Question about Kenmore 98702 Stacked Washer/Dryer
Water fill levels seem too low
Can the water level pressure switch be adjusted to fill the tub to a higher level? My tub only fills two thirds of the way up the inner wall below the rim, in the area where the inner tub holes are. If an adjustment is possible, how do I do it? Thanks.
    Genius:
  • 1,028 Answers
Wouldn't want to try to adjust ..can be risky and tough to get right ..water level usually comes to top row of holes ..be sure drain hose is as high as tub top to prevent siphoning
Posted on Aug 01, 2008
Not sure if normal or something wrong but i put it on large load and it only fills about a third of the way if that is this normal
top loader --- there is a small plastic hose that runs from the bottom of the tub up to the level control switch at the panel
the filling water pushes air up that tube until the trapped air pressurizes enough to overcome the water level setting and switches that switch
if it already has water in ti it will activate the switch too early
pull the switch off one end and blow the water back out
re attach and set the level and turn on the water
Apr 04, 2017 | Washing Machines
There does not seem to be enough water in machine to wash with
This problem could have a number of different causes. Unless it is a machine specifically designed to operate at reduces water levels, the likely cause is that the sensor that determines how much the machine fills up is somewhat blocked or going bad. The blockage would prevent accurate sensing of the water level. See the explanation below:
The level sensor uses a pressure switch to detect the water level in the tub.
Water level control switch
This switch controls how high the tub fills with water.
Water level control switch plumbing
The big end of the hose connects to the bottom of the tub, while the small end connects to the switch. As the water level in the tub rises, water rises in the hose also; but the air in the hose is trapped, so as the water rises, the air is compressed.
Inside the water level control switch
Inside the housing of this switch is a little piston. The pressure in the hose pushes the piston up. When it is raised far enough, it pops up and closes an electrical contact. This set point, where the contact is lost, is adjustable, and in the picture you can see the cam mechanism that is connected to the adjuster knob on the control panel of the washer. As the cam turns, it presses a spring against the cylinder, making it harder for the cylinder to pop up. This means that the water level will have to rise some more before the pressure in the hose will be high enough to trigger the switch.
Aug 11, 2011 | Washing Machines
Water runs but doesn't fill tub and wont spin if put on spin cycl
The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
Jan 09, 2010 | GE WBSE2090A Top Load Washer
Low Water Level in Roper washing machine
You need to check the pressure switch which is also called the water level switch. There is a small tube attached to it and it may have a blockage or a hole in it. You can find this behind the control panel to the left of the timer.
Nov 14, 2009 | Washing Machines
Maytag FAV6800AWW - Major overflow right after starting machine
Hi, If you turn the water source valve on and water starts filling the machine even tho the machine is off, change the inlet valve.
If you have to start the machine so water will fill but, the water does not shut off at the desired level, there is a problem with the water level switch.
I hope this helps you. Please let me know if I can assist you further.
Vic.
Jun 13, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Keeps filling with water
The water level in a washing machine is determined by the pressure switch. The switch is located behind the load selector, water level, load size (has various names depending on model and manufacturer) knob on the operator console. If the switch malfunctions, the water will not shut off and the washer will overflow.
Now...before assuming the switch is defective, a common problem that occurs is the small air hose on the pressure switch coming loose or leaking. This air hose attaches from the wash tub to the pressure switch. The pressure swtich senses the change in air pressure as the tub fills and shuts the water off at the selected level. The following link explains:
http://www.fixya.com/support/r762094-washer_overflows
To access your pressure switch, unplug the washer and open the operator console. Look for a clear plastic hose. If it is NOT attached, you may have found your problem. Reconnect and test operate.
If it IS attached, check the entire length of the hose all the way to the wash tub for any cracks of leaks. In addition, remove the electrical connection(s) and check for corrosion. Clean if necessary.
If all these preliminary steps don't solve your problem, replace your pressure switch. Read through the link I provided and let me know if you have any questions. I hope you find this information helpful.
Jun 12, 2009 | GE WJSE4150B Top Load Washer
Washer fills up only half way but water keeps trying to fill tub
That is because the water level switch get stuck when water level reaches that particular point.
The water level switch is activated either by a floater sensor or by a membrane sensor that detects water pressure/volume, depending on the model.
On washing machines it is usually a membrane switch, and that is faulty on your machine.
Feb 20, 2009 | Admiral AW22 Top Load Washer
LOW WATER LEVEL
you cant the water is meter though a pressure switch,,,but heres a trick but you have to find your way from here,,,fill the tub first than push the clothe,,careful of overflow,,if you do it enough you will be a master,,,
Jan 06, 2009 | Frigidaire GLWS1439F Top Load Washer
When washer is in super wash cycle water will not stop causingthe tub to over fill running onto the floor.
It sounds like you are trying to use the largest water level setting. If this is correct you may have a pressure switch problem.
First turn the timer to spin and get all of the water out, that start a washer cycle with the water level set to the small or low setting and see if the washer fills to this level. if it stops at the low level great Now if it continues to fill and does stop you may need a pressure switch or the hose needs to be replaced that runs from the tub to the pressure switch.
Now set at the medium level and try again. does it stop or over fill?
If it over fills you probably need a pressure switch however before you purchase this, make sure the hose is in good condition one pin hole will cause your overfill condition.
Jul 09, 2008 | Washing Machines
Kenmore 98702 Stacked Washer/Dryer Logo
200 people viewed this question
Sal De
fordexpert
Robert Rankin
