Question about Microwave Ovens
Can not find fuse - Microwave Ovens
  • Microwave Ovens Master
  • 6,771 Answers
Remove top, look under the keyboard in towards the high voltage capacitor "silver and rectangular in shape, the fuse is white with silver ends "ceramic type" may be under plastic flap you move out of the way, you will see it clipped in, and easily removed.
Posted on Mar 12, 2011
How do I fix a blown microwave fuse?
How to Fix a Microwave Oven - Simple Fuse Replacement ...
? 18:04
https://www.youtube.com/watch?v=IN0BqiVX5ds
May 21, 2013 - Uploaded by GuruBrew
How to Fix a Microwave Oven - Simple Fuse Replacement. GuruBrew .... I'm hoping it's just a blown fuse ...
Whirlpool Microwave Keeps Blowing Fuses - YouTube
? 2:35
https://www.youtube.com/watch?v=KGQgendKTR0
May 7, 2013 - Uploaded by AdamDIY
Whirlpool Microwave Keeps Blowing Fuses ... MicrowaveThermal Fuse Replacement - GE Microwave ...
Microwave Oven Repair 101 ' DoItYourself.com
Dec 06, 2015 | In Microwave Ovens
Works a few seconds then the fuse blows. model#JES13845F
Fuse holders sometimes become weak due to heating. If the fuse is not held very tightly by the holder, the fuse will blow because it gets hot, not because the current exceeds the fuse's rating. If this is the case, replacing the fuse holder would be in order. This is not to be confused with the situation where the fuse blows when the door is opened or closed. In that case it's a door switch sequencing issue, or a bad switch.
May 04, 2014 | Microwave Ovens
Replace fuse Kenmore 40188523011
If you know that a fuse is open, you need to find out why it went out before replacing it. There are typically three fuses in any given microwave oven. Line or monitor fuse, cavity temp fuse and magnetron temp fuse.
Oct 07, 2013 | Sharp R-1750 Microwave Oven
How do I access fuse in a jmc7000adw? Unit is "dead", want to check fuse first before calling repair person
To check the fuse in the JMC7000adw you first should remove the power cord from the power source. Then remove the screws holding the outside cover of the microwave . The High Voltage circuitry may hold a residual charge that could be lethal so use appropriate care when near the High Voltage circuitry. The fuse holder is a plastic inline clamshell type that must be opened carefully with the fingers or pried open. The fuse holder is located above the micro-switches near the internal light socket. The fuse plugs into contacts soldered onto wires so carefully pull the contacts off each end of the fuse being careful not to get cut if the fuse breaks. Sometimes the blown fuse might come apart so you will need to force the fuse ends out of the contact using a small screwdriver or other small instrument that will fit into the end of the metal fuse contacts. After replacing the fuse with the appropriate size I suggest you might wish to see if the fuse blows again before reinstalling the cover. Most likely the fuse blows because of an overload in the circuitry or a short in the safety micro switches as noted in other posted solutions. These micro switches seem to be underrated for the current they may be carrying and the contacts will weld themselves together or intermittently stick together causing the fuse to blow as noted in my previous posting.
Aug 09, 2013 | Jenn-Air JMC7000 Microwave Oven
What internal fuses for goodmans st101ss microwave
the modern microwaves has 2 fuses lines fuse+thermal fuse. You must see the diagram or instr. manual section troubleshooting for indication for specification of fuses. Lines fuses has 240vac and 20amps. Thermal fuses you must see the instr. manual
Jan 24, 2013 | Whirlpool GH8155XM Microwave Oven
GE microwave oven model#JVM1441BH04 when you close door on switch activates and oven comes on. Only goes off when door is opened.
HELLO.
the problem your are experiencing with your microwave oven is a failed interlock switch.
Be careful when closing your microwave door. Slamming the door too hard is one of the main reasons that the interlock switch is damaged.
Slamming the microwave door shut can easily blow the microwave fuse, but they can also blow due to problems with the interlock switches.
A microwave oven will not function until the fuse is replaced.
Instruction on how to replace fuse on microwave.
1. Unplug the microwave from the electrical outlet to prevent electrocution. Place the microwave in a well-lit area to be able to locate the fuse.
2. Use a screwdriver to remove the outer cabinet of the microwave, and follow the power cord to the fuse. The fuse is located 2 to 3 inches within the microwave and is attached to the power board.
3. Observe the fuse to determine if it is blown. Blown glass fuses will produce burn marks on nearby surfaces, or the internal fuse wire will be black and melted, while ceramic fuses show no outward appearance of being blown.
4. Determine if a ceramic fuse is blown by testing it with an ohmmeter. If the ohmmeter reads zero ohms, your fuse is not blown. Other readings on the ohmmeter show that your fuse is blown.
5. Replace the blown fuse by popping it out of its holder, and snapping a new fuse in its place. Tighten the fuse clips by squeezing them together with your fingers.
6. Replace the outer cabinet of the microwave, and plug the microwave back into the electrical outlet. Test the microwave to see if it's working properly.
thanks.
Sep 22, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
My old GE Spacemaker II microwave (JEM21K001) died. I was using it, heard a little pop, and it lost all power. Is this something simple to fix like replacing a fuse or is it bulk trash at this point?
HELLO.
take on these steps to solve the problem.
Check if there is electric power on wall outlet.
If the microwave plug has fuse,check if it has not burnt.if these are okay there is need to take the last step.
things needed
1.Screwdriver
2.Ohmmeter
3.New fuse
Thanks.
Sep 18, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I have a blown internal fuse on my JennAir M170b microwave. The fuse holder says 250V, 15A fuse, but the fuse that was in there is a 125V, 15A fuse. The micro plugs into a normal 110V circuit. Which type...
The information on the fuse is the maximum rating. The holder may not match the rating.
The 'A' is the very important part of the size. You will need a 15 Amp fuse. The best fuse to use is 'ceramic'. You can find them at Radio Shack in the back of the store there are drawers with electrical parts.
15 Amp ceramic
Jun 10, 2010 | Jenn-Air M170 Microwave Oven
Possible fuse -- no power
Replacing a fuse Locate your fuse. Most microwave fuses look like the one pictured to the left. They are usually an inch or two long. Each end is metallic and the center is either ceramic or glass.
To get to the fuse, remove the outer cabinet of the unit, which is usually held in place with a few screws. Once the outer cabinet is removed, follow the power cord into the unit. It will take you to the fuse holder, where the fuse sits. The fuse holder is located two or three inches into the unit, and may be attached to a power board.
Decide if your fuse is blown. A blown glass fuse will produce flash burn marks on nearby surfaces, or it will be completely black on the inside. The internal fuse wire (filament) will be melted and blackened. Ceramic fuses give no outward signs of having blown. To determine if a ceramic fuse is blown, test it with an ohmmeter. If the ohmmeter reads zero ohms, your fuse is fine. A reading of infinite ohms means your fuse is blown.
Replace the blown fuse. Pop it out of its holder and snap in a new one. You can squeeze the fuse clips together with your fingers in order to tighten their grip. Replace the unit's outer cabinet, plug it back in, and test to see if it is running properly. DO NOT run the microwave with nothing in it.
NOTE: Fuses do not usually blow on their own. A fuse may blow because of problems with the interlock switches or with high voltage circuitry. It is also possible, though rare, that a power surge will cause a fuse to blow.
Jun 05, 2008 | Amana RCS 10D 1000 Watts Microwave Oven
Fuse
I'm confused! You say you cannot read? OR, You cannot read the fuse. Remember on fuses, voltage rating is as important as amps. What is the make and model? is there a diagram of the wiring inside? get someone to read the amps (fuse) to you.
Note: Most common is a 15amp (for M/W Oven). Can be purchased at most Hardware Stores.
CAUTION!! Do not over-rate or under-rate the fuse. If it blows with the correct fuse in it Do Not put in a higher amperage fuse!! Can everyone say FIRE!!
Jan 22, 2008 | Sanyo EM-S8000 Microwave Oven
Microwave Ovens Logo
15 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
