Question about Sharp R-630D Microwave Oven
Loud pop now a hum and no heat light and fan working
  • Sharp Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Posted on Mar 12, 2011
My 3 year old frigidaire microwave made a loud pop and stopped heating. Everything else works. It also now makes a loud humming sound while running.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ][
\=-0-]
Apr 02, 2011 | Frigidaire GLMV169D Microwave Oven
Runs but has loud humming sound. Does not heat. Turntable, timer and lights work.
The diode that connects to the capacitor needs to be replaced. Once its replaced microwave will begin to heat again. (If it wasn't heating and wasn't making a humming noise, then your magnetron would need to be replaced). If you are thinking of doing it yourself and need instructions, i'll be glad to help.
Feb 06, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
My microwave made a loud "pop"and now hums loudly
Since the microwave is humming, that tells me that the diode is bad and needs to be replaced.
Feb 04, 2011 | Whirlpool MH3184XP Microwave Oven
Power on Turn,Turn Table Moves,but don't heat
To allow us to help you effectively (at no charge), please post a NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, your symptoms ("no heat"), as well as the answers to these questions:
- When you try to microwave are the inside light, internal cooling fan and turntable all working?
- Is there any unusual noise or is it louder or quieter than normal?
We have a sound clip here of what a microwave should sound like when the cooling fan and high voltage section are working.
A loud buzz, hum, or groan is usually a shorted high voltage rectifier diode, but a sound like gurgling into an empty coffee mug is one symptom of a failed magnetron, and yet the mag can be bad without that sound.
Nov 27, 2009 | Maytag Microwave Ovens
Microwave popped and now does not heat
Okay, first we need to separate the situations. You were boiling water on the stove and had the range hood fan running to **** up the steam. Then you put something in the microwave to heat and you heard a pop and then zip-o.
The water on the stove has nothing to do with the situation, the fan you turn on is not part of the microwave, so it has nothing to do with the microwave.
The pop you heard and then the humming suggests the magnetron failed. You said you found a blow fuse and replaced it and still nothing, right? The magnetron is the most likely culprit...I would think it is safe to say that the magnetron shorted and drew enough current to blow the fuse.
Replace the magnetron and if that doesn't work, let me know here. Good Luck!
Sep 14, 2009 | Sharp R-1480 Microwave Oven
Loud pop and microwave doesn't heat anymore
I have a GE Profile Spacemaker model JVM3670WF001, purchased I think in 2003. Pop sound, no Heat. Light goes on, carousel goes around,
Repair or new microwave
Jun 03, 2009 | GE Profile Spacemaker Over-the-Range...
Boiling waer under micro wave lots of steam into micro wave, turn on micro wave ,pop noise like glass miro wave comes on louder hum than normal no heat
Q - The microwave display counts down and the inside light is on,  but nothing is heating and the fan is not running.
A - This most commonly is a bad door switch, other possible problems are a faulty relay or solder joint on the power module, but a bad door switch is most common.
 Q - My microwave is running and sounds like it is working but will not heat up anything.
A - Many thing can do this but, common things are....loose high voltage wire.....poor solder joint on board.....magnetron.....power relay.....
Q - The microwave makes a loud "hum or buzz" noise but will not heat up the food?
A - 9 times out of 10 this is usually this is a bad magnetron, the other time is sometimes a bad high voltage diode. See components section.
Mar 03, 2009 | Amana Radarange Microwave Oven
My over the stove microwave will run however no heat. Popcorn digets do not count down but set numbers do. odd odor.
Q - The fan in my microwave oven is not running will this hurt my microwave?
A - YES, the fan cools the magnetron and electronics, take the microwave in for service, most fans are not too expensive to replace.
Dec 11, 2008 | Microwave Ovens
Loud humming noise
If all of your door switches check out, replace the magnatron, capacitor, and diodes.
Oct 27, 2008 | KitchenAid KHMS145KSS Microwave Oven
Microwave made a loud pop,won't heat,sounds like it's only on half power, makes a low intermittent hum
This is almost certainly a blown high voltage diode.
Please reply back with your brand and model number so we can help you.
May 31, 2008 | Microwave Ovens
Sharp R-630D Microwave Oven Logo
101 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Ed Mac
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
