Question about Isomac Millenium Espresso Machine
Hi. Not sure how to remove the filter from the group head on my Millenium. It isn't covered in the manual
    President:
  • 1,618 Answers
Depending on model there should be a screw in the middle.
Posted on Mar 14, 2011
How do i use cleaning powder
Hi Dont use the cleaning powder yet. Remove the group head shower and clean it with steel wool, then clean the group head where the shower sits with sfeel wool. Remove the filter fron the group handle and clean the under side. Also clean the group handle before you put the filter back in. You shouldn't use powder in these machines, but if you do, you need to put a blind filter (filter with no holes in it)in the group handle. If you dont have a blind filter, you can use foil to cover your filter. When you have done that, you need to add a 1/4 teaspoon of powder into the foil covered basket and lock the handle in the group head. Switch the coffee button on for a few seconds then off again.Domt take handle out yet. Repeat this on/off proceedure 5 or 6 times. Now remove the handle and flush out any powder that is left. Leaving the foil in place, lock the handle back into the group head and repeat the above proceedure. This fushes out any powder residue. Make a coffee and discard. Now your machine has bee back flushed. Again, i do not recomend using powder in these machines. The poder can back flow into the boiler. Just make sure you give it a good flush. If you clean your group head and shower weekly, you'll never need to use powder. Dazza COFFEE MACHINE TECHNICIAN
Sep 26, 2011 | Rancilio Silvia Espresso Machine
I need Windows 7 64 bit driver for Matrox G450 Millenium 32MB DDR PCI Dual Head Video Card (DVI + VGA) (G45FMDVP32DB) Graphic Card. Where can i get this one please let me know. Thanks in Advance.
Hi there please download "drivermax" search for this on google. This is agreat program that will find drivers for anything. Careful though, you only get 2 free drivers per day on the free version so make sure you download the relevant ones using this program.
Thanks hope this helps
Jul 29, 2011 | Matrox G450 Millenium 32MB DDR PCI Dual...
How do I remove the shower and the diffuser on an isomac millenium?
Hi
You need to remove the brew head gasket in order to get the screen out. Then you will see everything else. The brew head gasket holds everything in.
Jan 16, 2011 | Isomac Millenium Espresso Machine
Hi, no water through e61 group head ?
Check the metering jets and filter on the top of the group heads.
Jul 15, 2010 | Coffee Makers & Espresso Machines
How to change the fuel filter
Remove the right and left sidecovers, turn the petcock off - left upper side now accessable where the side cover removed. Remove the fuel filter phillips head screw from lower right side and slide it out. removed hose clamps from old one and withdraw filter. Replace in reverse order. Further info can be obtained from email group via www.suzukicavalcade.com
May 23, 2010 | 1986 Suzuki GV 1400 Cavalcade LX
Twisted crank
Replacing the crankshaft you will need to do complete engine tear down.
If your mechanically inclined and you have the tools and must needed service manual go for it.
Remove the engine and make sure you have an area to lay out your motor parts so you do not mix nuts and bolts in one big pile,start at the top removing the valve cover and work down, keeping your top end parts in their grouping ( valve cover with their bolt,cams and cam bolts together,head and head bolts and do not mixup your cam bearing caps ) your going to have a lot of bolts try not to mix them up.
Good luck but get a manual this would take days to walk you through it.
May 03, 2010 | 1983 kawasaki Csr 1000
How do i remove a broken gasket ring?
If it is the group gasket, remove the shower and diffuser, then using an ice pick or scratch Awl, insert into gasket and remove, it will come out in pieces.
Jan 20, 2010 | Isomac Millenium Espresso Machine
After getting Replace Water Filter VEntilate display I replaced with Saeco Intenza water filter cartridge I have always used. However, unit does not move off this display after I press OK button. I have...
After replacing the filter in the tank, keep the button pressed; when the indicator light is flashing, then release the button.
Also at times, the gears in the brew drive assembly will not complete the cycle to the proper start position for different reasons. Some of the reasons are:
  1. Brew group jammed or blocked.
    Note: A jammed or blocked brew group can happen when the brew group starts the cycle but doesn’t finish it.
  2. Either one of the micro-switches in the brew drive has gone bad.
  3. Brew drive motor failure.
  4. Broken teeth on either of the brew drive gears.
  5. Dirty brew group, covered by coffee grinds.
  6. Brew group or gears not lubricated.
  7. Connections to the board from brew drive assy., or motor have gone bad
Oct 08, 2009 | Saeco Incanto Classic Espresso Machine
Where is the fuel filter located on a 2000 millenium edition
Hello kathysue2: My name is Roger and I can answer your question. Open the trunk pull up the cover. The carpet that cover the floor. You will find a small cover. Probably 6 inches or so in diameter. Remove the 3 screws holding it down. You will find the filter under this cover. Be careful loosening the fittings. The fuel system will be under pressure. Please rate the quality of your answer. This helps insure the information you received was correct. Thank You for using FixYa. Roger
May 07, 2009 | 1999 Mazda Millenia
Water not pouring down
Need more info such as is it a 2 head or 1 head. Have you removed the screen and diffuser to see if its clogged, do you hear the pump when you run the head. If yes to all then on top of the group, if you remove the front cover, and the sheet metal plate you will see a nut a 17 or 19mm open end wrench will help you remove it(MAKE SURE WATER IS TURNED OFF AND THAT THE MACHINE IS COOLED BEFORE OPENING). The micro filter and the jet will be covered with minerals clean filter and use a paper clip or long pin to clean the small hole in the middle of the jet.
Mar 16, 2009 | Astoria Argenta SAE-2 Espresso Machine
Isomac Millenium Espresso Machine Logo
90 people viewed this question
Top Isomac Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you an Isomac Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
