Question about Gigabyte GA-8LD533 Motherboard
I DONT FIND THE CORRECT VGA,DISPLAY DRIVERS OR ANY
  • Gigabyte Master
  • 3,606 Answers
You need to down load this driver from here:
http://www.gigabyte.lv/products/page/mb/ga-8ld533-c/download/
Intel VGA (845/865) Driver.
Hope this was helpfull.
Posted on Mar 12, 2011
  • Gigabyte Master
  • 32,281 Answers
You can download the drivers from Gigabyte WEB support site,select your model motherboard to download :- http://www.gigabyte.com/support-downloads/support-downloads.aspx
Stack when vibrating
actually , the problem
with cable for Display or VGA ship-set
problem , you have plug you laptop with external
Screen then check , if still " Vibrating "
check the driver for VGA , is it correct , if there is no problem with vga driver it means ,VGA ship-set problem
hope help you
BR
Mohamed Hejazi
HP Tech. Support
Nov 10, 2013 | HP Compaq nc6120 Notebook
I have a dell laptop that I want to add a second monitor to. My monitor is a HP L1755 and my laptop has Windows 7 Ultimate on it. I can not find a driver for this... any suggestions?
Hi there, if i read you correctly you are trying to connect external monitor on laptop. As you use old Monitor for this you can probably establish only VGA connection . For this you dont need any special drivers if you use VGA external connector on laptop. You just need to find out right combination on keyboard to activate external monitor to be activated or right click on desktop then properties and display option multiple displays. Of course when you manage to activate mode for external screen please use lower resolution like 1027*768 for second display aka monitor to test .Cheers
Sep 15, 2013 | Samsung 941BW LCD Monitor
Trouble with HDMI output on Acer Aspire D257 Netbook.
VGA Driver? Does your tv have a VGA Connection? Have you selected PC or HDMI as your input source on the TV? Have you hit the FN Function Key on the laptop + the corresponding F1 thru F12 key that displays the image on the TV?
Press and Hold the FN key then hit the correct F1 thru F12 key that displays on the tv. The correct F1 thru F12 key will probably have LCD/CRT on it or it might have the icon of a display.
For Drivers: They won't be called VGA but either (Display, Video or Graphics Drivers)
Get onlineand got to www.google.com In the google search box type: "AcerSupport" (without the quotes). Look for downloads and drivers. Enter your model number and operating system when requested. Download andinstall the drivers.
Apr 01, 2012 | Acer Aspire One Netbook
My Acer Aspire 5580 turns on but has no display on the monitor. How can I solve this?
HI
can you try to start up with power key and also press the f8 key at the same time
now can you see anything if you can
go down to and try to click on repair and if that dont work on restart
then start up again pressing the f8
and try last good configuration and if that dont start up correctly then
try to restart again pressing f8 and try to go into safe mode when you probably will be able
to see the screen
and if you can go to device manager
scroll down to find the display
uninstall it and do a restart and hopefully windows will find new hardware and
reinstall the display correctly but it will probably just give you a standard vga driver
so on restart if you can then see your screen you could go to
start
programs/windows updates
check for new updates to see if there is a update for your vga
good luck
Mar 06, 2011 | Computers & Internet
My mother board are biostar amd k8m800 micro am2. plb are i have dont instal vga driver. i need a vga driver.
Hi i belive this is the correct driver for your system for xp as theres is no vista or 7 driver so you must use xp
http://www.viaarena.com/Driver/CN800_220001e_XP_wIShld_logod.zip
Mar 04, 2011 | Computers & Internet
Set up your display adapter with a standard vga driver i cannot download games my video card because i install window 7
Windows 7 must have the correct VGA driver to work correctly.
Contact your manufacturers web site for the correct driver.
Jan 26, 2011 | Computers & Internet
Samsung samtron 55v display problem
assuming that u r a professional..
i guess there is no problem with ur monitor, it sounds like itz due to graphic adapter..either the adapter on ur system main/mother board/agp/pci/pcie is damaged or itz simply 'driver corruption'..
don't panic..check for driver update/download n reinstall graphic/display driver..
however, 1st make sure that the Screen Resolution (1024x768 or as applicable) and Color Quality (32 bit or as applicable) is correct..from Display Settings->Settings tab..
always better to contact system admin/vendor....
Dec 30, 2008 | SAMTRON 55V 15" CRT Monitor
Vga driver for ecs M791G
KENAPA PCI-E VGA SAYA ECS KN1 SLI LITE / C51G-N754 TIDAK MAU DISPLAY, SEDANGKAN WAKTU SAYA BERI VGA DISLOT PCI MAU DISPLAY?
Oct 13, 2008 | ECS KN1 SLI Lite (V1.0A) Motherboard
Vga driver?
Check on the board there should be a FCC code use this code to google. This should get you the correct drivers
Jul 04, 2008 | Computers & Internet
I am not having vga driver
Hi sajal12,
http://www.driverstock.com/MSI-PM8M-V-driver-download/14-9-11370/index.html
Here you will find all the drivers for MSI PM8M-V Motherboard like display , SATA driver, video driver, audio driver, chipset driver etc
Best of Luck and dont forget to Rate :-)
Jun 03, 2008 | MSI PM8M-V Motherboard
Gigabyte GA-8LD533 Motherboard Logo
227 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
