Question about Coleman Propane Forced Air Heater w/Electronic Ignition (50,000-80,000 BTU)
I have a Coleman Furnace Model G8T10016U4B11A, the red light flashes twice and I get no combustion blower. Can anyone suggest a solution? Is it a bad board?
  • 48 Answers
Your combustion motor is the very first thing to cycle when theres a call for heat. Look at your access panel. There should be a LED status indicator chart. It will tell you what the flashing LED means and what your most likely problem is.
Posted on Mar 13, 2011
Combustion switch error on windy days
check gas pressure and flame sensor
Jan 06, 2018 | Coleman Heating & Cooling
Furnace wont work
Have to know the model and serial of the furnace.
locate code list usually inside or on the back of a door.
Operation sequence= call for heat--inducer blower motor--makes pressure switch--signals board to bring on hsi--after a set time gas valve opens and you have ignition--main blower motor comes on after a set time
Feb 14, 2014 | Coleman 7990-319p Evcon Gas Furnace...
I have a Coleman/Evcon furnace model #DGU08016UB that has a concern. In my attempt to check my furnace before we need it for the winter; the following condition occurred. Condition: Flashing code of...
jump out pressure switch see if it lights check hose to pressure switch see if they are split or connections are not good ,cut off ends and put back on presure switch.
Sep 21, 2011 | Coleman Heating & Cooling
Coleman combustion air switch failed to close
Hi, new switch can be found on amazon... here: Amazon com Coleman air switch. I hope this was helpful. Cheers
Nov 24, 2010 | Coleman Propane Forced Air Heater...
Coleman evcon Dgato7obdc
Small blower motor? Are you talking about the combustion blower if so then check your vents for blockage.. if the vents are blocked won't work... if it has a control board init it will give you a diagnostic code. Flashing light on the board... count the flashes and look up the fault on the chart in your owners manual ot on the furnace door..
Jan 13, 2009 | Coleman Propane Forced Air Heater...
Furnace shuts off
Defective combustion air switch. The 3 blinks are an error code. You didn't say, but I'm guessing you have a Coleman Evcon. They had alot of defective Combustion air switches. Your specialists were not that.
Jan 05, 2009 | Coleman Propane Forced Air Heater...
I have a red t brand furnace. i think it's part of coleman.
could be bad switch but is the vent free and open of all debris or being blocked by anything
Nov 18, 2008 | Coleman Propane Forced Air Heater...
Coleman furnace blower runs continuously
You should be seeing 120 volts to the igniter. Anything less requires either a replacement of the transformer, start relay or control module.
Dec 19, 2007 | Coleman Propane Forced Air Heater...
Heating & Cooling Logo
113 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
