Question about LG Washing Machines
LGWM0642HW 2 yrs old. Load of towels unit would not spin. When spin cycle trys to engage makes grinding noise. Unloaded all towels and performed drain cycle unit spins but makes grinding noise? Any ideas?
    Guru:
  • 262 Answers
Hello....My name is Keith.....Please give me one moment while I bring up the parts drawings, and then I will start to address the issue.
Thank You....
Posted on Mar 12, 2011
  • Keith Drake
    Keith Drake Mar 12, 2011
    From the service manual.....
    ABNORMAL SOUND
    Is the motor bolt loosened?......Secure the bolt.
    Is there friction noise coming from the motor?........Replace the STATOR ASSEMBLY or ROTOR ASSEMBLY.
    here is a link for your parts diagram....Copy and paste into your browser
    http://www.searspartsdirect.com/partsdir...
    you will need to take off the back cover then run a spin cycle....see if you can locate where the noise is coming from.My guess it is coming from parts k122 and k125 bearings.This is how they sound when they go....then later on the noise may sound like a helicopter taking off.
    Note the drawing and the parts mentioned above. With the cover off and the spin cycle running you should be able to determine where the sound is coming from.
    Please post results.
    Keith
My LG Front Load washing machine is making a grinding noise on spin cycle I believe it is coming from the motor
Hello. The noise you are hearing on spin is a failed basket support bearing. Depending on the model, you are looking at a cost of a professional to repair it of around $400+. If you do it yourself, around $200. This is a common failure on LG washers.
Apr 28, 2014 | LG WM2487H Front Load Washer
Loud grinding clicking noise during the drain cycle
It sounds like your drain pump has failed or has something stuck in it. You didn't specify a make and model so all I can say is that there are several good videos on YouTube about this problem because it's fairly common. Good luck!
Nov 23, 2013 | Whirlpool LHW0050PQ Front Load Washer
I have a John Deere LA145 lawn tractor. When I engage the mower, a loud noise (grinding) comes from the mower. What could be the problem? The tractor is 2 yrs old.
check and make sure all of your drive pulleys are spinning freely a bearing may be bad in one of the pulleys cause it grind metal on metal but the most common problem is a bent or warped mowing blade cause it wobble and shake and contact the underside of the deck.
Aug 26, 2011 | Garden
GE Profile WPRE6100G Top Load Washer My washer is 2 yrs old and has started to make a loud metalic banging noise during the wash cycle. It does not during the spin cycle. Doesn't seem to matter whether...
Hi!!
The "Metallic banging/clicking" sound you hear is the Shifter mechanism engaging or disengaging.
The drive system will engage at the start of the Agitate Cycle and disengage when the Agitate Cycle is complete. This occurs multiple times during the wash. GE claims this is a normal sound and should not be concerned about it. Check page 10 of your Operating Manual, if you do not have a manual, click on this link to download one http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-90323.PDF
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Dec 03, 2010 | GE Profile WPRE6100G Top Load Washer
FRIGIDARE FRONT LOAD WASHER,2+YRS OLD ON FINAL HIGH SPEED SPIN MACHINE MAKES LOUD VIBRATION NOISE AND FIND NEED TO SHUT DOWN DUE TO FRANTIC VIBRATION AND NOISE.
It is possible the bearings on the motor that spins the canister could be going bad especially at the high speed. This could also be from clothes getting unbalanced in the final spin cycle. Hope this helps. This could still possibly under warranty!
Aug 22, 2009 | Washing Machines
Spin cycle not working properly
On the transmission there are two shift arms. One shift arm controls the agitator and the other shifts to spin the cloths. If the washer has been making a "clicking" sound when it trys to spin, the solenoid that shifts the spin shift arm is not catching and the drum will not spin. The other possibility is the spin clutch is slipping and make a "grinding/ratcheting" sound. Neither, unfortunately are inexpensive to fix.
If you can describe the sound and when it occurs, I might be able to get closer.
Let me know.
Regards,
May 15, 2009 | Maytag Ensignia MAV4757AWW Top Load Washer
GE model WCVH6800JMS front load washer spin cycle
My washer is 1 1/2 years old and I have the same problem.
Nov 11, 2008 | GE WBVH6240F Front Load Washer
Maytag Performa - Loud Noises during Spin Cycle
This washer is JUNK!!!!!! We have the same washer (2 1/2 years old) and same problem. Tried to replace the bearing myself, no luck. So I called a repair man to come out and look at it. As soon as i told him the model number, they would'nt even come out. Very common problem for this washer. We are on our way to Sears to purchase a Kenmore.....GOOD LUCK
Sep 07, 2008 | Maytag Performa PAV2200
Washing Machines Logo
137 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
