Question about Cameras
The problem is that the lens eont open and this system error mf00c appears all the time
    Novelist:
  • 147 Answers
A lens error can be caused by physical damage to the mechanism that controls the lens, or debris that is interfering with the operation of the lens.
This article may be able to help you with a "do it yourself" solution.
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
In the event that your problem is due to physical damage and not just dirt or debris, you will need to take it to a local camera repair shop for troubleshooting-- though with most consumer digital cameras, labor and parts cost of a repair can easily exceed the value of the camera.
Posted on Mar 12, 2011
My new panasonic lumixDMC-ZS8 14.1MP Digital camera gives me system error (zoom) when I turn it on.the lens will not open?
The systems control board has detected a fault wth the lens, over time dirt and grime collect in the len causing havoc, the other concern is the gears have jammed or got damaged, either way it is a major dis-assembly and it will be expensive.
Mar 20, 2012 | Panasonic Cameras
When camera is turned on the lens opens and closes several times and then an error message appears: "Turn the power off and on again." When this is done, the camera does the same thing - lens opens and...
Hello
Unfortunately a "lens error" message is not something that you will be able to fix. This error indicates a system failure and requires the camera to be sent in for servicing and repair.
You may find it more cost effective to purchase a new camera as opposed to the repair price on your current camera.
Oct 20, 2010 | Sony Battery (844986068551) for CyberShot...
Powers up, lens doesn't move, shows error MF00C and shuts down.
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Mar 05, 2010 | Konica Minolta DiMAGE G400 Digital Camera
Minolta dimage g400 camera...cannot get the lens to close
Your problem is likely due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may require professional repair.
Oct 20, 2009 | Konica Minolta DiMAGE G400 Digital Camera
Error system MF00C
Just solved this problem on my Dimage G530. An earlier time the lens (inner part) was cocked to one side after a small drop. Pulling it back straight, out of the outer part, fixed it and the lens closed.
Then just this past trip, the lens was not retracting with the MF00C error and the lens looked straight. It had opened in a pocket and gotten bumped. I had even taken the case off but that did not offer any insight into fixing the problem. (They certainly cram a lot into the case). I was about to give up and just buy a new camera or was going to inquire at vistek to see how much it would cost to have it looked at this Saturday because I really like the camera. Anyway, to make a long story short. I decided to pull hard on the inner part to pull it out - basically try to cock it to one side then the other. The lens popped out to it normal position and now everything works fine. So it appears that if bumped the lens goes to a lock position to prevent any damage to the drive mechanism.
Hope this helps someone else with this problem.
Dec 30, 2007 | Konica Minolta DiMAGE G530 Digital Camera
Nikon coolpix 775 digital camera
try these:-
  • connect it to pc and on it
  • vaccum the barrel of lens
  • changing mem. card and batt. for 2min.
  • shake it.
  • on and off in different positions
  • hit the part near lens softly with palm (trust me this made mine work)
Dec 02, 2007 | Nikon Coolpix 775 Digital Camera
Minolta G530 System error MF00C
Lens motor stalled - a repair is not likely Check out the Konica web site
Aug 03, 2007 | Konica Minolta DiMAGE G530 Digital Camera
System error
turn on and off 6 or 7 times while banging on the body beside the lens, worked for me, apparently coolpix lenses tend to stick, as my girlfriend says " a good bang will solve many problems"
Dec 06, 2006 | Nikon Coolpix SQ Digital Camera
Lens will not retract
In my case, there was dust in the switches that sense the cover movement.
  1. Close the sliding door and wait until the lens is drown inside (timeout).
  2. Open the screws that secure the front cover.
  3. Remove the sliding door covering the lens. There is no trick (hidden screws etc) so just use the force. The door is mounted by two-sided tape and adhesive.
  4. Remove the front cover. This is also mounted by two-sided tape / adhesive in the center, so you have to be a bit brave.
  5. The sliding door rails and the movement sensors are now visible. Clean all dirt.
  6. Try the door functionality.
  7. Mount the front cover after the lens works as it should. Close the screws.
  8. Mount the sliding door.
May 27, 2006 | Konica Minolta DiMAGE G400 Digital Camera
Cameras Logo
146 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
