Question about Refrigerators
My refigerator does not work. the fan runs but the compressor does not. the compressor start relay is burned. Did a failed compressor caused this problem or will the relay alone correct my problem?
    Guru:
  • 683 Answers
You can test it if you are still online i will tell you how.
Posted on Mar 12, 2011
Mr Kenmore refigerator started making a loud SNAP when the compressor starts and stops a while later. This apart from the fan noise. Relay?
Sounds like the compressor start relay might be the culprit. It generally clicks when the comp turns on or off but you normally do not hear it.
May 04, 2014 | Refrigerators
Jenn Air JCD2389GTB side-by-side refrigerator freezing & cooling
Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Jul 13, 2010 | Jenn-Air JCD2389G Side by Side...
Fridge made a burning smell, and now makes a Tick, Fan runs on...
Sounds like the start relay has become bad/defective and it should be unplugged until we can have a look at it closer to see if possibly something other than the start relay is the reason for causing this failure. Depending on your model number a defective defrost control board or fan could start this cycle of damage to the compressor start relay and compressor if not unplugged until repaired. Please see if you can find the model number and I will be able to tell you more about the cause and assist you in the repair, Thanks, Sea Breeze
Apr 25, 2010 | KitchenAid KSRA22CN Side by Side...
Frigidaire FRS23R4CW2 side by side refigerator It is running but it is not cold at all. the fan work I check the back of the refigerator. what is the problem.
Hi, if the condenser fan is up and running at the back, what about the compressor? When the fan is on, the compressor should also be on. Place your hand on top of the compressor, but carefully as it could be very HOT if it is locked up! If it is hot, more then likely the compressor has failed and is off on its overload. If you can hear it click on and off so often, it is stuck and tripping on the overload. Check the condenser coil in back to make sure it has no layer of dust covering the front of the coil. This will cause internal pressures in the system to be very high causing the compressor to stop. Check and make sure the fan in the freezer, evaporator fan is also running. Check what I have asked of you and keep me posted.
Sincerely,
Shastalaker7
Feb 03, 2010 | Frigidaire FRS23R4A Side by Side...
Frigidair side by side refigerator fan not operating
I do see the power to the evaporator fan section going through the adaptive defrost part number 240554502 It would not hurt to unplug for a few moments and open the control panel inside the fresh food section and examine that control board. With it doing that you may see signs of heat or burn marks on the ADC Let me know, Sea Breeze
Jul 21, 2009 | Frigidaire Refrigerators
Refrigerator and freezer not getting cold
Clean out the coils on the bottom, make sure the fan motr is turning below and remove the relay from the compressor. A lot of these relays are failing lately. If the relay sounds like a slt shaker inside it is toat. if it makes no sound at all it is bad. You should beable to feel the sliding start switch inside.
Jun 14, 2009 | Frigidaire FRS26R4A Side by Side...
18 cubic foot roper is clicking, but not freezing.
yes the "relay" on your unit has burnt out. if you shake it and pepper looking pieces come out of it that will verify that you need to replace the relay.
nice work finding the exact problem by yourself and now all you have to do is buy a relay and plug it in to get things back to normal.
also be sure to clean the coils under the unit as when the compressor gets too hot it will cause the relay to fail. it is very common and you can fix this yourself.
Jan 07, 2009 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
Stopped working
Unplug the ref for a couple of hours ( let the compressor cool off) plug it back in. If it still clicks, replace the relay, if the compressor still won't start then the compressor is bad. Last rights at this point would be appropriate.
Mar 18, 2008 | Maytag 22.1 cu. ft. Bottom Freezer...
Kenmore side by side #50562991
The black pod is the compressor and the switch on the side is the compressor start relay. You either have a failed relay or a locked up compressor.
Most likely it is a burned out relay.
Unplug the fridge and remove the relay from the compressor.
Shake it. If it sounds like a lot of loose pieces are rattling around in it, it is burned out.
Be sure you replace it with the correct replacement part. A "fit-all" relay may work for a while then cause the compressor to fail.
Your model number has 106 in front of it. You will need to know that when looking up or ordering parts.
Post back if you have any questions.
Nov 11, 2007 | Refrigerators
Kenmore Refidgerator is not cooling
let fridge cool down it sounds like the relay overload is bad try replacing it with a 3 n 1 start kit directions on the kit real easy to hook up... if the compressor starts then you are ok... hopefully the compressor is not burned out good luck
May 09, 2007 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
46 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
