Question about Garden
Where in brisbane can I get a pressure hose that is broken can you just buy parts or buy a complete unit
Where can i buy spare parts in Brisbane
go on line to google --type in the manufacturer and model of what ever it is you want parts for and look for a page that has distributors or service centres for what you want in Brisbane.
May 14, 2015 | Samsung Health & Beauty
I can't get the pressure washer to start up. The water is coming out of the hose, but there is no water pressure
If the washer is the kind that shuts off completely when the pistol grip is released, the problem is likely the little pressure sensor located near the output fitting (the threaded part to which the hose connects). The sensor is a little plunger held down against an opening in the side of the pipe by a spring when there is low or no pressure in the output pipe, as when the trigger is pulled and the pressurized water in the hose is released by pulling the trigger. That completes the electrical circuit and the washer is on and continues pumping water. When the trigger is released, water in the hose and output pipe jams up super high pressure, forcing tjhe little plunger out against the spring, and the electrical circuit is broken. If you take the case apart, you will see wires coming from that area. The fix (if this is the problem) is to free up the little plunger.
Dec 05, 2012 | Coleman Powermate DuraBuilt 1400 PSI...
My pressure washer has no water pressure
If the pump was run with ice in it the pump may have been damaged on the crank side. This means your pump might not be moving the little pistons back and forth anymore.
You can take the cover off the water side of the pump and crank the engine *(dont start the motor! Crank with motor switched to off) and observe the pistons for movement. If they dont move the pump is broken internally on the crank side.
The only fix for this is major repairs or a pump replacement. Sorry. But most of the time it's just cheaper to purchase a new pressure washer. But you can sell the motor and supporting parts to recoup a bit too. Or buy the same unit and keep this unit for parts.
Dec 28, 2011 | Honda Garden
I have a Black & decker-pressure washer and the problem is the hose was broken. How can i fix or where i can buy a new one?
duck tape if it's completely dry and extremely tight. Mabey epoxy but that might not be strong enough. I would just get a new hose at blackanddecker . com or ebay
Black & Decker - Dewalt DP352 Pressure Washer 4000 Psi Hose
$71.99 new - TheHardwareCity.com
Jun 27, 2010 | Garden
My 06 2500 Sprinter is lazy - had it checked and the shop tells me the complete turbocharger needs replacement because the boost control solenoid is broken. Is it true that the solenoid cannot be replaced...
You do not have to replace complete turbo for VAG solenoid problem, you can buy it separately, but first test you VAG unit, behind your right side head light, 2 narrow hoses at top, one narrow hose at bottom, disconnect bottom hose and block the hose with your finger to check for suction while your buddy pressing accelerator pedal a little bit, if suction there, check turbo and turbos attachments
Jan 07, 2010 | 2006 Dodge Sprinter
A plastic bevel gear has broken and the material
You can get the gears quite easily on ebay, they are standard on all singer machines
Nov 21, 2009 | Singer 5070 Mechanical Sewing Machine
WE HAVE A GAGGIA CLASSIC MACHINE PURCHASED IN 2003. THE BLACK PART OF THE MILK FROTHER HAS PERISHED. CAN YOU BUY REPLACEMENT ONES. WE ARE IN BRISBANE.
You will need a new complete frother.
There a a few agents in brisbane under coffee machine repairs in the yellow pages.
North and southside of town
Oct 05, 2009 | Gaggia Classic Brushed Stainless Steel...
HONDA power washer ON-OFF switch
more than likely the switch complete the circuit and allows the engine to run you canjumper the switch and see if it runs, if so, you can buy a switch from auto parts store and mount it
Aug 19, 2009 | Honda Pressure Washer PSI 3000
Power Steering Recently my power steering pipe blew and started leaking due to it comming in contact with the engine. Is it possible to remove and replace this pipe or is it a sealed unit to the steering...
if it's the low pressure side i'm sure a mechanic can replace just the broken part. if it's the high pressure side, best off just to get a new hose. if not, the hose is likely to leak again on the high pressure hose if the unit isn't replaced.
Mar 12, 2009 | Ford F Cars & Trucks
Garden Logo
35 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
