywhere and compressor is running that indicates a Freon leak and worth very little due to repair cost. You must be sure that compressor is running not the fan noise
Appliance 911 Sea Breeze
Nov 12, 2015 | Avanti Refrigerators
Air compressor noise
Most likely going to be a bad compressor, the compressor most likely has internal failure.
Sep 18, 2013 | Toyota Avalon Cars & Trucks
Compressor problem
is the sub is distorting then the "compressor" or voice coil will make horrible noises. Turning down the settings on the amp that is powering the sub will help decrees the noise.
Aug 20, 2012 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
I just bot a 1997 monte carlo 6cyl dohc and it has been making this horrible noise..dealership says it is a ac compressor .. can i just unplug this ac compressor so the noise will stop?
well, yes, if the issue is inside the compressor. If it is the compresser pulley, unplugging it will not help.
The compressor is needed for defrost and defog, as well as a/c.
Mar 10, 2010 | 1997 Chevrolet Monte Carlo
I have an Avanti outdoor refrigerator. It's about
Try to place on flat ground surface, u can balance its weight. Check compressor fan if its making noise.
Nov 05, 2009 | Avanti BCA5102 Stainless Steel Compact...
When I turn on the air conditioner after a few seconds it starts making a horrible noise....it works when the noise is not there, but once the noise starts the it doesn't blow as strong.
Usually you get a horrible noise,once the compressor starts...May be the instant the compressor starts the voltage drops down and so it doesnt blow as strong as you expect... If u expect a comparitively heavy blow then adjust the thermostat to 20 degree celsius...Try this,I hope this works out...
Jul 11, 2009 | 1998 Oldsmobile Intrigue
There is a low pitched growling noise coming from the ac compressor of my 2004 grand caravan when engaged at idle. Compressor, belt, have already been replaced twice. Any thoughts?
Are you sure the noise is coming from the compressor and not the belt tensioner or other accessories, when you turn the ac on it put more of a load on the engine. If not since the compressor was changed twice was it properly oiled and the clutch turned manually to insure proper lubrication. I am hoping if it is the compressor that the reciever dryer and expansion valve was changed and the ac system was flushed well, to insure no contamination, or blockage damaging the new compressor.
Jul 08, 2009 | 2005 Dodge Caravan
Avanti WC5100BG Wine Cooler Logo
57 people viewed this question
Top Avanti Refrigerators Experts
John Tripp
John Tripp
john h
Are you an Avanti Refrigerator Expert? Answer questions, earn points and help others
