Question about Vacuums
Hoover elite u4617-930 how to change out belt
  • 240 Answers
First remove the bottom rug plate. Some have screws, but most have tabs holding it in place. The upper plastic cover must also be removed. Pull off the rug heigth indicator knob first. The upper cover is held in place by 4 tabs along it's outer sides. Look for little arrows in the base that indicate the location of the tabs, and pop them loose with a screwdriver. The upper cover should now lift off. Place the new belt ( # 38528040 or package # 40201190 ) around the brush assembly and put the brush back in. Now you must hook the new belt with a strong screwdriver and stretch it up and around the motor shaft. This will require some strength, as the belt must be stretched a considerable distance. Turn the brush with your fingers prior to replacing the cover, to be sure the belt is centered, and not caught between the brush and the base housing.
Posted on Mar 12, 2011
What is the belt part no. for a hoover elite rewind?? model no. UH71009RM
If you look up the Hoover page for the UH71009 (the non-remanufactured Elite Rewind), there are 3 different belt model numbers listed. One part number is simply for a 2 pack of the belts. See http://hoover.com/products/details/uh71009/elite-rewind-bagless-upright/ . Click on the Parts & Accessories tab.
I believe the belt part number is 38528058 , http://hoover.com/parts/details/38528058/sra-r-b-562932001-belt/ .
I hope this helps.
Oct 04, 2015 | Hoover Vacuums
How do I change the belt for the Hoover Elite
Follow this link to a website that will show how to change belt (it aslo has illustrations). Click first link listed on page.
http://www.info-vacuum-cleaner.com/hoover-vacuum-cleaners.php
Hope this helps.
Jan 26, 2010 | Hoover Elite Rewind Bagless Upright...
Hoover elite how do i put the belt on
Here is the belt you need: Hoover U5061900 Belt
Simply turn the machine over and you will see (4) screws, remove them and you will be able to access of the belt.
Dec 14, 2009 | Hoover Elite U5061-900 Bagged Upright...
My HooverDeluxe Elite Rewind became extra loud
If the belt is really worn it can cause that. I wold try changing the belt if you haven't recently. Here are the belts you need:
Hoover Elite Rewind Belts
Nov 14, 2009 | Hoover U6630-900 WindTunnel Bagless...
How do I change the belt on my Hoover Elite Dual Purpose Vacuum cleaner? The belt part # is 38528-027. Where is the motor pulley?
The hoover belt number you listed (38528027) has been changed by Hoover to 38528040. Below I have listed a link to the manual that has instructions and a link to the belt you need. Hope this helps!
Hoover Elite Manual
Hoover Elite Replacement Belts
Nov 02, 2009 | Hoover Elite U5061-900 Bagged Upright...
How do you change the belt on a Hoover Elite
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=704482
Generic problem for all Vacuums
posted by Belle406 on Jun 25, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. the Hoover Elite belt change can be done from the bottom under the bottom plate by removing clips or screws and the bottom plate should come off and then you can get @ the belt. 1st, lift the brushroll out from the pulley end on the side – remove the belt and slide on the new belt and re-install the new belt on the pulley side. Then use a belt puller or a screwdriver that may or may not have a hook or bend on the end and then stretch the belt onto the motor pulley and the track the belt in a straight line, then /2 that time replace the bottom plate. If you cannot get @ the belt from the bottom, then the top cover will come off and use the steps above.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 25, 2008 | Vacuums
How to change a Hoover Elite sweeper belt
on the bottom there should be a few screws take them out and a cover should come off the belt is right there. hope this helps
Dec 18, 2007 | Hoover Elite U5061-900 Bagged Upright...
Vacuums Logo
1,385 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
