Question about Moen & Replacement Cartridge
Shower valve first opens hot then cold after ccw rotation. Isn't that backwards? Is the cartidge upside down?
  • 6,674 Answers
HC should be facing up on cartridge.
Posted on Mar 12, 2011
  • Mike Butler
    Mike Butler Mar 12, 2011
    If faucet was installed upside down originally, then HC will need to point down.
I installed a Tuscany shower valve and the hot and cold are reversed. I didn;t change any of the piping and hope there is a way to adjust with the cartridge. Help!
I am not familiar with that valve, but I hope I can offer some help. It may be that you installed the valve upside down. Every shower valve I have ever installed has writing on the back that says; UP. If you still have access to the rough-in valve, you may want to check that. Also, if it is installed upside down, you can try to pull the cartridge, flip it and reinstall it. That does not work with all cartridges, but it is worth trying if the rough-in is installed upside down.
Oct 17, 2014 | Home
Single handle balances cold & hot. First cold then hot at full counterclockwise rotation. Only a trickle of cold coming through but hot side works fine. Appears to be a ball valve. What could...
there could be dirt in the cartridge or the integral cold side shut off is not fully open. the integral shut off has a slot for a screw driver. the slot is to face the same direction as the pipe coming into it to be open and straight up and down to be off.
Dec 29, 2010 | Moen & Posi-Temp Single Handle Shower Or...
I bought a Danco 3H-10H/C, Hot/Cold stem. The problem is, it seems to be setup for hot (clockwise closes the valve, counter clockwise closes it). Is it reversable? Or is it not really a hot/cold...
One of two things has happened. I'm assuming you only get hot water when you open the valve and that this is for a single handle control shower fixture. If so either this is the wrong valve for your shower control or it is installed backwards. Sometimes the valve can be installed at either 180 degree angles. See if it can be installed any other way. If so this may solve the problem.
Jul 18, 2010 | Danco Faucet Stem
Kohler shower valve (hot/cold switched)
Just had this same thing, on this exact faucet. If you still have the manual, it has instructions on how to rotate the valve for back to back installations where one shower has the hot/cold reversed. Our contractor got ours in backwards the first time and I had to call and have them come out and rotate the valve this morning.
Dec 19, 2009 | Kohler Forte entertainment remote valve...
Water came out both shower head and tub spout (even w/o spout)
The shower valve is clearly mark "UP" when you look at it from the front.
Nov 17, 2009 | Plumbing
Faucet issue
Sounds like it was installed upside down or the cartridge is installed improperly
May 06, 2009 | Kohler K-T10335-4-CP Lyntier Rite-temp...
Hot and cold oscillations on my deva envy shower
no man i installed plenty of shower valves if your in the shower looking at it the left is hot always just make sure ur holding it right side up most of them have a plug that goes in the bottom to block the tub spout and the top goes to the shower are maby u put it in upside down? good luck man if you run in to another prob, post again good luck
Apr 11, 2009 | Plumbing
Hot and cold backwards on a moen shower faucet
tun off the water.
unscrew teh allen screw under neath the handle. pull out hteh handle. undo the wall plate and gain access to the cartridge in the handle body. turn the artridge around 180 degree and reisntall all parts.
Apr 06, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Replaced a moen cartidge and now the water is not hot in shower
make sure when you turn on the hot and cold shut off valves all the way and turn the moen on after that. Some times I would get that problem if I turned one(either hot or cold) off then tried the shower.
Feb 23, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Moen & Replacement Cartridge  Logo
82 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
