Question about Noritz Residential Heaters Tankless Water Heater N-0931M-OD-LP
I'm working on a n-0931m noritz and i have a 61 code flash and water leak out the blower housing i assume the heat exchanger is bad. is a heat exchanger difficult to replace
    Scholar:
  • 73 Answers
61 code is a fan motor abnormality. It typically indicates the fan is damaged and needs to be replaced. It can be caused by water leaking onto it from the heat exchanger.
The heat exchanger isn't difficult to replace, but it is confusing if it's your first time doing it. I'd recommend calling Noritz for assitance.
Posted on Apr 29, 2011
Resolving an error code 51 on Noritz nrc98-dv lp tankless water heater
I need the full model number of the water heater to pull the manual on it for you.... so far only an error code 61 is shown. sometimes a 6 can look like a 5 on a digital display if it's a 6 then error code 61 is bad fan motor or printed circuit board that sends power to the fan motor.Get me the full model number, we can go from there
Jan 10, 2018 | Noritz Water Heaters
Sounds like a truck
If the heater is more then a few years old the heat exchanger is probably corroded. Air flow from the blower motor can't squeeze thru the exchanger fins and causes loud vibrations. It can sometimes be cleaned but usually requires replacement of the heat exchanger. If you are not familiar you should definitely have a professional sevice the unit. Continued use in its current state can cause many other issues. Be prepared because the heat exchanger is the most expensive part of the heater and the most difficult to replace
Jan 10, 2014 | Water Heaters
I do have noritz 0931m that some times work and some time not
The NC250 (N-0931M) Series ASME Tankless Water Heater is a commercial grade water heater and many people install the vent wrong. PVC CANNOT be used for venting. The NC250-DV-ASME is for indoor use only. Improper venting will cause the symptom you describe.
Feb 08, 2012 | Noritz NORTIZ Outdoor Propane Tankless...
Leaking from inside box for few days , plumber said condensation built up to use fan to dry out.
If the water is coming down over the fan motor, you probably have a heat exchanger leak. If the heat exchanger is leaking, it needs to be replaced. The heat exchanger is the large copper box on top of the heater.
Oct 15, 2010 | Noritz Water Heaters
My o69m flashes a 16 and says priority
The 16 error code occurs when the outlet temperature exceeds the set temperature of the unit. Typically this occurs when the unit has developed scale in the heat exchanger. I would initially recommend performing a descale on the unit to remove any scale deposits from the HEX.
Aug 31, 2010 | Noritz 6.9 Gallon Residential Direct Vent...
I have a three year old home with a noritz tankless hot water heater. It's leaking and the plumber says the flue was plumbed incorrectly which invalidated my warranty. So, apparently I need a new tankless...
bull ****! . If the heat exchanger is leaking, it should be under warranty. If you have and improper installation that should be the responibilty of the builder or his plumber. You may have some labor cost, but not the entire cost. contact your builder
Feb 04, 2010 | Noritz 6.3 Gallon Residential Tankless...
Flashing code 90 .
The 90 error code is caused by two conditions:
1) the unit is under heating the water (not hitting the set temperature)
2) the fan is encountering resistance to air flow, which causes it to over correct
The most common causes for this conditions are:
1) insufficient BTU supplied to the unit
2) clogged fan motor or vent
3) insufficient makeup air
4) improperly installed exhaust vent
Nov 10, 2009 | Noritz Tankless Water Heaters N-0931M
It will heat water when noff for a long time. 4 hours or more. thenn it will trip the remote control. If I reset it will start to cycle twice and then trip again with a 20 flashing on the error code.
it's heating up too hot. you need to flush it out ASAP!! it has too much hard water in the heat exchanger. let me know if you need details how to flush it
Aug 02, 2009 | Noritz 6.9 Gallon Residential Direct Vent...
Trouble light bilnks 3 times pause and then repeats
You have a 16 error code, abnormal output temperature. I recommend performing a descale to remove hard water deposits in the heat exchanger. This should resolve your issue.
Jan 28, 2009 | Noritz 6.3 Gallon Residential Tankless...
Noritz Residential Heaters Tankless Water Heater N-0931M-OD-LP Logo
453 people viewed this question
Top Noritz Water Heaters Experts
jasbo
jasbo
Mack Baxter
Are you a Noritz Water Heater Expert? Answer questions, earn points and help others
