Question about CTX S761A (Black) 17" LCD Monitor
Monitor will not turn on. I have pressed the power button still no power
  • 62 Answers
Hello
This should be pretty straight forward to trouble shoot.
1) make sure the outlet you are using does indeed have power
2) try another power cable
If you are not getting any power at all (no lights or anything) when you try to turn this on, the monitor has most likely failed and needs to be serviced.
Posted on Mar 12, 2011
Osd unlock
To unlock the OSD (onscreen display control), turn off the monitor and then press and hold the Menu button on the monitor. Then press the power button to turn the monitor back on. Do not release the Menu button before pressing the power button. This same step (holding the Menu button and then pressing the power button) enables the OSD lock. The menu button is the top button on the right side of the monitor (on the bezel). The power button is the bottom button of the group. AOC has the documentation for the 2036sa here: http://us.aoc.com/monitor_displays/2036sa . See page 20 of the User's Guide for the OSD lock procedure. The picture of the monitor buttons is on page 19. The guide is available as a PDF on the AOC site. Note: you will need Adobe Reader or a similar program to read the file.
I hope this helps.
Nov 01, 2012 | AOC 2036sa 20"TFT LCD Monitor
What is combination for entering service menu on LG M1962D?
1. Power off your monitor with POWER button
- Hold MENU button and keep it pressed while pressing POWER button
2. Press MENU button to enter Service menu
3. Change panel type
- Press SET button until PANEL text is yellow and press (-) two times to change it to LPL22W 4L
- Press MENU button to close the Service menu
- Press POWER button to power off your monitor and remove power cable for a minute and plug it in again
Jan 18, 2011 | LG M1962D Monitor
Volume control stays on screen
hi,
while the system is turned on,
Remove all cables from monitor.
keep pressing the power button.
reseat the cables.
release the power button.
press the power button again to turn on the monitor.
It must work.
else the monitor needs repair.
Rate this solution and comment to keep in touch or further interaction
Sep 16, 2010 | HP Compaq WF1907 Monitor
What is osd locked
You can try the following, to lock or unlock OSD function: To lock the OSD, press and hold the MENU button while the monitor is off and then press power button to turn the monitor on. To un-lock the OSD - press and hold the MENU button while the monitor is off and then press power button to turn the monitor on. Hope this is helpful
Jul 22, 2010 | HP vs19 (Silver) 19" LCD Monitor
OSD locked how do I unlock
OSD Lock Function: To lock the OSD, press and hold the Left button while the monitor is off and then press power button to turn the monitor on. To un-lock the OSD - press and hold the Left button while the monitor is off and then press power button to turn the monitor on.
Sep 11, 2009 | AOC 917Sw 19" LCD Monitor
Possilbe to reset monitor?
This document pertains to MX50, MX70, MX75 and MX90 CRT monitors.
NOTE: To reset the monitor to factory settings:
  1. Turn off the monitor by pressing the POWER button.
  2. Press and hold the plus (+) button and then
  3. Whith the Plus (+) button pressed, press the power button to turn on the monitor.
  4. Release both buttons.
Jan 01, 2009 | HP Pavilion MX70 17" CRT Monitor
How to turn off burn-in mode if botton on Monitor
I didn't have the monitor connected to the computer, and that's why the power button was unresponsive. After connecting it, the solution above worked for me.(My KVM switch was set to a computer that was turned off)
Oct 07, 2008 | Sceptre DCL9a
OSD Lock
  • OSD Lock Function: To lock the OSD, press and hold the Left button while the monitor is off and then press power button to turn the monitor on. To un-lock the OSD - press and hold the Left button while the monitor is off and then press power button to turn the monitor on.
Apr 18, 2008 | AOC LM729 17" LCD Monitor
Power button won't turn monitor off?
ok,your monitor is in  a very simple problem.clean the control panel circuit of your monitor,or if it is not working replace the tact switch in your monitor.
Oct 18, 2007 | Sharp LL173C 17" Flat Panel LCD Monitor
OSD Menu won't turn off
Known issue -- can get a replacement if still under warranty. The planar rma techs are really really nice.
May 13, 2007 | Planar PE170 White (Black, White) 17 in....
CTX S761A (Black) 17" LCD Monitor Logo
88 people viewed this question
Top CTX Computers & Internet Experts
Rommel Balcita
Jerry Greenberg
Jerry Greenberg
Are you a CTX Computer and Internet Expert? Answer questions, earn points and help others
