Question about Amana ASD2628HE Side by Side Refrigerator
Amana asd2627kes refrig water dispenser very slow new filter installed\r\nalso using bypass no change in flow
catriver
  • 878 Answers
SOURCE: No ice or water from dispenser
Kathryn, make sure you do not have the dispenser locked out. Press and hold the lock button for 3 seconds. If you have a green light above the pad this indicates lock. You are going to have to hold the water lever for a while until all the air in the new filter is purged. Catriver...post back.
Posted on Nov 12, 2006
  • 87 Answers
SOURCE: Amana fridge water filter squealing
I would suggest that you put the new water filter back in and try dispensing water for about ten minutes. If there is still a high pitched noise then you could try bleeding the water line at different points along the water circuit (with control over the incoming supply). The fact that you are forcing water through the tank should normally resolve any air locks. The water filter could also be bled of air. Hope this is of some help.
Posted on Sep 06, 2007
  • 219 Answers
SOURCE: amana fridge water dispenser real slow
u m,ay have to change the filter tubing as well
Posted on Mar 19, 2009
farfield
  • 462 Answers
SOURCE: water from dispenser slows down while filling cup
If your water is slowing down the screen on the water valve may be stopped up or the filter (if it has one, when was it last changed?) or line feeding the refrigerator may be stopped up or the water valve its self may not be opening all the way and staying open.
To eliminate 3 of the external problems take the water line off the fridge and run some water into a pan and open and close water like at your kitchen sink and see if the water slows or speeds up noticeably while running into the pan. If so the problem is in the water line. While you have thew line off remove and inspect the water inlet valve screen and replace the hose washer (if so equipped) this brings your problem if you have not found it yet to the inside of the fridge. Usually on the corner of the door hinge the water line makes a turn up to the dispenser inspect it there and see if its twisted or kinked. Also there is a water resiviour inside the fridge look there for the same thing and possibley where food may have been forced agianst the line.
If you still dont find it by now I'D have to know what you did find and where.
If this helps you please rate me with as high a rating as you can and thank you for using fix ya.
Posted on Apr 20, 2009
  • 103 Answers
SOURCE: Amana Refridgerator won't dispense water or make ice.
  • Hi: You did your homework and checked everything. You said you checked the water flow to the refrigerator, and it was fine. Although what you described sounds like no or low water flow to the solenoid. I'm referring to the valve the water line is connected to. When they "rattle" it means there is not enough or no water pressure keep them open. These valves usually have a gravel filter. As you say it's a scratch and dent. The filter may clogged with gravel, or mildew (as it sat unused as a scratch and dent for who knows how long.) You sound handy. Before I replace that valve I would remove it and look where the inlet water is attached. Usually there is a screen behind a cap you will have to unscrew the size of an garden hose cap. See if there is a screen that can be cleaned. I'll lind the Sears parts direct page to you with the part no. #10 on the diagram. http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=AFD2535DEB&productCategoryId=0161000&brandId=1268&modelName=AMANA-REFRIGERATOR&diagramPageId=00012&componentDescription=CABINET BACK&documentId=M0705005&backToLink=Return to Sub Components list The clogged screen would make the valve vibrate like you described. I hope this helps, Jeff
Posted on Jun 26, 2009
Need to find water filter on my amana model scd23vw refrig.
Install Water Filtration Cartridge (some
models)
a. Remove bypass cartridge from water filter head in rear
right corner of refrigerator section. Twist cartridge
counterclockwise 1/4 turn and pull down to remove.
Save bypass for use at a later date.
b. See Water Filtration System Installation and
Operating Instructions provided with water filter
cartridge for filter installation and operation.
Aug 16, 2010 | Amana Refrigerators
Want to know when and how to replace water filter on a ge side by side refrig
The water filter status light or indicator, present on some models, will help you know when to change your water filter. The light, or indicator, is located either on the temperature control panel in the refrigerator compartment or on the dispenser control panel on the freezer door.
The indicator will be one of two styles.
If the indicator is a light or series of lights, the light will change from green to yellow. This tells you that it is almost time to change the filter. It is recommended that you replace the filter when the status light changes to red or when water flow to your water dispenser or ice maker noticeably decreases.
If the indicator resembles a stack of bars, the bar height will decrease and the status display will change from "Good" to "Order." This tells you that it is almost time to change the filter. Replace the water filter cartridge when the water filter status display changes to "Replace" or when water flow to your water dispenser or ice maker noticeably decreases.
If a filter status light/indicator is not present, the filter should be changed at least once every 6 months. Your filter may need to be replaced more frequently depending on your usage and water quality.
If the water flow to the water dispenser or ice maker noticeably decreases before 6 months have passed, you may need to replace the water filter cartridge more often. Decreased water flow is a sign that the filter is clogged and needs to be replaced.
If the filter is clogged and you are not able to immediately replace it, remove the filter so the water system is in bypass mode. With the filter removed, the water system will continue to operate, bypassing the filter, and the clogged filter will not cause slow water dispensing or low ice production. However, in order to have filtered water, you will need to install a new filter.
The filter status display will help you know when to change your
water filter. When the display reads 10%, order a new filter. It is
recommended that you replace the filter when the display reads 10% OR when water flow to your water dispenser or ice maker decreases.
The filter should be replaced at least every 6 months depending on your water quality and usage.
Step 2
Press the eject button to release the filter from the base grille.
Step 3
Pull the filter straight out.
Step 4
Turn the cap counterclockwise to remove it from the filter. IMPORTANT: Do not discard the cap. It is part of your refrigerator. Keep the cap to use with the replacement filter.
Step 5
Align the ridge on the cap with the arrow on the new filter and
turn the cap until it snaps into place.
Step 6
Remove the protective covers from the O-rings. Be sure the O-rings are still in place after the covers are removed.
Step 7
Push the filter into the base grille. The eject button will pop back out when the filter is fully engaged.
Step 8
Flush the water system. Use a sturdy cup or glass. Depress and hold the
water dispenser lever for 5 seconds, then release it for 5 seconds. Repeat this process until water begins to flow. Once water begins to flow, continue depressing and releasing the dispenser lever. Hold down for 5 seconds and then release for 5 seconds. Do this on/off process for about 2 minutes. This will flush air from the filter and water dispensing
Hope this helpout in changing the water filter......
Aug 10, 2010 | GE Refrigerators
Slow water flow from water dispenser
Check water supply make sure you have ample water and not a kinked connection from supply. It is a common failure on Amana to have a defective Filter/Head assembly.
Mar 28, 2010 | Amana 22.6 cu. ft. Side-By-Side...
The water flow on my side by side, water & ice dispenser in the freezer door, keeps decreasing. Model GSS25UFPD CC. Is there some way to increase the water flow?
I would install the filter bypass ( the piece which came with the refrig ) to see if that will improve the water outflow . If so , then replace the filter . If not , you will need to replace the water valve . Pt # WR57X10032 . This part runs about $ 40 , and is the part that the wall water line connects to on the back of the refrig .
Nov 22, 2009 | GE Refrigerators
No flow after filter change.
G E waterfilters , can be bad when new (all , not just G E ). Put your old one back in , if water flow was fine , and you replaced just because the light came on . Or , use the plastic bypass piece , which came with the refrig , when new . The replace light , works off time and/or usage times only . If you have good water flow and the cubes are normal size , don't change the filter when the light comes on , just reset the light . All "filter" companies , have found the way to sell more filters , the light on dispensors .
Sep 11, 2009 | GE Refrigerators
The water dispenser is not working properly. There is water coming out, but at a reduced amount than before. The filter is new so it is not that. What could be the reason?
Put your old filter back on or the filter bypass piece that came with refrig .I have found several new filters which lowered the water output when installed . I would not replace the filter when the little lite says to . Only when the water flow rate decreases .
Jul 28, 2009 | GE Refrigerators
GE WATER DISPENSER RUNS SLOW AND GIVE WARM WATER
With the refrig , you should have gotten a small bypass piece which fits in place of the inside filter . Install this to see if the filter is good or not . Water faster , replace filter , still slow , possible water valve problem . Also use a connector usually a 1/4 x 1/4 compression fitting , to bypass the outside filter for test purposes only .
Jul 19, 2009 | GE Refrigerators
About a week ago, ice making slowed way down.
changed the water filter. cost $43 for a new one. crazy.
Jun 17, 2009 | Aspen Refrigerators
Water dispenser is just a trickle
the biggest culprit for slow water dispensing aside from the filter is the water supply its self. check to make sure the water line isnt kinked behind the refrig, if thats ok then disconnect the water line from the refrig and run water into a bucket and observe your water flow. good water pressure would basicly fill a 2 gallon bucket in less than a minute. much less than that can cause problems. hope that helps peyton
Jan 29, 2009 | KitchenAid KSRA25CNSS Side by Side...
Amana ASD2628HE Side by Side Refrigerator Logo
61 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
