Question about Thermador MBES Microwave Oven
How do i remove the membrane touchpad? - Thermador MBES Microwave Oven
  • 1,538 Answers
Every microwave oven I've seen has the touchpad permanently glued to the controller housing/front trim piece. To get this off, remove the top/side cover piece, then look for screws that hold the controller housing to the front of the oven. On some models, there is one screw at the top. After you remove that you can slide the controller up to unhook it from the oven frame. If there is a push-in door release latch in the housing, there is probably a screw or two at the bottom as well.
Now here is where it gets interesting. There is a flexible printed cable from the touchpad to the controller circuit board. To detach it from the board, you must first unlock the connector. There is a flanged collar on the connector. If you pull the collar up as if you were going to slide it along the cable (it only comes out a millimeter or so and hits an internal stop; it's part of the connector and is not supposed to be removed), that unlocks the connector and the cable slides right out. If the cable doesn't slide out, make sure you have both ends of the collar up to the internal stop. Now you can remove the screws that hold the controller onto the keypad and the removal process is essentially complete.
To reinstall the ribbon, slide it all the way into the connector and push the locking collar back down. Make sure the cable is in square and straight or the keypad may not work properly.
Caution: handle the controller board only by the edges. The controller chip(s) is very vulnerable to static electricity damage and can be ruined by a spark to the circuit that is too weak for you to feel the discharge. Avoid touching the contact area of the touchpad ribbon while inserting or removing it. (If you need to clean the ribbon contacts that go into the connector, it is OK to work on those while the ribbon is disconnected.) In some ovens, the controller chip is mounted directly on the board and covered with a soft rubber compound. These are especially delicate; it's too easy to break the fine wires inside that connect the chip to the board (but they're cheap to make!).
Posted on Mar 12, 2011
Built in microwave counter top lights not working
Did you replace bulb yourself if so it may look a good bulb with filament complete but if you have touched the glass part of bulb with your fingers it can knacker the bulb.
Also the switch membrane panel traces the circuit from both the switch membrane and the lighting circuit to the power circuit board. So, I know that both the lights and the switch membrane have a common terminus on the power circuit board. Since the circuits from both sources lead to a common point,
Apr 06, 2016 | In Microwave Ovens
Not all buttons work on touchpad
There will be a problem with the touchpad membrane, usually this is usually repaired by replacing the complete touchpad facia or front control panel.
Nov 10, 2013 | Goldstar MV-1515 Microwave Oven
HOW DO I CHANGE OUT THE TOUCHPAD FOR JNM1731DPBB
I'd suggest you contact Matt Fadorsen at eM-Ka Ventures in Chesterland, Ohio. He just repaired my GE keypad on a Model JVM2070CH02 microwave (GE doesn't make just the membrane keypad available--you have to purchase the entire control panel ($548.00 through a local parts distributor). Matt's turnaround from the time I removed the keypad to the time I re-installed it was only 8 days--and it only cost me $100, which included the return shipping. I'm sold on Matt!
Jun 29, 2013 | General Electric GE JNM1731DPBB 1.7 cu ft...
Touchpad does not work any longer. Is there something to check, or is this a service call.
You have a failing membrane keypad.
On some models you can order just the membrane keypad. It's more work, but it's cheaper.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
On other models, you have to order the control panel frame which comes with a new keypad already on it. This costs more, but it's an easy DIY job.
A YouTube video showing how to remove a typical over the range control panel assembly in under 5 minutes, is here.
Some connectors have a lock.
You can order GE parts from the Pros here.
Nov 30, 2012 | GE Profile : JVM3670BFBB 36" Over the...
Touchpad isn't responding. GE JCM1540 the touchpad isn't working--stuck at "press clock"
I'm guessing that full model number would be JVM1540xx###?
But in any case, you have a failed membrane keypad.
On JVM1540 models, the membrane keypad the membrane keypad is not available as a separate part, so you would have to order the control panel assembly which comes with a new keypad.
It's actually a pretty easy do it yourself job.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Next, disconnect the strip as shown in the photo below, then remove the screws that hold your circuit board in the old frame.
Then carefully (since the display is made of glass) move your circuit board to the new frame, and reassembly is the reverse of disassembly.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Here are the proper model number formats in this series:
JVM1540DM1BB
JVM1540DM1CC
JVM1540DM1WW
JVM1540LM1CS
JVM1540SM1SS
May 22, 2010 | GE JVM2070 Microwave Oven
Microwave ge spacesaver touchpad does not work except for the
You have a failed membrane keypad.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites. There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
If you would like to have us do this repair for you, we do that for $39.95 plus part costs nationwide.
But please note that for some GE models, the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
In this case, you simply move your circuit board into the new frame.
That is a simple do-it-yourself job.
Either way, we can let you know what your options and costs would be and send you other helpful info.
Feel free to contact me
directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
May 04, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I have a Sharp model R-1610 Microwave. The work/night light does not work. I"ve changed the bulbs.
Does it operate with a membrane-type touchpad?
These things seem to be problematic as the microwave ages.
They are usually replaceable, and the cost is not great. I just installed a new touchpad on an LG, and it cost $25.00 plus shipping.
Oct 12, 2009 | Sharp R-1610 Microwave Oven
Can I replace keypad for my PLMV168KC3 Frigidaire Microwave?
Is it a membrane type touchpad?
These are usually held in place with an adhesive. You can pull the old one off and stick the new one on. The complication usually involves the connection between the touchpad and the body of the microwave. This connection may or may not be easily accessible.
Oct 09, 2009 | Frigidaire 1.6 Cu. Ft. Over-the-Range...
The touchpad is not functioning
Found part number to be A630Y5940AP try http://www4.ued.net/catalog/cat_item_idx_2099.html or search part number
Aug 03, 2009 | Microwave Ovens
Touch pad on microwave doesn't work
HI, since this happen before and it suddenly fixed itself, i don't think its major. i recommend checking the ribbons for a tight fit. theses connection ribbons may be lose or partiality separated form the control board, in return, causing this fault. you can accesses the ribbons by removing the backcover of this unit. if the ribbons are in good condition, i recommend replacing the touch pad membrane.
May 21, 2009 | KitchenAid KHHS179LSS Convection /...
Thermador MBES Microwave Oven Logo
319 people viewed this question
Top Thermador Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Are you a Thermador Microwave Oven Expert? Answer questions, earn points and help others
