Question about Kenmore Elite 45986 Front Load Washer
I have kenmore elite HE5t. I replaced the door latch because there was error code F29 and then F22. After replacing the latch I still get error code F22. After replacing the latch and initially getting the error code, I unplugged the machine for 30 min, but that didi not work either. What next?
  • 6 more comments
  • jeffd287 Mar 12, 2011
    Did not find any loose connection
    Model number11047018601
    Sorry, transposed numbers, number is 11047081601
    11047081601
    Model 11047081601
    Yes
    Not sure you are getting my replies
    That is my original post
  • Anonymous Mar 23, 2014
    cost of new one
  • 1,940 Answers
F-22 is: CCU /touchpad/LED assembly unable to transmit/receive data to/from the CCU central control unit
Take the top panel off, should be 3 screws on the back of the top panel. Then look at your CCU, and remove the wire connections from it and inspect the wiring in the connectors to make sure non of the pins are broken or burned. Then reset all the connectors back to the CCU and see if that fixes it, if not then your CCU would need to be replaced.
Possible causes/procedure:
1. Check the touch-pad/LED assembly by selecting different cycles and changing the modifiers and options available to confirm the touch-pad/LED is responding.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the touch-pad/LED assembly and Central Control Unit (CCU).
The part number on the CCU can be looked up and purchased from here: http://www.repairclinic.com/Shop-For-Parts
Posted on Mar 12, 2011
    Guru:
  • 262 Answers
F22 DOOR LOCK ERROR After 6 failed attempts to lock the door. Possible Causes/Procedure Door lock mechanism is broken or removed from door. Door switch/lock unit failure.
1. Unplug washer or disconnect power.
2. Check door switch/lock unit.
3. Check the wire harness connections to the door switch/lock unit and Central Control Unit (CCU).
Link for all appliance model numbers.
Please post your entire model number.
After you have clicked on the link below....
Just to the right of the "search" tab click on "help me find my model number"
Just click on the model of your choice In either video or image presentation
Then please repost the information.
Click on the link http://www.repairclinic.com/Appliance-Parts
Thanks....
Keith
  • 1 more comment
  • Keith Drake
    Keith Drake Mar 12, 2011
    Data base says no go on the model number
    0 results found for model # 110.47018601
    If this is a canadien model I can not help you.
  • Keith Drake
    It is one of these
    Model 11045986400 (250 parts)
    Kenmore Elite Washer
    RESIDENTIAL WASHER
    Model 11045986401 (211 parts)
    RESIDENTIAL WASHER
    Model 11045986402 (193 parts)
    RESIDENTIAL WASHER
    Model 11045986403 (193 parts)
    RESIDENTIAL WASHER
    Model 11045986404 (193 parts)
    RESIDENTIAL WASHER
  • Keith Drake
    Is this not your original post?
    Problem with the Kenmore Elite 45986 Front Load Washer I have kenmore elite HE5t. I replaced the...
Code f29 will not start
The error code F29 indicates a problem with the door lock assembly. I recommend replacing the door lock assembly part number 8183270
searspartsdirect.com
Please see the instructions provided below.
If you do not feel confident repairing this problem yourself, then you can have it repaired at your home by a Sears technician. Here is a link for the website:
Sears Home Services
SAFETY NOTICE: Be sure to disconnect power to the appliance before performing any repairs. If you are not comfortable with doing any voltage checks that might be recommended, please contact your local service provider for repairs. Be aware that there could be sharp edges inside the appliance that could cause cuts or other injuries to yourself or others. http://www.shopyourway.com/m/questions/1077653
Apr 28, 2015 | Kenmore Elite HE5t Washer
F22 error persists on my washer, does the door gasket have to do with it?
F22 is usually a door latch error on Kenmore washers so you are working on the right area. The door gasket rip should not cause that unless it is stopping the door from closing all the way. It is usually the door latch itself which has switches built into it that causes that error or the main board is not reading the latch operation.
Mar 21, 2015 | Kenmore 4.7 cu. ft. High-Efficiency Top...
Washer gives code F22. I replaced the door lock mechanism but it still will not start.
Hi, F-22 means that the CCU /touch pad/LED assembly unable to transmit/receive
Your model's tech sheet gives error codes and remedys.
Jun 17, 2011 | Kenmore Elite HE5t Washer
Kemmore elite 3t has error code f and will not drain
Check your door when it closes, it should hit a push-in button above that door latch, at times I have seen the door hinge bent down just some, causing the door not to strike that button dead on.
If thats fine, then its likely to be the door latch assembly or the CCU board bad.
The code is a door lock error!
Nov 25, 2010 | Kenmore Elite HE5t Washer
My Kenmore Elite is getting to hot. It flashes f-29
F29 is a Door Latch Unlock error. This occurs after the door attempts to lock 6 times. With no successful lock achieved, the error code will be generated.
http://www.fixya.com/support/r1484196-f29_error_code_whirlpool_duet_kenmore
Check the above link for an detailed article above the same F29 error.
Courtesy:JSROCK - A senior expert of fixya.
Jun 10, 2010 | Kenmore Elite Oasis ST 7806 Dryer
Kenmore he5t
this looks like a classic whirlpool control board issue. fault is a communication error between board and panel. check connections.
whirlpool always recommends replacing both at same time. very common problem.
Jun 01, 2008 | Kenmore Elite 45986 Front Load Washer
HE5t Kenmore Elite
non existent code. if under warranty call tech support. probably control board. can manually override door lock. by removing lower panel and pulling tab at bottom of lock mech.
May 30, 2008 | Kenmore Elite 45986 Front Load Washer
F22 code appears on Kenmore Elite Front Load washing-?
communication error between control board and panel. Make sure both are replaced together. common problem
May 27, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
237 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
