Question about Panasonic PT-AX100U-EC DLP Projector
Why does the projector keep going to standby mode?
    Genius:
  • 1,114 Answers
If the lamp usage time has passed 2 000 hours (when LAMP POWER has been set to NORMAL), the projector will switch to standby mode after approximately 10 minutes of operation. The resetting procedure should thus be completed within 10 minutes.
1. Insert the power cord plug into the wall outlet and then
press the MAIN POWER switch.
2. Press the POWER button so that a picture is projected onto
the screen.
3. Press the MENU button to display the menu screen, and
then press the F or G button to select the OPTION menu.
4. Press the ENTER button, and then press the F or G button
to select LAMP RUNTIME.
5. Press and hold the ENTER button for approximately
3 seconds. The confirmation screen, "LAMP RUNTIME
RESET." is displayed and select OK.
6. Turn off the power.
This will reset the cumulative usage time for the lamp
unit to zero.
Posted on Mar 12, 2011
Thank so much
Posted on Mar 13, 2013
Miss operation to launch "Control
When the control panel lock ON of the projector so that the projector can be operated only with the REMOTE CONTROL.
If you loos your remote control then keeping the POWER key on the projector control panel pressed for 10 seconds turns the projector ON when it is in standby mode, and turns the projector to standby mode when the power is on. If you press and hold the MENU key for about10 second when the power is on the lock will be released and "panel key lock" is automatically set to "OFF"
Feb 23, 2011 | Sony VPL-CX70 Multimedia Projector
When i turn on the video projector and send me this message"the panel keys are locked "
Your projector key panel locked you have two option to operate the projector
1 . Use remote control press MENU the menu window displayed.
use DOWN ARROW key and select SET SETTING.
press ENTER
use DOWN ARROW key to select PANEL KEY LOCK.
press RIGHT ARROW key to OFF the panel key lock
press ENTER and then press MENU key to exit the menu.
now you panel keys are working
2. If you loss your remote control then;
When the key panel lock is ON keeping the power key on the projector key panel pressed for 10 seconds turns the projector ON when it is in standby mode, and turns the projector to standby mode when the power is on. If you keep pressing the MENU key for about 10 seconds when the power is ON, the lock will be released and "panel key lock" is automatically set to OFF.
Feb 05, 2011 | Sony VPL-CS7 Multimedia Projector
How can i reset the lamp timer ???? Typ of beamer: Sony VPL-FX51 E-Mail:francois.humbert-prince@vtg.admin.ch
Connect with power cord and turn the projector to the standby mode.
Press the following keys on the control panel in the following order for less than in five seconds each: RESET, LEFT arrow key and RIGHT arrow key and then ENTER.(showing in the picture below)
(NOTE projector must be in standby mode and keys pressed less than five seconds)
now press power/standby key to ON the projector and check lamp hoursgood_help_1.png
Jan 31, 2011 | Sony VPL-FX51 Multimedia Projector
Changed my projector lamp yesterday, it work for about 4hours and went on standby. its now on a stanby mode and all effort to switch it on has not been successful. Please help me
Hi!
Is your projector connected to a source? ( Computer, DVD, or any device) make sure the connection is tight/properly plug in so that the projector will recognize the device attach to it and override the standby mode.
Hope this helps, thanks for contacting Fixya. Please keep us posted of issue. Cheers!
Dec 09, 2010 | Panasonic PT-AX200 LCD Projector
Projector problem HELP!? my projector was on whiles the utility power went out, and when the power came back i realised it had affected my projector, when i put it on (press the power button) the:...
it wasn't able to go through the cooldown mode. turn it on and power down, letting it go through the cooldown mode. does the lamp come on at all?
Jan 22, 2009 | Casio XJ-S31 Projector
Projector keeps going to standby
power supply bad. shuts down when overdrawn.
Oct 31, 2008 | Yamaha DPX1000 Multimedia Projector
Projector problems
Hi David IB
I've had teh same experience with a BenQ MP720 ( just the XGA version of your Projector )
I queried this with BenQ Engineer in Dubai and he said that it sometimes works exactly like a short on the machine.
If I could give you a tip , If it happens again don't put back the metal cover of the Mainboard it solves the problem 100%
Nov 19, 2007 | Office Equipment & Supplies
Bulb Reset issue
I had the same problem and called Sony, they just said to keep trying what the manual says to do, but make sure the unit is in standby mode. I tried in powered mode and in standby mode many times and it did not work. Then I tried again the next day when the unit had been in standby mode for an extended time period. I hit the four buttons like the manual said, all four in quick succession. I also tried the four buttons in many different sequences from what the manual said. When I powered back up the lamp timer was set to zero, finally! I think having the unit in standby for an extended time was the key. The Sony rep really emphasized the need for the unit to be in standby.
Oct 01, 2007 | Sony VPL PX40 Multimedia Projector
Panasonic PT-AX100U-EC DLP Projector Logo
2,134 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
