Question about Kenmore (15132) Built-in Dishwasher
Why my glasses has spot - Kenmore (15132) Built-in Dishwasher
    President:
  • 228 Answers
You may have hard water, you may not have a water softner. to compensate for this you have to
use a rinse agent in addition to the dishwashing powder, there should be a cap or screw in cap
next to the area where you put in your dishwashing powder. this is where the rinse agent goes.
just put enough to fill. it should be good for several washes, check often this will insure, no spots
on your kitchen ware. good luck!
Posted on Mar 12, 2011
White spots on exterior of microwave door glass
Exterior or interior? If they are on the exterior then something unassociated with the oven has caused them. If they are between sheets of glass then could be silacone fume residue or if it has a clear plastic filter on the inside of the glass, could be that. If they happen to use laminated glass, it could be the plastic middle but I doubt they would. Radiation leaking from microwave ovens is really a bit of a myth. Yes, if you have a damaged seal and there is a big enough gap, microwave radiation can leak out but unless you are hugging your oven, it's no real drama, according to current medical experts.
May 05, 2017 | Kenmore Kitchen Ranges
I can closed the back passenger window
IF you can, separate the rubber/felt window seals and see if you can see the top of the window glass. IF you can - use a pair of needle nose pliers and attempt to carefully pull up - making sure you do not crack (shatter) the glass. Once enough glass is exposed - use your fingers to pull-up. While you are pulling--up attempt to raise (up) the window with the window switch. There may be a dead spot on the motor, by pulling-up you advance the motor beyond the dead spot, and the motor MAY re-engage.
IF you can't get the glass up with needle nose pliers, try pushing down on the glass (being careful again) while engaging the window switch to raise (up). Again the idea is to get the motor from the dead spot.
Another way: While engaging the window switch to raise the window - bang (hard) on the door - in various spots to attempt to "vibrate" the motor to engage.
Last but not least: Remove the Inner Door Panel and raise the window by hand, again using the window switch to (maybe) assist you.
I have also (but painfully): separated the window seals and got a piece of duct tape down onto the glass, using a long screw driver to adhere enough of the tape to the glass enough to pull up on the glass. It worked but it needs careful hand control on your part. GO Duct Tape!
Jan 10, 2010 | 2007 Jeep Liberty Sport
Just changed all cartridgages and photo quality is still bad
scanning
Spots on a scanned
- Glossy photo (original)
- In the high humidity
environment
When a glossy photo is
strongly pressed on the
platen glass, the photo
will stick to the glass,
and the stuck points are
scanned as spots.
- Do not strongly press
the photo on the platen
glass.
- Clean the platen glass
(to eliminate any
moisture).
- Spots appear on
the scanned
image, though
there is no such
spots on the
original
document.
Oct 13, 2009 | Canon Pixma MP500 All-In-One InkJet...
My 2000 ford crown victoria's driver side windshield wiper will not stay tightly on the windsheild when i get over 40 it gets worse until it does not wipe at all. Tried replaced the blade nothing, the arm...
I usually start with the blade as well, the arm can be bent in a method to make it arch high higher in the middle of the arm - forcing more downward pressure onto the windshield. The real problem however, could be your windshield. Not that I believe that all Ford vehicles should have the "Carlite" stamp on the glass, there are other good brands of glass. But, some glass manufacturers have poor quality control and their glass molds produce some parts with flat spots, low spots, high spots and many other distortions in the glass. Does your windshield have a Carlite stamp at the lower part of the windshield? If you can't adjust the wiper to work, you may want to consider the glass instead.
Sep 27, 2009 | 2000 Ford Crown Victoria
Line showing up on scanned photos
You can remove the line by checking the glass in the auto document feed area (the small glass area about 1" X 8"). Check the glass for either white-out or a black spot (ink) and wash it off using alcohol or glass cleaner and a lintless towel which ever works. Sometimes the spot can be more easily found if you line up the line on the paper to the glass.
Good Luck!
Rich
May 02, 2009 | Computers & Internet
How to get a black spot off a glass top range
I found an amazing way to clean my glass cooktop... I pour Boiling water on it... then a sponge with a scrubby side and it look great! Try it
Jan 27, 2009 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
There are spots in the glass in the door can you take it appart
There is a screen behind the outer glass of the door which protects you from harmful microwave emmisions. Residue will build up here over time. Trying to clean this screen may damage it and subject you to serious problems. I have been using Microwave ovens for 35 years with no problems. I dont worry about this because germs will be eliminated by the emmisions.
Nov 13, 2008 | Frigidaire PLMV169DC Microwave Oven
Panasonic Copier
If the spot is in the same spot each time, then there is something in or on the glass. Make sure both sides of the glass are clean ( sometimes spots are really hard to see on the glass and may take several times of cleaning. You may have dust on the mirror under the glass. I would suggest a tech clean there.
Hope that helps...
Lbcoaster
Jun 27, 2008 | Panasonic Office Equipment & Supplies
Microwave door has burn spots on the glass of the door...
i have the same problem, there is a brown spot about 3 inch
by 2 inch at the bottom of the glass, I cannot clean it, it looks
like its in between the glass.
May 01, 2008 | Whirlpool MH6150XMS Microwave Oven
The brown spots are usually grease / smoke deposits. Usually there are indeed two sheets of glass in the door. If the grease is not arcing or smoking, and the metal screen / mesh (that blocks microwave leakage) is not damaged, then it's likely better left alone. It might be useful to boil a few cups of water with a little vinegar inside the microwave to help dissolve the deposits. In case you want to take it apart, I have attached a photo from a similar model that illustrates disassembly of the door. It is not necessary or advisable to remove the door or hinges when disassembling the door.
Jun 25, 2007 | Goldstar MV-1501 Microwave Oven
Kenmore (15132) Built-in Dishwasher Logo
121 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
