Question about Acer Aspire One Netbook
Will not boot says enter current password don't have one
    Welcome Back:
    Visited the website for 2 consecutive days.
Comment debloquer mon pc de current password
Posted on Nov 12, 2014
    Sergeant:
  • 199 Answers
Dear Friend,
If after Acer logo password, you might have to removed the battery, and press power button for like 30 to 45 seconds to reset memory and battery.
If you are reffering to windows password, (for Windows XP) press CTRL+ ALT + DEL about two to three times (all together) then, use Administrator as username and not password.
If none of these works, download Oph Crack from the link below.
http://ophcrack.sourceforge.net/
Good Luck!
Posted on Mar 12, 2011
Enter current password on boot on acer aspire 5253g
If the pc doesn't have a BIOS password then:
1.- look at the error messages on the blue screen,
2.- the blue screen shows errors when a driver is bad or not the right one for the hardware or the OS is corrupted.
3.- try to boot using safe mode.
4.- after the logo and right after it shows the F2/F10/F12 key start tapping the F8 continuosly. If your here a beep stop tapping.
Apr 03, 2014 | Computers & Internet
Boot hp mini 1151nr laptop bios password
Re Bios Password Reset HP Mini 1000 1151NR
Try going to this site and follow what it says. If this doesn't help, please let me know.
thanks.
Jun 02, 2017 | Computers & Internet
HP Centario running Lenux I reset the CMOS battery and the blue screen still comes on says password required what am I doing wrong?
if you are running linux ubuntu
http://www.howtogeek.com/howto/linux/reset-your-forgotten-ubuntu-password-in-2-minutes-or-less/ Click "Applications" and then click "Accessories" on the top taskbar in the Ubuntu desktop. Click "Terminal" to open a terminal window. Type the following command at the Linux prompt and press the "Enter" key: sudo passwd To change the Administrator account password, the password of "root" is changed. The "sudo" command gives the current user temporary Administrator access, in this instance, to change the password of "root." First, the user will see a Unix prompt asking for the current user's password. Type the user password for the current user account. Press the "Enter" key. Next, Unix will prompt the user for the new password for "root." Type the new password for "root." Press "Enter." Finally, a Unix prompt will require a confirmation of the password. Retype the new password for root, and press "Enter." The Administrator (root) account password for Ubuntu is now reset or Boot computer into recovery mode. Reset your computer and as it is booting, hold down the "Shift" key on your keyboard. You will be presented with the boot menu. Select "Recovery Mode" from the boot menu. It is usually the the second boot option. Wait for computer to boot up. You will be presented with the Recovery Menu. Select "Drop to Root Shell Prompt." Type "ls /home" and press "Enter." Note: The command starts with a lower case L, not a capital i. You will be presented with a list of usernames of accounts installed on the computer. Type "passwd username" where username is replaced by the name of the account you want to reset. For example, if the username of your account was "jeff" you would type "passwd jeff" and press "Enter." You will be prompted to create a new password. Enter a new password of your choosing. Note: You will see no visual response when you type in your newly selected password; however, the computer still will register the input. Press "Enter." You will be asked to retype your password. Re-enter the same password and press "Enter." Your password is now reset. Type "Exit" to return to the boot menu and select "Resume Normal Boot" to restart Ubuntu.
Feb 24, 2013 | Computers & Internet
Ubuntu adm password reset
sudo passwd
or
hope this helps
Oct 02, 2012 | ValuSoft Ubuntu Linux for PC, Mac, Linux
How to unlock hdd/ssd password on toshiba satellite l655-s5153
Step 1Turn on your laptop. Press the "F2" key when the first loading screen appears. This will load the BIOS. You'll only have a second or two to press this key before Windows begins to boot. If you're not fast enough and the Windows screen comes up, simply restart and try again.
Step 2Use the right-arrow key to highlight the "Security" tab. This is the third tab from the right.
Step 3Press the down-arrow to enter the Security Settings menu. Scroll down to "User Password," listed beneath the "HDD/SSD Password Select." This will open a pop-up window with three text fields.
Step 4Type your current password into the "Current Password" field. Press "Enter." Type your new password into the "New Password" field and press "Enter." Type the same password again into the "Confirm New Password" field and press "Enter." The "Password" window will close.
Step 5Press the "F10" key to save your new settings and exit the BIOS. Your laptop will now boot normally.
Tips & WarningsHDD password can be changed as many times as necessary. However, once you enable password protection, you can never delete it.
Mar 24, 2012 | Toshiba Computers & Internet
Unlock hdd/ssd password on toshiba satellite
TipHDD password can be changed as many times as necessary. However, once you enable password protection, you can never delete it.
How to unlock my toshiba laptop/...don't know password
Right here we're going to deal with as one of our common annoyances for some time to come, crack laptop password based on any Windows including Windows XP/
7/Vista/2000/2003/2008.
Jul 19, 2011 | Toshiba Computers & Internet
It says enter current password I don't know no password
During the boot up process you will see on the screen for a short amount of time press a certain key to enter set up
Press either delete or f2 during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there
hope this helps
Nov 03, 2010 | Averatec Computers & Internet
How do I rebuild the MBR?
You will need an XP install CD for this and also set the CD/DVD drive as the first boot device.
  1. Watch for a Press any key to boot from CD... message similar to the one shown above.
  2. Press a key to force the computer to boot from the Windows CD. If you do not press a key, your PC will continue to boot to the Windows XP installation that's currently installed on your hard drive. If this happens, simply reboot and try to boot to the Windows XP CD again.
  3. When the Windows XP Professional/Home Setup screen appears, press R to enter Recovery Console.
  4. The Recovery Console is now loading but needs to know which Windows installation to access. Most users only have a single Windows XP installation so the choice is usually clear.
    To the Which Windows installation would you like to log onto question, press 1 and then Enter.
  5. The Recovery Console now needs to know the administrator password for this Windows XP installation. Unless you are using a PC in a sizable business network, the administrator password is most likely the same password you use to access Windows XP on a daily basis. To the Type the Administrator password request, enter the password and press Enter.
    Note: If you do not have a password or Windows XP normally starts without asking for one, simply press Enter.
  6. Type fixmbr and then press Enter.
  7. The fixmbr utility will write a master boot record to the hard drive that you're currently using to boot into Windows XP. This will repair any corruption or damage that the master boot record may have.
  8. Take out the Windows XP CD, type exit and then press Enter to restart your PC.
    Assuming that a corrupt master boot record was your only issue, Windows XP should now start normally.
Regards.
Aug 16, 2010 | Microsoft Windows XP Professional SP3 Full...
Lockedout before user acct. password window entry
so is your password blank?? or have you changed it to something you cant rememeber? did you create a restore disk (no one really does this so will be surprised if you have) you can try a password change boot disk (search online for this) but can't guarantee this method.
May 07, 2010 | Acer Computers & Internet
Acer Aspire One Netbook Logo
427 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
