Question about Maytag Bravos 7.0 Cu. Ft. Electric Dryer
My electric maytag bravo 400 series dryer won't start. The time doesn't come on and when I push the minus and/or add button the only thing that comes on is 1h or 2h ect... That is all it does when those buttons are pushed but the dryer wont start when I push start. Then when I do the activation where you push a button for five seconds and release for five seconds and so on everything turns on but than it says CO. What does CO mean?
    President:
  • 3,074 Answers
This may help, Tim:
http://www.assuredparts.com/MaytagBravosDryerFaultCodes.html
Posted on Mar 12, 2011
I have a Maytag bravos 300 quiet series dryer that had a error code of F73. Lights come on without code but still doesn't start. Problem?
The F73 error code means that one or more of the control buttons on the touch pad is defective. You can clear the error code by the pushing clear/cancel button, if it doesn't reoccur all is well. If it ever happens again, you will need to replace the touch pad
Apr 05, 2017 | Maytag Dryers
Maytag bravos quite series dryer will not start
Pull the back of the dryer off and see if the thermal fuse near the dryer tumbler motor is blown.
Sep 05, 2016 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
I have a maytag bravos quiet series 300 dryer with the error message f73. What does that mean?
Maytag Bravos 7.0 Cu. Ft. Electric Dryer F73 - Questions ...
www.fixya.com/search/p688923-maytag_bravos_7_0_cu_ft.../f73
have a bravo dryer , wont start shows error code f73 ? lights come on but dryer ... I think there was an F73 or F93 error message but we did not write it down.
Sep 22, 2015 | Maytag Dryers
Electrical on but dryer does not start
Sounds silly, but because it's an electric dryer, it's run on a 220 line. Double check your breaker box to make sure both breakers are in the correct position. If only one breaker is in the correct position, you'll have electrical power, but the drum won't spin.
Jul 28, 2013 | Maytag Bravos MGDB850WB 7.3 Cu. Ft. Gas...
Is there a reset button on a Maytag electric dryer purchased in 2000? Power is coming into the dryer, pushing the start button has no effect.
check the switch itself ,, you can do this with a meter and checking for continuity when the button is depressed, also check the door safety switch,, it won't run if this switch is defective,, you can check this one the same way , or just locate the connection, and add a jumper wire, to see if the machine starts
Aug 10, 2011 | Maytag Dryers
I have a maytag bravo 400 series dryer, the power comes on but the dryer will not start
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 18, 2011 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
MAYTAG BRAVOS DRYER CODES FLO, CO WON'T START AFTER STORM
I have the same problem. Technician recommended to replace main control board - didn't help. Now I ordered the user interface board. The self test results in C0 code which stays till reset.
Jul 04, 2011 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Maytag Bravo 400 series won't start. I click the start button and it beeps but nothing happens.
Well first of all you can check door switch - If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. The door switch is a simple on / off switch to indicate whether the dryer's door is open or closed. The dryer will not operate when the door is open. If your dryer runs with the door open, the switch may shorted closed or there may be a dangerous electrical short in your dryer. If your dryer will not start when you press the start button and you hear no sounds, the door switch may be the problem.
Good Luck!!
Thanks for using FixYa!!
Jul 07, 2010 | Maytag Dryers
Bravos Dryer blinking start button
Manual says it could be a number of things, and you should have a copy of the manual since you've only had the dryer 3-4 months. If not, go to the Maytag website and download.
Some things to check -
1) Press Start/Cancel if dryer was stopped in a middle of the operating cycle.
2) Check that one of the two breakers has not tripped or fuses blown (if an electric dryer) in your breaker panel.
Please reply the flashing code number so that I may can help you further.
Jan 19, 2009 | Maytag Bravos 7.0 Cu. Ft. SuperSize...
Maytag Bravos Dryer (1 mo. old) timer does not change from start
Maytag Bravos 400 Series Dryer purchased August 2009 - November 2009 required repair as I also experience the timer readjusting itself to excessive extended drying time when clothing was bone dry and hot. Sometimes extended to 1 hour 40 minutes! Serviceman stated problem was the Sensors in the dryer. Part number 8577274 Thermister and "Old Ohmed out open" whatever that means as listed on my repair ticket. Have not had that particular problem since. Make sure your dryer vents from dryer to outside are clean and clear of lint. Will help immensely. I have many other issues with this dryer it has been down FOUR times in 9 months. Fighting with Maytag to replace this lemon!
Jan 13, 2009 | Maytag Bravos 7.0 Cu. Ft. SuperSize...
Maytag Bravos 7.0 Cu. Ft. Electric Dryer Logo
663 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
