Question about Dryers
My dryer was working fine until one morning it wouldnt even start. We have cleaned out the traps, We have checked the door... the light comes on every time its opened. The buttons seem to work and move fine. Yet our dryer is still not working.
  • Marc Uhrey
    Marc Uhrey Mar 12, 2011
    Is it a gas or electric dryer? If electric, does it run on 120 volts AC (VAC) or 240VAC?
    President:
  • 1,554 Answers
This is a symptom of a blown thermal fuse located on the blower housing. This thermal fuse is in wired in series with the motor and power to the motor is cut when the fuse blows then the motor cannot run and no dryer function works. Click on the link below for the details on how to troubleshoot this kind of dryer problem.
Troubleshooting Whirlpool and Kenmore Dryers Not Starting
Posted on Mar 12, 2011
Dryer heats but clothes wont dry and have checked lint screens front and back. How much "air flow" should be coming out the back of the dryer?
Do not use this dryer until you fix it. You need to check the pipe or flexible tube that comes out of your dryer (where the hot air comes out). Even though you clean your dryer lint trap some lint gets by. If you can get to it, go outside and find the opening where the dryer air comes out of your house. Then open the little door and look inside but not when the dryer is running. If there is any lint inside clean it out. Then disconnect the air outlet from the back of the dryer and inspect. It should be free of lint. If it is full of lint clean it all out. You can also call a pro to perform the inspection and cleaning. Good luck.
Jan 16, 2014 | Dryers
My whirlpool dryer will not start. The light comes-on, but no go. Reset circuit breaker in garage, cleaned-out lint trap. Door switch appears fine (I replaced it a few months ago). It's a Whirlpool...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Dec 05, 2010 | Whirlpool LER7646E Dryer
We just finished a load in the dryer and it worked fine. When we went to start another load it wouldn't start. The circuit works, it is plugged in, and the door is shut
Are your lint traps clean? Also, your vent hose going out the back of the dryer sometimes gets clogged up, and this will shut down your dryer until it is cleaned out. Try this, and if it still doesn't work - try shutting the dryer's circuit breaker off (or if its easier to unplug the dryer), and then back on again. This will reset the breaker, and then you can try running your dryer again. In fact, you can do the circuit breaker step first. If this doesn't work, then clean the lint trap, vent, etc. - and then return to the circuit breaker step. I hope this works for you. If not, let me know. I'll check back with you in a little bit. Good Luck!  Jim
Mar 29, 2010 | Maytag Dryers
Our Kenmore Elite HE4 gas dryer will not start although all controls on front are lite and appear to be functioning properly (settings can be changed, etc). I has been working fine for several hours until...
check the door switch and door latch. Open door, set the dryer to air fluff cycle, and manually depress the door switch. Press start button. If it started - door needs alignment to fix it.
If it did not start:
If your dryer has light inside - check if light turns off when you press the switch. If not - switch needs replacement.
If all that checks out ok - the problem is more serious, and you might need a tech to come out and diagnose it.
Mar 04, 2010 | Kenmore Elite HE4 Electric Dryer
Maytag Neptune MDG4000BWW
check your door switch it might be broken. push the door switch in with your hand. does the light turn off? if no this is your problem
Aug 19, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Magtag Electric Dryer
Did you check the breaker closely. Dryers work on 220 volts, usually 30 amps and that means TWO 110 breakers attached together must be good and putting out 110 volts each. One may be burnt or disabeled and the other working. Also check at the  dryer receptacle and make sure you have 220 or more volts.
Mar 11, 2009 | 2001 Yamaha V Star 1100 Classic
Whirlpool dryer model LEQ8800JQ won't start when push start butto
I posted today (Jan 2, 2009) that I had same problem. Handyman tested for blown thermal fuse, etc and everything was fine. He said I have to replace the timer switch .. well guess what - I fidgeted with the start button (on/off) hard a few times while simultaneously pressing & releasing door switch and it did the trick. In my case the problem was most likely with the start button. Dryer is working fine now!
Jan 02, 2009 | Whirlpool LEQ9858P Electric Dryer
Dryer won't power up, says check filter
Check the door switch first.Than look for possible thermal fuse has cut off.
May 22, 2008 | LG DLE2514 Electric Dryer
Won't work at all,
Hi Lanil,
The only things that will not allow the dryer to start are the following:
  1. I know you said you checked the breakers, but they could be the cause.
  2. The Child bouncing on the doorcould have broken the stub stub that pushes the door switch in.
  3. You may need to firmly press the Start switch.
  4. The dryer need to be plugged in, I know you checked it.
These are the four main things. Since the child bounced on the door, the trouble is most likely with the door switch. Try to use a stick or something to simulate the door closing and activate the switch and push the start button. If this starts the Dryer, and closing the door firmly does not, then the switches position or doors prod that pokes the switch, is not lined up or failiing to fully activate the door switch.
Nov 02, 2007 | Whirlpool LER5636P Electric Dryer
Dryers Logo
71 people viewed this question
Top Dryers Experts
