Question about Kenmore 600 6965 Electric Dryer
Kenmore dryer model # 6672. Comes on and gets hot, but after a few seconds, the heat cuts out.
    President:
  • 3,074 Answers
Disconnect vent tube and run dryer, as it sounds like the vent is restricted, Tim
Posted on Mar 12, 2011
Kenmore Heavy Duty dryer model # 86873100
The drum belt is lopped through a idler wheel that has a power cut off switch that cuts the power when the belt breaks.
So I don't know why the dryer would heat up if the belt is broken?
Is the top of the dryer very hot. Check the dryer vent tube is not clogged.
Feb 22, 2014 | Frigidaire Kenmore Washer Tub to Pump Hose...
Schematic kenmore 110 96585200
Firstly, take off the vent that hook up to the rear of the dryer, if the dryer got heat again. You should clean the vent. Else, there are quite a few component caused no heat. They are: thermal-cut-off (non-resettable), heating element.
Beware to unplug your dryer before opening it. The cut off thermal and heating element can check it connectivity by ohm meter. Normally, the cut-off causes this issue.
Check this link for more information http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Dryer-Parts/Model-11096585200/0582/0151200/10036890/00003
Oct 15, 2013 | Dryers
I have a Kenmore Series 70 Dryer and I changed the thermal fuse got hot for a few minutes the model #110.74722400
The cycling thermostat must also be replaced when replacing the thermal fuse. The cycling thermostat's failure to cycle off the heating element results in overheating of the dryer which consequently blows the thermal fuse open.
Replacing only the thermal fuse should the dryer stops running and fails to start will result in its premature blowing or even the thermal cut-out (cut-off) located on the heater duct. Like the cycling thermostat, the high-limit thermostat must also be replaced once the thermal cut-out blows open. Refer to the parts diagram in the link below and look for item numbers 31(thermal cut-off), 34(hi-limit thermostat), 39(thermal fuse), and 41(cycling thermostat.
Kenmore Series 70 Electric Dryer (110.74722400) Bulkhead Parts
Aug 21, 2011 | Dryers
The dryer is taking a couple of ctlces to dry items. I opened the door and depressed the button, so that the dryer would run while I was checking for heat. The heat comes on but then after a couple of...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101'
Mar 12, 2011 | Kenmore 72802 Gas Dryer
My kenmore dryer turns on but cuts off a few seconds latter.
Must be the motor. If it was a limit and the dryer stopped it would NOT start again later. Only a bad motor can produce this phenom.
Dryer motor replacement video for old school models
New style dryer motor replacement video
You could replace the motor OR go to Plan B
Lube the motor and see if it will go a bit longer.The heat makes the oil in the resrvoirs dry out with time. The motor shaft needs a thin layer of oil between the shaft and bearing. If that oil is gone the motor will get hot and die quickly. You can sometimes get her to work some more and save some money: How to lube a dryer motor
Jan 21, 2011 | Kenmore Dryers
Kenmore Model 110.96585200 No heat!
You probably have a bad thermal cut-off . This is the small thermostat , located at the top of the element housing . This " thermostat " should read infinate resistance ( no resistance ) . You can put the 2 wires togather , and see if heat comes on . pt # 3399848 . Both thermostats , should read 0 resistance . They are normally closed . The thermal cut-off , will not reset itself , if open . This is a safety t-stat , for when dryer gets too hot , and will have to be replaced .
Nov 11, 2009 | Kenmore Dryers
Kenmore dryer will not git hot HEATING ELEMENTS is good and thermostat is good
Hello, Ok if you have checked the heater, hi-limit, thermal fuse and thermostat and they are all good your problem is going to be with the centrifugal switch. This is built into the motor. To check this pull the wire harness off the motor and where you see the 2 big wires going into the plug make a jumper wire with 2 male spades and some wire. Jump this wires and then run a cycle for a few seconds. if the heater comes on you have found your problem. This will require you replace the motor. Hope this helps. Mike
Oct 30, 2009 | Kenmore 62602 Electric Dryer
Whirlpool dryer model LER7646EQ1
Thats what it's supposed to do hopefully the clothes are coming out dry. The dryer has both thermal sesors and fuses that tell the dryer when to heat up and when to cool down. So yes the heating element will come on and go off multiple times in a cycle.
Mar 31, 2009 | Whirlpool LER4634J Electric Dryer
Dryer does not heat
Check the thermal cut-off, the thermostat, and the heating element. Most times one of the tree is the culprit.
I have seen a bad timer cause the no heat problem a few times but 99% of the time it is one of the three I mentioned.
If you change the thermal cut-off make sure you get both the cut-off and the thermostat. A stuck T-stat will take out a cut-off in a big hurry.
Feb 12, 2009 | Whirlpool LER5636P Electric Dryer
Kenmore 600 6965 Electric Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
